Question about Bodycraft ® TR1140 Treadmill
Bodycraft TR1140 Treadmill gave me an error code of E 1. . .anyone know what that means?
SOURCE: the treadmill will stop and brings up error 1.
Hi, E1 is speed sensor or motor related, you could try changing the speed sensor, you should check wires from speed sensor to board and check wires from motor to board, yoou can check you motor by plugging the live and earth onto a 9volt or 12volt battery to see if it turns. i suggest you check and clean the brushes in the motor, hope this helps.
Posted on Oct 08, 2009
maxtreadmill
  • 832 Answers
SOURCE: asi image pro 2 treadmill error code 2
Loss signal or No Speed: 3 possible areas that can be causing the problem speed sensor , motor control Board ( MCB ) or the drive motor. Unplug unit remove motor shroud then plug in unit now on the MCB their should be L E D s lights should be on. One of the L E D s should speed on other P W M . Start your treadmill you see the PWM light flickering thus the upper console and cable connections are good now it will go back L S. Reset your treadmill then manually start pushing the running belt2_bing.gif now the speed light should be flickering if it does then the peed sensor is good if not flickering then replace sensor. If we have a good speed sensor then I would check the Drive Motor this done unplugging the unit the disconnect the two leads coming from the motor to MCB then by using a fully charge 18v drill battery connecting the leads to the motor should move it at approx; 1 mph then Your MCB is defective and need to be replaced. if no belt movement you for the most part will have worn brushes or open windings in the motor , I would open the brush compartment and inspect the brushes if they are less than 3/8" in length replace them this should the motor issue. Good Luck
Posted on May 15, 2010
  • 33 Answers
SOURCE: I have a Tunturi j770 treadmill with error code E1...
Your problem could be that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
ercupa190
  • 12223 Answers
SOURCE: Where to buy lubricant for bodycraft treadmill
www.fitnessrepairparts.com
www.treadmilldoctor.com
www.unitedassemblers.com
Posted on Nov 11, 2011
ercupa190
  • 12223 Answers
SOURCE: I got an E1 error
This conditions will be cause an abrupt
shutdown of the bel and the motor controll detect an sharp increase a drive current and inmediate stop driving belt.Some situation will be damming the belt and cause this error code .Without abuse will be a situation for cause a extreme care and analysis.
E5 error code on a YorkFitness Inspiration treadmill, anyone know what i should do?
key permanently stuck, remove the keypad connector cable. Restart the power up sequence, if the error disapear the keypad is the cause.
otherwise the PCA is the cause. the chip PCA must be changed.
God bless you
Jun 17, 2012 | Exercise & Fitness
Just purchased a used treadmill, but the former owner cleaned the belt with something that has made it too slick to run on. I've tried dishsoap and water, but the belt has a slick grease all over
I would say go to your local auto parts store or even Walmart might have Chlorinated Brake Cleaner. It's a great spray type cleaner that really works great for removing solvents without leaving any film behind. It evaporates fast & brings rubber back to it's original state.
Feb 04, 2018 | Bodycraft ® TR1140 Treadmill
I got an E1 error code the other day. Treadmill started and ran for a few seconds and just shutdown. What could that be? I have a Bodycraft TR 1160 that's about 6 years old.
Feb 05, 2011 | Bodycraft ® TR1160 Treadmill
My treadmill shuts down while running with an E1 error. What is that?
Oct 30, 2010 | Bodycraft ® TR1160 Treadmill
Motor immediately shuts-down upon start-up
check the brushes, if the machine turns on normal but the engine does not work can be a problem with the brushes, check the connections or wires that go to the motor drive card. Also check the speed sensor is often a magnet
Feb 05, 2010 | Bodycraft TR1180 Light Treadmill
Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Apr 05, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Error codes
error 1 is many times a speed sensor error. Make sure the speed sensor is in place, working and sending signal to the motor control board.
Jan 03, 2009 | Exercise & Fitness
Bodycraft ® TR1140 Treadmill Logo
142 people viewed this question
Top Bodycraft Exercise & Fitness Experts
Howard
Howard
Jay Plesset
Bill Boyd
Are you a Bodycraft Exercise and Fitnes Expert? Answer questions, earn points and help others
