Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
What is the fram cross reference part # for oil filter #78-69539-0110
    Problem Solver:
  • 6 Answers
After doing extensive search online about the cross reference with FRAM oil filters and eliminating the Briggs & Stratton oil filter number 78-69539-0110, I found the B&S REAL oil filter number.
It is: 695396 which can be cross referenced with FRAM.
I called FRAM and they gave me the oil filter of PH8170. But keep in mind that this filter is only located at auto parts stores and is a wee bit pricey.
I opted for the FRAM oil filter of PH3614 and using the SAE 10W-30 oil. This filter is great IF you have room for it. It is about 1 inch longer than PH8170. It is less expensive than PH8170 and far more available. I got mine at Walmart.
Not only did they have it in the PH3614 standard oil filter, but also in the ToughGuard TG3614 and also the XtraGuard XG3614 for a bit more filtering.
Remember though, if you go more than the standard PH3614 oil filter that it takes a bit more pressure to filter our stuff through the filter as there is more filtering compound in it. Same with XG3614. More filtering compound.
The TG and XG are great when you use synthetic or synthetic blend. They work better.
This info. was given to me by the FRAM experts when I called them. Hope this helps.
Want to see what I do? Go to : www.seattlewatching.com
Posted on Jun 16, 2015
2 Suggested Answers
  • 5 Answers
SOURCE: Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1: LOOKING FOR A DEW CROSS REF OIL FILTERS TO REPL. C...
motorcraft fl-400 can buy at walmart
Posted on May 23, 2010
What type of oil & oil filter needed for my 99 jd 4200?
Any name brand of diesel oil is good. The 4200 is a small tractor usually used on an acreage. Never is worked hard, just mow, till and other small jobs. A 5w-40 is a good choice. As far as filters, stay away from the real cheap Wal-Mart ones. Bosch, fram tuff guard, k&ns are ok if you can find a cross reference for them to fit your tractor. Otherwise go to auto zone, O'reillys, etc. and get a good quality like Wix or some others. The tractor isn't like a vehicle. Probably changing oil if you are like me at 100 hrs. it's going to be only once a year. Small investment in oil and filter for the price of a tractor. Most diesel oils come in gallons also to save you money.
Apr 02, 2017 | Cars & Trucks
Oil fiter type for 1994 ford windstar
For future reference every store that sells filter has a catalog to look this up, but here at the FRAM AND MOTORCRAFT O.E.M. PART NUMBERS.
FRAM Part # PH3600
MOTORCRAFT Part # FL400S
Sep 30, 2012 | Cars & Trucks
2011 Chevy Equinox 3.0 liter Q. what oil filter is used? (ex., fram ph10060)
There is nothing listed on Fram's web catalog but if you go by any GM dealership, you can either buy it or ask the partsman what the part number is and then use the cross reference guide on the website to get a Fram number, or any other manufacturer. All of them have cross guides. It's unlikely that GM has designed a completely new filter for this vehicle, but it is possible. If so, it will take awhile for the aftermarket to catch up.
Aug 23, 2010 | Chevrolet Equinox Cars & Trucks
I went to wal mart to get a oil filter for my 1988 Ch. Sil. 2500 that I was just given - the filter on it was Penz 29 - which wal mart does not carry so I wanted a Fram - the kid looked it up on the inter...
i know that the ac delco number is PF 1218C for the 305, 350, and 454 (you did not specify your engine). they should have a cross reference book from delco to fram.
Aug 09, 2010 | 1988 Chevrolet Silverado 2500
What type of oil filter does my suzuki intruder 1500 use?
All VL 1500s use a spin on type oil filter (just like the ones used on most cars). The filter is located on the front of the engine right between the lower oil cooler lines. Just follow the lines from the cooler to the engine and you'll see it. You will probably have to go to a cycle shop or order it on-line to get one though. Although your local auto parts store might be able to order you one as well.
The FRAM part # is PH 6018. If your local parts store doesn't carry FRAM filters they can cross reference the number or should be able to look it up for you.
Good Luck.
Mar 30, 2010 | 2003 Suzuki VL 1500 Intruder LC
What kind of oil and filter is needed for this car
For the 3100 (3.1 litre) 6 cyl. engine, use a Fram 3387 or compatible cross-reference oil filter. I also use K&N's HP-1001. Call it fate or American patriotism, but I have 4 vehicles that use that same filter, I buy them by the lot on the internet whenever I can. Here's a tip for that model: remove the wingnut on the front shroud, under the front end of the car, passenger side, to allow the oil filter to be removed easily (and sometimes sloppy if you're not holdin' your mouth right). Otherwise, it just won't fit downward past those A/T lines and going up is impossible.
Oct 09, 2009 | 2003 Chevrolet Malibu
What oil filter and how much oil for a 1992 jeep wrangler with a 2.5 ?
Parts houses have a filter chart for determining the filter number. I believe that a #16 fram filter is used on yours but different "cross-over" numbers from other companies will also fit. Your vehicle capacity is four quarts with filter.
Aug 15, 2009 | 1992 Jeep Wrangler
CANNOT FIND THE OIL DRAINPLUG ON MY 1994 SPORTSTER 883
The oil drain tube is between the rear down tubes of the frame and attaches to the frame. Don't feel bad it does not look like a the oil drain and a lot of us have trouble finding it at first.
Jun 21, 2009 | 1993 Harley Davidson XLH Sportster 883
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
4,227 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
