Question about HP Pavilion ze4630us PC Notebook
My battery for my hp ze4630 does not hold a charge and on the side of the battery it says replace with compaq spare. not sure what that means
    President:
  • 2,666 Answers
Compaq and HP are the same companyand of course they want you to buy a replacement from them.
There are many other companies which will supply you a replacement so use Google to shop around.
Here's a couple of examples.
http://www.batterylaptops.co.uk/Hp-Pavilion-ZE4630-Series-battery.html
http://www.ebatts.com/hewlett-packard_pavilion-ze4630us_Laptops_batteries_part_b-5681.aspx?GCID=C10847x001&KEYWORD=Hewlett%20Packard%20Pavilion%20ZE4630US%20Battery%20Extended&utm_source=Pricegrabber&utm_medium=cpc&utm_term=Hewlett%20Packard%20Pavilion%20ZE4630US%20Battery
Posted on Jul 10, 2010
HP Compaq NC8430: Laptop does not want to charge battery
Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Jan 30, 2013 | HP Compaq nc8430 Notebook
Its plug in but battery wont charge
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Nov 28, 2012 | HP Compaq nc2400 Notebook
Compaq Presario CQ61-320SA Notebook PC
contact hp tech support and give them the serial no and product no of the notebook...battery connectors have gone bad
Jan 29, 2012 | Compaq Presario CQ61-310US Laptop
Battery problem with HP Compaq Presario V2000 laptop
When batteries fail, they usually lose the cells inside them, which means that the cell is no longer able to function as a holding cell for power and therefore cannot do its job anymore, when a battery fails to hold and refuses charging it is bad and needs to be recycled. The flashing is telling you to purchase a new battery. The larger the number of cells in the battery, the longer and better it will perfrom,,RE: 6 cell, 9 cell, 12 cell.
Jan 13, 2010 | HP Compaq Presario V2000 Notebook
My compaq c500 wont power up?
Battery could be bad,
Are you sure it's the battery
Nov 27, 2009 | HP Compaq Presario C500t Notebook
Have a brand new battery, but it will not charge
It is not the battery, it is the charging mechanism in the laptop. See if you can buy an external charger used for spare batteries or you may be limited to ac power
Aug 20, 2009 | HP Compaq Presario V2000 Notebook
Hp compaq nx7400 - battery died and power cord will not turn comp
Some laptops will not power up with a completely discharged or faulty battery. Remove the battery from the laptop, plug in the power cord and try to boot the system. If the system boots, your battery needs to be replaced. Replace your battery as soon as you can, it's not a good idea to run the laptop for extended periods with an open battery bay.
May 07, 2009 | HP Compaq Presario V2000 Notebook
Battery won't charge
If the battery is not charging, then the charging circuit of the motherboard is bad.
Page 3-22 lists the spare part number for the motherboard. (4 versions depending on options)
Chapter 5 covers disassembly and reassembly
http://www.hp.com/ctg/Manual/c00212209.pdf
May 21, 2008 | Compaq Presario R3000 Notebook
HP Pavilion ze4630us PC Notebook Logo
44 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
