Question about Zojirushi BBCC-X20 Home Bakery Supreme Bread Maker
I need a new baking pan and kneading paddle for a Zojirushi Home Bakery Model BBCCQ-S15.
Abtecparts.com has almost every kneading paddle and accessory you can imagine.
Posted on May 26, 2008
I need a baking pot and paddle for a Prima Home Bakery, model no. ABM3. Can you help me?
Try a second-hand STORE IN YOUR AREA... Good Will, Veterans, and others.
Sorry I can't be of much help.
Nov 11, 2014 | Prima Kneading Paddle ABM31 Home Bakery...
Zojirushi home bakery model BBCQ-S15 kneading blade needed
Hi Jean, I hope I can help you find your paddle. Did you lose your paddle or did you buy a machine without one. Or perhaps yours broke?
Oct 18, 2011 | Breadman TR900S Bread Maker
It won't knead :(
Hi and welcome to FixYa, I am Kelly
When you reach in the bottom of the unit with the bread pan installed is there resistance felt as you move the kneading paddle in either direction? Yes = Motor problem No = belt or kneading paddle problem. (Since this a twin paddle machine they both must move at the same time)
The belt can be found here: PN: 8-BBV-P540
http://www.thegourmetdepotco.com/items/?item=2131
The paddle can be found here: PN: 8-BBV-P290
http://www.thegourmetdepotco.com/items/?item=1550
The manual: (6.83 mb)
http://www.zojirushi.com/servicesupport/manuals/manual_pdf/bbcc_x20.pdf
If you need parts other than above contact their customer service using the number below.
Customer Service:
If you have any questions, please call ZOJIRUSHI Customer
Service Dept. at (800) 733-6270 or (323) 722-1700.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Zojirushi BBCC-X20 Home Bakery Supreme...
The spindles that you attach the paddles to is leaking a black lubricant or something like that. I was making a simple sweet dough. By the way, I NEVER bake in the bread maker. I only use it to knead the...
Your machine has a lubricating grease that is under the small gasket or washer at the bottom of the pan under each paddle. After a lot of use the little gasket can fail and the grease can get get past the gasket and into your bread. The best thing to do is either replace your pan with what is called a "pan assembly which will include everything but the paddles. If you decide to do that be sure to keep your paddles. The other choice of course is to replace your machine which might not be a bad idea if your machine has been used a lot because you would have a new pan assembly but older parts may begin to fail such as the drive belt. Bread machines aren't all that expensive anymore so you may want to go ahead and replace especially since you just use your machine for making dough.
Feb 08, 2011 | Zojirushi BBCC-X20 Home Bakery Supreme...
One of the paddles froze after baking a bread. I was able to break it free but it is still stiff
Sounds like the sealed bearing that the paddle shaft turns on is starting to fail. Fill the pan 1/2 way with warm water and soak for a few times to see it this helps. If not you should start looking for a new bread pan. Sorry Hank
Sep 12, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
Rotating shaft will not rotate - during the kneading process nothing happens
1) Make sure bread pan is inserted in the machine correctly. 2) Take pan out of the machine and make sure the paddle spins freely on the shaft. ( If not, sealed bearing is frozen and pan needs to be replaced. 3) Keep pan out of machine and start a kneading cycle. Look through the lid window to see if the motor shaft is turning. If not the belt may have come off , snapped or there is something wrong with the motor or curcit board in the machine . Hank
Aug 24, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
Only 1 Kneading Blade is working. The other stops
Hi, Could be the belt is slipping or is worn for that paddle. Belts and motor are located in the base of the machine. Hank
Mar 21, 2010 | Zojirushi BBCC-V20 Home Bakery Traditional...
Zojirushi bread maker, BBCC-15, Baking Pan,Paddle drive seal
Where can I get replacement parts for the BBCC-15? My keeper clip underneath the baking pan came off and is lost. It holds the wing clip that drives the kneeding blade in the pan.
Nov 22, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
Zojirushi BBCC-X20 Home Bakery Supreme Bread Maker Logo
223 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
