Question about Microwave Ovens
I have an Maytag 30 inch Electric Wall Oven Model CWE9000 and F-7 keeps appearing in the display with a continuous beeping. Why is this?
2 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: i have a Jen Air
Hi
Thanks for using FixYa. Error F2 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 28, 2010
Maytag model MMV4203 display shows SE
same thing as Samsung - shorted key - google manual
Feb 01, 2016 | Maytag MMV4203D Microwave Oven
5E display on maytag microwave
<- Let me know your full model number from the tag on your oven so I can give you detailed information repair.
Unless there is grease or moisture on your control circuit board, "SE" means you have a shorting membrane keypad.
Jan 05, 2014 | Maytag MMV1153A Microwave Oven
Unlockmy lg microwave oven
As with most situations, it depends on the model number, but try this:
To set child lock:
1. Touch STOP/CLEAR pad.
2. Touch and hold 0 pad more than 4 seconds. LOCKED will appear in the display window and oven will beep twice.
To cancel child lock:
1. Touch and hold 0 pad for more than 4 seconds. LOCKED will disappear from the display and the oven will beep twice.
Sep 10, 2013 | Microwave Ovens
How do I access fuse in maytag model mmv4205AA
If the oven is dead - no display, no beeps when you press a pad on the keypad, and no inside light when you open the door - then I would suggest that you very the outlet is okay under load.
A hair dryer or toaster are the best ways the average DIYer can test the outlet under load.
If that's good, then your microwave may be dead due to a blown fuse, magnetron thermostat, or oven cavity thermostat.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If the fuse and magnetron thermostat are good, then you will have to take the oven down from the wall to get to and test the oven thermostat.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Aug 31, 2012 | Maytag MMV4205 Microwave Oven
GE microwave/convection oven 1790 there is a #8 displayed in the right upper corner of display
HELLO.
When the F8 code appears,it means that electric control requires replacement because the relay drive circuit has been lost.
Attempt to clear the code by pressing Cancel and cutting power to the range for 30 seconds.
If the code cannot be cleared, replace the electric control.
thanks.
Sep 21, 2011 | GE JVM1790SK Convection/Microwave Oven
F3 flashing on display screen..no buttons work!
I have the same problem. However when I unplug the microwave from the wall outlet, let it sit for 10 seconds, then weird codes appear on the top line. Reset the clock and it shold work just fine.
zayd4@aol.com
Apr 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
59 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
