Question about Rio Go Video DDV9050 Dual Deck VCR
My tape is stuck inside and i want to eject
My tape is stuck inside and i have no remote to press eject
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Locate any screws that hold the top in place. carefully slide the top off. find the loading motor. it should have a worm gear on it. turn the gear and after a while the tape should come out. is this only in one vcr in the duel deck? please reply if you can fix it. if that did not work, just let me know. good luck!
Posted on Jul 11, 2010
VHS tape is running at high speed when insert it to VCR. no playback..buttons doesnot work.
Check if the fast forward button is more inside than the rest of the buttons. May be its stuck in the ff position. After all they were just micro switches below the plastic buttons strip. The specific ff micro switch may be stuck, if I were you I would try some switch cleaning spray to loosen it. But be prepared that the control ic is busted.
Jun 21, 2014 | Panasonic Televison & Video
How to eject stuck tape
might have to remove bottom of vcr and manually move the drive motor by the belt or the pully. if the bottom doesn't come off, you'll have to remove the top. usually screws on the side bottoms and one in the back. you can reach the motor from there.
Feb 27, 2014 | Mitsubishi Televison & Video
A cassette has jammed inside my vcr machine. It will not move forward or backward Can yoy please help
Since the tape won't come out then it means you will have to manually remove the stuck tape. This involves you disassembling the unit in order to help/assist the player get the stuck tape out.
Turn of the unit and remove from the wall, get a Philip screw driver, use it to remove all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now plug the unit, and turn it on. Press the eject button, as the tape tries to come out, support it with your hand so that it can come out.
Or if it happen that the cassette tape has coiled inside the unit, carefully free the coiled tape and the press the eject button.
Lastly, the moment you disassemble the player, you would see what's preventing it from coming out, then you can free whatsoever that is making it stuck press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
I hope understand the above explanations.
Good luck.
Mar 04, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
VCR tape won't eject
The reason your tape wont eject is either because, it is stuck or the tape run loose inside of it.
To remove the tape, unplug the VCR, then unscrew it open, you will have direct access to the tape, so try to plug it back and press eject, when it gets stuck, apply a little force in pushing the tape up, to the height where it is to pass out, and it will eject your tape.
If you are not familiar with such activities, i will advice you get a repairman to get this done for you, in order for you not to damage any other part inside the VCR.
Take cacre and good luck
Oct 14, 2010 | Sylvania LV448HG VCR
Entire front panel does not work, but responds to control.
have you pulled the plug from the wall for a few minutes?
also, some vcrs will eject the tape when the RECORD button is pressed on the remote, and a tape is inside that has the record tab REMOVED!
good luck
Feb 07, 2009 | RCA VR622HF VHS VCR
Magnavox TV: Somehow the record button on the remote will not record VCR. It ejects the tape and does not record. Please help. Thank you.
Try Using a new VHS tape. If the new tape ejects when press recording, the recording switch inside your VCR could be defective.
Let me know if you require further assistance.
Aug 26, 2008 | Televison & Video
TVSC1320 13 in. combo from January 2000 VCR Tape is Stuck
i took mine out with 2 butter knifes. 1 pressing on each side of the tape forcing it outward while pressing eject at the same time
Dec 23, 2007 | Zenith TVBR1330 13 in. Combo
Tape can't eject out
Did the tape go all the way in? If it didn't make it all the way in, try lightly pushing on both ends of the tape to even it out if it is crooked inside the tape slot. If it did go all the way in, and won't release at all, try pressing down on the top of the tape in the slot. Make sure it is evenly positioned in the tape holder. If it started to come out, but didn't make it all the way out, try doing the same as before by pushing on both ends of the tape to even it out or get it further in to try ejecting again.
Sep 07, 2007 | Samsung CXM1974 19 in. TV/VCR Combo
Stuck Tape Removal
usually a reboot gets it out...hit eject button BEFORE windows starts up...I've seen some get stuck forever... Good luck.
Aug 22, 2007 | Quantum ValueLoader SDLT 320 Super DLT...
Televison & Video Logo
131 people viewed this question
Top Rio Televison & Video Experts
Rommel Balcita
SHARCNET-USA
SHARCNET-USA
Jaime Hernandez
Are you a Rio Televison and Video Expert? Answer questions, earn points and help others
