Question about Bose Wave Radio
Bose radio model awrc/10 no volume
Everything works fine with the exception of the fm/am radio does not play. CD player, alarm and display all work, but when I put on FM radio no sound comes out, not even static. Is there an easy fix? If not will just keep playing cd's only.
  • 48 Answers
SOURCE: Bose Wave System CD 2000 FM volume much lower cd stops if volume higher.
sounds like a loose cable from the control bard to , some one will have to open up to fix, i recommend bose do that for you,
as for fm volume, the same could be the cause as the fm antenna coudl be disconnected, ( are you using an external FM antenna ?)
Posted on Mar 11, 2008
  • 20 Answers
SOURCE: Non-working CD in Bose wave radio
Try replacing the battery on the bottom of the system - alot of people miss it because you have it constantly plugged into the mains, but replacing this (somehow) re-sets the system, and 9 times out of 10 solves the issue.
Posted on Dec 31, 2008
SOURCE: no fm or am reception on my bose wave alarm clock radio
I had the same problem took off the two screws in the back and one under the cd cover once I took it apart the am rod was loose i put a piece of duct tape to hold it down and it works great, don't drop it anymore
Posted on Mar 25, 2009
cjackHD
  • 71 Answers
SOURCE: How can I get the Bose Wave radio to work in Europe??
Yes. The tuner spacing option should do this. If it's a Wave Music System or a Wave Radio II, go into the 'setup menu' and look for 'tuner spacing'. -If it's older, you may want to call Bose for a solution.
Posted on Jun 12, 2009
neutronrace
  • 66 Answers
SOURCE: CD player on Bose radio started making a click sound
did you clean the laser inside? that a thing I would do first
after that mail us again
Posted on Feb 15, 2010
Bose wave awrc-1g cd player spins but does not play.
You have done what i would have suggested, the Bose Wave unit will need to back to Bose for service, and there is a good chance they will need to replace the laser pickup assembly and cost should be considered even thoe it is top of the line.
Apr 02, 2012 | Bose Wave radio/CD remote control -...
No sound from bose wave radio/cd player Model awrc-1g? Mute is not on, and volume is up!
Your volume amplifier is either gone bad or you have a blown speaker itself.
Oct 19, 2010 | Bose & Wave& Music System
I have a Bose Wave radio AWRC-1g. The CD player
Yes you have a defective laser assembly. The 139 is a great price as buying the laser lens alone will cost you around 70 .Bose will also upgrade with any new software and will also provide you with a 1 yr warrenty.
Mar 21, 2010 | Bose & Wave& Music System
The CD player on my Sony Dream Machine FM/AM CD clock radio will not play. I have left the CD compartment open per the troubleshooting instructions in the manual, to remove moisture but to no avail. When I...
The laser has gone weak. If you feel confident taking it apart, unplug it and look for a small potentiometer on the CD reading pickup. Turn it to the right to about 700 ohms, it should start reading again. If you don't have a multimeter to measure it then get one, a basic $10 meter will do fine.
Jun 26, 2009 | Sony Dual-Alarm AM/FM Clock Radio with...
10-year-old Kloss, model 88 stopped playing, suddenly.
Sounds like a cold dry joint connection problem internally ,needs to be serviced
Jan 14, 2009 | Cambridge Soundworks 88CD CD Player
I have a bose wave model awrc-1g cant set time from military time to regular
Hold the alarm setup button and at the same time hit the on/off button.
Oct 16, 2008 | Bose Wave Radio
Bose Wave Radio Logo
167 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
