Question about Xerox Phaser 6250DP Laser Printer
Xerox Phaser 6250DP sensor not cleaning
I have a Xerox Phaser 6250DP and when i try to print, i receive an error asking me to clean the dirty sensor. I open the machine and that sensor is located behind the transfer roller. I clean the sensor but after that, the printer keeps with the same error.
    President:
  • 2,072 Answers
Is there a specific code coming up? That can make it easier to pinpoint the exact problem.
Posted on Apr 21, 2008
  • Rick Kasper Apr 21, 2008
    Give this a try.
    The Phaser 6250 should be powered on with the Transfer Roller removed, so the CTD Sensor will detect it missing and the Install or Reseat Transfer Roller message will be displayed. Leave the power on when reinstalling the new Transfer Roller Assembly and, once
    the cover is closed, the machine should proceed to Warming Up.
    If message does not clear and machine does not warm up, use NVRAM Access in Diagnostics to Reset CRU Life. Verify the CTD (ADC) Sensor and Transfer Roll Toner Full Sensor operate correctly in Diagnostics. Make sure the surface of the Transfer Roller is shiny and reflective (new), because a dull surface (defective or worn) will cause CTD readings to be out of range for a new consumable. Repeat the procedure above to clear Transfer Roller is at End of Life or Replace Transfer Roller message.
    Some other info I found. This seems more of what your describing.
    Problem:
    Cause:
    Solution:
    Fixed! Did not fix.
    TRY FIRST (Solutions without parts): 1.Check transfer roll for damage.PARTS:Parts are listed in the order of highest probability for repair.
    NUMBER QTY DESCRIPTION
    116139000 1 ASSEMBLY; HARNESS,CTD
    116139100 1 ASSEMBLY; HOLDER CTD
    116161200 1 *CIRCUIT BOARD,ENGINE CONTROL,PHASER 6250
My xerox phaser 6250 prints the first page fine then the black fades on the following pages
Your toner supply route is partially plugged and it can't keep up with the demand. It's not an easy process to clean it but a can of air, toner vac, and an area you don't mind getting dirty are necessary. Pull the imaging unit out and dig around, blowing and vacuuming out toner. Also, pull the black toner cartridge and work through that way as well. If your black toner is low, that might be the problem.
Jul 13, 2009 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 6250 yellow line at far left of page
Sounds like it is time to replace the imaging drum. This is a consumable and usually done every 15-20k pages. Cost is about $250-300 and very easily replaced, fast as changing a toner.
I am assuming that you tried changing the yellow toner already? If not, do that first...
Jun 18, 2009 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 8400 error code 37,004.40:27697
The majority of the time that code means the print head has failed.
That is a print head heater error.
You can find some places that sell print heads for about $150 , you would have to google the model number for that.
Xerox would charge $750 for a new print head, uninstalled.
Apr 24, 2009 | Xerox Phaser 8400 Laser Printer
Xerox phaser 7700 paper feed transparency errors
There is a Transparency sensor (called the OHP) which is part of the Registration Transport 116-1164-00
Clean it first. Or replace the whole assembly
Whit
Item, Inc.
Mar 24, 2009 | Xerox Phaser 7700DN Laser Printer
Xerox Phaser 6120 Error 21 OHP Detect Sensor
Hopefully you waited 30 min to an hour before moving it .if not you may have sloshed the ink within the unit witch will require a through cleaning these are great units but they can only be moved when ink wells have cooled off. To be safe at leased an hour. It's real hard to move them without sloshing because they are very heavy a must to cool. Good luck.
May 03, 2017 | Xerox Phaser 6250DP Laser Printer
Phaser 6250 "Ram error" (?)
For a continuous RAM Error message, try cleaning RAM contacts and reseating RAM.
NOTE: Third-party or generic RAM is not covered by warranty or service contract and should be removed for troubleshooting purposes.
TROUBLESHOOTING TIPS AND HINTS:
Replace RAM. If problem is not resolved, replace the Image Processor board. Please Note:
Intermittent 6250 RAM Errors can be resolved by replacing the Print Engine Board and EEPROM, remembering to Save/ Restore in Diagnostics.
Apr 15, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 6250 started printing bad
That really sounds like the imaging unit cleaner has an issue.
If you have one try the imaging unit, I really suspect that is your problem.
Black is Faded or Missing Step 1 Clean the Laser Windows and Remove Excess Toner From the Imaging Unit Step 2 Check or Replace the Imaging Unit Gear Retaining Pin Step 3 Replace the Imaging Unit (installation instructions) ic-film.gif
See if this link works. Xerox is infameous for these not working.
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=842,E=0000000000019251353,K=6024,Sxi=13,Case=obj(19377)
Apr 08, 2008 | Xerox Phaser 6250DP Laser Printer
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Jan 25, 2008 | Tektronix Phaser 860DP Thermal Printer
Xerox phaser 6250 NVRAM Failure
Cycle power, try cleaning the CTD (ADC) sensor and toner full sensor. This is what Xerox has to say about the NVRAM failure: On the front panel, press the key labeled i to view information about the error. Record the error code number. Turn off the printer. Reseat the fuser. Reseat the imaging unit. Reseat the toner cartridges. Turn on the printer. If the error continues to be displayed contact service. To be on the safe side you can follow the instructions here on the procedure to replace the transfer roler: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi Good luck
Mar 25, 2006 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 6250DP Laser Printer Logo
710 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
