Question about Haier HW05CA12 Air Conditioner
How to put in freon in my haier HW-05A12 - Haier HW05CA12 Air Conditioner
  • Haier Master
  • 43,501 Answers
You need specialized equipment and a license to do that..
heatman101
Posted on Jul 12, 2010
Where do I check the freon gas level in my Haier CPRB08XCJ
There are generally no fitting to connect to the sealed systems of portable air conditioners. You can buy a 'saddle valve' that will pierce the suction side and allow you to check low side pressure, but they will allow a very slow leak in most cases.
It likely uses R134a instead of Freon.
Jul 23, 2014 | Haier Commercial Cool 8,000 BTU Portable...
How do you add freon to haier window unit air conditioner
Window units do not come with service ports. You can buy them at local parts houses, but unless you have the freon, not gonna do you any good. Window ac use either r22 our 410a, and that cannot be bout without being certified.
Aug 18, 2012 | Haier Heating & Cooling
My Haier window airconditioner dose blow cold air even on max do I need freon and can I replace freon my self, model no.# HWF05xCA
dcorey, Freon is no longer used. R134A refrigerant gas is what is now used. Unless, you have all the proper equipment to purge the system and then introduce the refrigerant gas into the compressor, on the high side and the low side, it's not a DIY project. However, you can contact Haier Consumer Support 1-877-337-3639 for an authorized repair center in your area.
Hope this helped you.
Jul 07, 2011 | Haier HWR08XC7 Air Conditioner
How to add freon to a Haier hwr10xc6 Thru-Wall/Window Air? i accidentally damaged one of the copper lines & all the freon came out but i welded it back together put how to at it & where? help!
If the unit has no existing service valves you will have to purchase some - and braze them into the freon lines. Valves (with valve cores) can be purchased at a AC Supply house fairly cheaply and then you can braze them into the lines. One in the suction (big line that gets cold) and one in the liquid line (the one that gets warm). NOTE: be sure NOT to weld this into the 'discharge line' (one straight out of compressor).
Once you have the two valves welded into the unit - you can then charge the unit.
Good Luck!
Jun 24, 2011 | Haier hwr10xc6 Air Conditioner
My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
Jan 07, 2010 | Haier Washing Machines
I have a small haier refrigerator and it needs freon. is it possible to add freon?
it leaked out some where, so the leak would have to be repaired first . consider the cost if worth it.
Nov 04, 2009 | Haier HPAC9M Air Conditioner
Washing machine finished its last wash and is no longer working ?
All HAIER Washing Machines come with a 3 year parts and labour warranty - Ring them and get them to come and repair..
Apr 10, 2009 | Haier Washing Machines
Haier central ac unit problem
HEY,Kim, connect the red hose with the crooked end on the small line service vale and the blue crooked end to the fat line service valve and read the preassure now. Also the yellow line connect to the refrigerant tank...!
Jul 09, 2008 | Haier Energy Star ESA3183 Air Conditioner
Haier HW05CA12 Air Conditioner Logo
99 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
