I think iv uninstall my speakers iv got no sound and the speaker sign not showing up in the sound manager how do i install them again there the ones that come with the computer
  • 975 Answers
Go to START , click CONTROL PANEL , click SOUNDS , SPEECH , and AUDIO DEVICES , check on your left corner , it says TROUBLESHOOTERS, click where it says SOUND ?, and follow it from there , you should be able to connect the sound back . good luck
Posted on Apr 19, 2008
Occasionally my sound system pops and does not work and I have to reboot my computer to get sound to work again. is there something in my settings on XP I should change
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
Dec 18, 2010 | Bose Companion III Computer Speakers
My laptop's audio has stopped working, and the audio area says that the speaker is working and the sound is on, but nothing plays, not even the test tone. I think it is a driver issue. The speakers are...
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
or
hope this helps
Nov 11, 2010 | Computers & Internet
Makes a loud noise when i turn on and no sound plays. I don't think i need drivers but either way they're impossible to find. I have Altec Lansing ADA215 Computer Speakers.
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Oct 31, 2010 | Altec Lansing ADA 215 Computer Speakers
BOSE SPEAKERS INOP,RCA CABLES PLUGGED INTO DIGITAL OUTPUT OF MY HP PAVILION. TRIED DIFFERENT CABLES.DONT KNOW IF IT DRIVER RELATED.REALTECK DIGITAL OUTPUT SHOWS PLAYING MUSIC BUT NO SOUND JUST HUM
hope this helps
Oct 25, 2010 | Bose Companion 2 Series II Multimedia...
Sound does not come out my speakers at all now
Try going to Device Manager:
- Click on the Start button
- Look for Computer, or My Computer, and right-click on it
- In the menu that pops up, choose Manage
- A window named Computer Management comes up
- On the left pane, look for Device Manager and click on it
- The right pane will show you the Devices on your system. The sound drivers go under the "Sound, video & game controllers" section
Under this section, look for any devices that have a yellow or red sign on them. This would indicate a problem with that device. It would most likely be caused by a driver problem. Either a wrong driver, or a corrupt install. Be sure you have the right driver and try installing again.
If you don't see any devices there with yellow or red symbols, it could indicate a hardware problem, e.g. loose internal speaker cable.
Let me know what you find.
Nov 10, 2009 | HP Pavilion dv9000z Notebook
Popping sound coming from unit.
1. Check that the speaker input cable or input jack is not damaged. Do this but plugging in some other speakers or headphones into the computer and plugging the speakers into a MP3 player or cd player.
2. check device manager. This can be done in Win XP by right clicking my computer, properties, hardware, then click device manager. Alternative way to enter device manager is by clicking start menu, control panel, system (performance and maintenance), hardware then device manager.
In the deice manager window see if any question marks or exclamation points are visible.
If so, see if it the mark is for an audio device.
If it is an audio device, uninstall the device.
Next, try to install the sound card driver again. If that fails, the enter the device manager and uninstall the sound card again, restart the PC, ignore the hardware manager, and try to install the sound card driver software again.
3. If the sound card is a separate discrete card then you can power down the PC (do powerdrain procedure to drain capactors) and reseat the sound card.
Hopefully some of this helps
Brian
Jul 09, 2009 | Altec Lansing M604 Computer Speakers
Logitech
1.
Lets start with the obvious. Make sure the volume mixer control is not muted. This is usually a speaker icon at the bottom of the screen. If you do not see this then go to control panel, sounds and audio devices, and make sure nothing is muted.
2.
Jul 09, 2009 | Logitech X-530 Computer Speakers
REALTEK REMOVED MY WINDOWS SOUNDS!!
Solution:
best sol: go to start button ----->click RUN----->Type devmgmt.msc in Text Box ----->
              Device Manager windows appears , click on Sound, video and game controllers(+),
              if you see "Realtek AC97 drivers"(if they are visible...) then we can make sure that sound                     drivers are loaded in ur system, otherwise you have load it again.....
                                                          or
i) my best advice would be, dont mess up with installing, reinstalling, uninstalling sound drivers rather try   to format or reload your OS again(Windows XP) and then install drivers.
ii)  try to check volume on your speakers, volume in windows or system , volume in media players sometimes they may set to mute of no volume.......
iii) try to check all sound physcial connection that run from your computer to speakers, including power connections, cable connection ....or just remove and replace them(reseating...)
iv) try connecting a headset to your sound port, sometimes your subwoofers or speakers may fail.....
Thanking You
M. Sridhar
Dec 27, 2008 | Digital Audio OMX-LE (OP428LE) PC Desktop
No sound on my toshiba satellite laptop
Have you done re-installation of window?
Do you have the motherboard Cd with you? Since audio driver can be easily install from there.
Otherwise google for the audio driver for your Laptop and select the appropriate one.
Let me know if bit more detail if you need further assistance.
Ellin
Oct 14, 2008 | Computers & Internet
SPEAKER OUT PUT
I think it may caused due to improper sound driver settings correct it
sol.
first go to device manager
for that press right mouse button on my computer icon
select properties
click hardware
double click sound, video and game controllers
select each driver, uninstall one by one
click right mouse button for getting uninstall option
After you uninstall all drivers, restart your computer
The computer automatically detect your sound driver
Jan 14, 2008 | Audio Players & Recorders
Computers & Internet Logo
David Payne
David Payne
