Question about Danby DPAC8020 Air Conditioner
My unit keeps showing me P2 when I turn it on and it power up.
    Genius:
  • 1,417 Answers
what this mean is an error code indicating that there is some water in the system sensing error from the lens reader indicating code P2
what you will have to do fix up this problem is to open (unscrew) the unit from the strol then clean up all forms of water around the panel and the wire carefully do this then couple it back with care the problem of P2 will be solve .
thnak you and thanks for using fixya.
Posted on Jul 10, 2010
MG3260. trying to set up and keep getting P2 error message. tried turn off both power cord and switch. still the same
not picking up ink cartraiges, is the plastic sticker peice off the ink cartridges? are they lined up right in the printer, do you have enough paper in the machine for it to register.
Feb 09, 2013 | Canon PIXMA Office Equipment & Supplies
Samsung p2 won't turn on
the battery seem to be bad replace the unit.
Jul 09, 2008 | Samsung Yepp YP-P2 Digital Media Player
Tip
Display showing p2
turn unit on by display , runs for a few minutes and shout it self off , blinking p2
on Sep 25, 2008 | Mitsubishi PK18FK/FL Air Conditioner
What does p2 mean on LG1010 snr air conditioner
p2 means that to the indoor unit one of the 3 thermistors have problem.
May 07, 2012 | Heating & Cooling
I have a ductless window LG airconditioner that keeps show P2; I have lost the owners manual so I can't remember what this means.
P2 indicates a circuit protection shut down. Turn the Unit Off & Unplug it for 15 minutes. Then plug the unit back in, and turn it ON. During that time out, the electronics should have reset and the unit will go back to your original settings. If this continues to happen contact LG Customer Support 1 (800) 243-0000.
Hope this helps you and thanks for choosing FixYa.
Jul 29, 2011 | Heating & Cooling
TH42PZ85U Panasonic that will turn on for a couple of seconds, not even long enough for picture, then it shuts off. Red power light blinks 2 times with about 3 seconds in between the 2 blinks. I am...
1. Reseating the connector P25 may solve the problem. If it does not.
2.Right before the unit shuts down, check the VSUS voltage at connector P2 of the power supply. If VSUS voltage measures zero volt, disconnect the connector P2 and SS11. Check the VSUS level at socket P2. If it is still low, replace the P board.
3. Unplug the unit andd disconnect the connectors A5, A6, and A7. Apply power to the TV. If a White screen comes up and all voltages check normal, replace the P board.
4. If the TV stays on after isolating the SC board, then replace the SC board and the D board; it is likely that the fuse on the D board is blown
May 01, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
The top drawer will not drain, it stays about half full of water. how can i get it to drain?
Go to Diagnostic Test mode by:
Hold the lock button and Ress the start/pause for 10 seconds
1- When you see the display show up, press Power button to have the HO display
2- Now press the tart/pause button once a time to scroll through the letter until you see P2.
3- If you miss it, keep going then it will go back in a circle loop.
4- Once at P2, press lock button one to turn it on.
5- When it is on your water will drain.
6- To turn it off, press lock button again.
7- To get out of the deiagnostic mode, press the power button.
Happily cheerful.
Aug 08, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
My samsung p2 will not turn on...
battery can fully charged but if contacts of the tray are dirt than no current can pass through. firstly check contacts, switch showing that it is come out, after pushing it in, also check for polirities of batteries.
Mar 25, 2009 | Samsung YP-K3 MP3 Player
Yp-p2
Did you read the manual ?
There is a reset button (hole) in the back the the unit.
Oct 13, 2008 | Samsung Yepp YP-P2 Digital Media Player
None of the words are showing
Put the files on the root of the P2's folder. Unplug the P2. Leave it off for 2 mins, and power up.
Now, if this does not work, you probably need a config.dat file which you copy with the 2 firmware files onto your P2.
Open notepad
write:
YP-P2
XX XX UMS
Replace XX XX with the 2 letters in front of your P2's firmware (Settings>System>about). Example: EU EU UMS
and save as config.dat (remember all files)
Sep 11, 2008 | Samsung Yepp YP-P2 Digital Media Player
Danby DPAC8020 Air Conditioner Logo
273 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
