Question about Kenmore 77719 Side by Side Bottom Freezer Refrigerator
Just got new kenmore elite 795.71079.010 frig, no water has gone into the ice tray to make ice, I can get water out of the door. I have turn the ice maker on and off, but make a sound like it is stuck
ngfam1
  • 639 Answers
SOURCE: ICE MAKER ON KENMORES ELITE SS
Friend,
ngfam1 At your service!
You need service this time !
Sounds like a Thermostat problem!
How old is the ice maker?
If is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Posted on Aug 31, 2008
huuum
  • 750 Answers
SOURCE: kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
You said, Kenmore elite, ice maker in door...........................???What????????
And we need more detail than Ice maker in door.
What does your ice maker do?
Posted on Sep 27, 2008
larryyb
  • 291 Answers
SOURCE: Ice maker in a Kenmore Elite Side by side refrigerator
check the head of the icemaker and see if the gear is broken on the module
Posted on Nov 26, 2008
  • 3 Answers
SOURCE: ice maker not working
make sure the wire rod on the ice maker is in the down position in order for it to make and release the ice
Posted on Dec 19, 2008
  • 190 Answers
SOURCE: kenmore coldspot top freezer auto ice maker, water
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
Posted on Apr 08, 2009
The ice maker overflows the ice tray, so water runs down the side of my freezer.
if it has worked for 3 years then I would guess just a new tray
Feb 18, 2015 | Kenmore Refrigerators
Ice maker no making ice.water not filling tray
you have a bad water inlet valve located on the back bottom of frig behind the bottom panel-mike
Jan 26, 2010 | Kenmore Refrigerators
The icemaker in the door of our Kenmore Elite Trio frig just stopped working, exactly 13 mos. after we bought it. We did not get an extended warrantee, because we have never had a new appliance fail so...
Is the ice unit turned on? I pushed the off button by mistake and PAID someone to "turn it back on for me" The guy laughed all the way to the bank :( Also he said a good place to start , before I call next time, is have you checked to see if there is a ice cube frozen(caught) in the top.Pull out the ice catcher(bin) and check for the frozen cube of ice. Be sure to turn off the ice maker first or it may drop ice when you least expect it! My fridge is the origional for house (18 yrs) and after I've done this check list, the problem is fixed. Just thought I mention it. Good luck!!!
Mar 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The ice maker stopped working on my Kenmore Mod 106.55532400
either your water valve is clogged or it has gone bad, located bottom right corner, you can take it apart and check the screen filter if it is not clogged than you need a new valve approx 72-80$ plus install unless you diy!
Nov 29, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore elite french door freezer on bottom
Odds are due to the fact the ice maker was left on for an extended time with a full tray of ice the mechanisms froze. You can take a hand held hair dryer and defrost the parts, just be careful not to get too over zealous and melt the plastic parts. It should only take a few minutes to defrost.
To avoid this problem from occurring again, I turn the ice maker off when the ice tray is full.
Regards,
Ann
Nov 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No water and ice cubes
Check the water valves in back of frig. and see if working.. make sure you got a water supply valves may be plugged
Oct 05, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Trio 795.7756 /7757 problem
I had the same problem, freezer full of groceries defrosting or crisper drawer freezing produce. Sears Appliance Repair sent servicemen out twice and both times I was assured the problem was fixed. After freezing produce the third time I insisted they come and get the faulty appliance. The replacement has worked perfectly since day 1. INSIST ON A REPLACEMENT
Sep 03, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Leaking water
test: first, turn off water supply to frig. then dry up all water. then ensure frig is running at right temperature. now gradually turn on water and observe where leak is. My guess is it is overflowing the ice-maker. there is an adjustment for this. pop off the cover over the end of the ice-maker. look for a screw adjustment. turn it counterclockwise.
Jun 04, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Kenmore 77719 Side by Side Bottom Freezer Refrigerator Logo
162 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
