Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
Quit running while cutting the grass. Notice gas coming out of the exhaust when trying to crank
Just as Alaska bratt says check your carb. I had gas leaking into the oil and the entire engine was destroyed. Gas dilutes the oil and then there is no lubrication. FYI don't be worried about gas/fire as the gas is also diluted and is not very flammable, with gas it is the fumes that are highly flammable. I recommend rebuilding the carb draining the engine oil and keep your fingers crossed that you didn't damage the piston/sleeve/cylinder.
Posted on Jul 20, 2010
    Sergeant:
  • 299 Answers
Rebuild the carb or adjust the lean, sounds like its getting too much gas that sounds very dangerous when gas hits exhaust it gets explosive, be careful.
Posted on Jul 19, 2010
Cub cadet gtx 1054 cutting grass and the tractor stop running. Will not start
check wires and connectors--check the inline fuse --seat switch -battery look over the wiring possible wire damaged or disconnected
Aug 14, 2016 | Cub Cadet GTX1054 54 in. 27 HP Kohler...
After 45 minutes of run time drops to half power
it is droping to half power to stop the motor from over heating check the water level and oil top them up.
Jun 27, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Kohler engine troubleshooting
Sounds like you got some dirt or rust in gas tank
try emptying the tank and cleaning it out. also check you bottom of you gas can too it could be souse of dirt in you tank.
Just remember to put fresh clean gas in mower gas tank after you clean it.
Aug 18, 2014 | Toro Garden
Why does the engine slows down when engaging the blade
check fuel filter and pump pressure starving for gas
Jul 02, 2014 | John Deere Garden
Echo trimmer srm230 runs but will not rev to cut grass
Check the spark arrester in the muffler out let is no blocked with carbon, remove the muffler and check the exhaust port itself is not carboned up.
Jun 03, 2012 | Echo Garden
I have a Cub Cadet LT 1018 with an 18hp Kohler motor. It was running fine today while cutting the grass it just shut off. It will not restart. The engine will crank over fine but it will not fire. I...
First make sure you have oil in it. Next take off the air cleaner box. Try restarting it if it runs fine clear or replace the air filter. Also check to see if it’s getting spark.
Dec 22, 2017 | Cub Cadet Street Sign- tractor lawn riding...
2005 Cub Cadet RZT 50 dark grey exhaust smoke upon start-up, plus some smoke when blades are engaged. Muffler gets very hot, and the engine seems to choke somewhat. The remote choke lever is opening and...
It sounds like it is very likely you have gas in the oil. This happens when the needle valve in the carburetor is leaking gas thru and into the crankcase. That will have to be repaired and the oil needs to be completely drained and refilled before running. Another thing can be done as a temp fix and that is to place a fuel (gas) shutoff in the line and turn off when not running but the oil has to be changed. Hope this helps you.
May 01, 2017 | Cub Cadet Garden
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
610 people viewed this question
Top Parks Optical Garden Experts
colesmowers
Renee Knafel-Bullock
Adam Jasar
Level 1 Expert
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
