Question about Ecoquest Flair Air Purifier
I have a Ecotech Flair air purifier that im not sure if it works correctly ? the fan works and the ozone plates sound like they are buzzing like a bug zapper but when i dial the square feet dial to the off position there doesent seem to make a difference ? im not sure how it is suppost work correctly ? Thank You Jack
Got the same problem except that when sq. ft. dial is moved to the off position, the sounds goes away
Posted on Jul 19, 2010
I have a Flair air puifier but no ozone smell. I replaced the high voltage transformer( it was a 3500 watt instead of a 5000 watt transformer) The red light now flickers but no ozone smell . It has ne
Your ozone generator may have gone bad. It's the small black rectangular looking apparatus located near the bottom of the unit. It usually has a zip tie holding it to the circuit board. You will have to take the Flair out of it's case to see it. Make sure it's unplugged and remove the bolt from the bottom of the unit. You can then slide the framework out of the casing. It's also possible that it's time to replace your Ceramic Ozone Plates. They have a life expectancy of 2 to 4 years. The Flair has two of them that slide into slots in the rear of the unit. You can see them when you remove the washable filter. All items can be purchased on Ebay. DM
Apr 28, 2012 | Ecoquest Flair Air Purifier
No ozone smell can it be repaired or do i need to buy another unit
You can try a couple of simple fix-its before deciding what to do.
The plates (4" white ceramic squares with screen glued to center of each side) must be clean and inserted correctly.
1) Soak the plates in equal parts plain ammonia/water for 5 minutes. Scrub gently with a toothbrush or small veggie brush. Rinse well. Blow dry or air dry. DO NOT use a towel or paper to dry it off. Avoid touching the screen with your fingers. Clean the metal fingers with a cotton swab and alcohol.
2) Insert the plates firmly, making sure they go in on the tracks, and that the contact fingers rest firmly on the screen part.
If you still detect no ozone, it's probably because the transformer is no longer working. Vollara (formerly EcoQuest/Alpine) no longer repairs or sells the Flair. You may be able to find someone (former dealer perhaps) who has parts and repair skills, or else you'll need to find another machine.
Jan 10, 2011 | Ecoquest Flair Air Purifier
Can feel motor run, but fan doesn't turn and very little ozone smell-have new plate
same deal with mine. Im gonna open er up n give a look c. Im thinkin the fan motor is running but not enough 2 turn the blades. Im fixin 2 google fan motors now as a matter of fact.
Jun 09, 2010 | Ecoquest Flair Air Purifier
My Flair stopped working correctly,so I purchased new Ozone plates. It still doesn't provide that clean ozone smell. I took mine apart and cleaned it and noticed a small bulb inside that doesn't light up....
pull the unit out of the enclouser and check the bottom for a circuit board and on the board their is a glass fuse see if it is blown. Also on that same board their is a small round black fuse that is labled f21 it is a 400ma 250 volt fuse on my unit and is soildered in this fuse is just for the ozone
May 23, 2010 | Ecoquest Flair Air Purifier
HELLO AND GOOD MORNING I HAVE A FLAIR AIR
Open the back and change the Ozone plate. then slide out the ION plate and clean it with denatured alcohol. If no light inside, you may have to replace the bulb and / or starter. Hope that helps.
Mar 18, 2010 | Ecoquest Flair Air Purifier
My flair works o.k. except the santinizer doesen't work. I have one ozone plates that is broke on the corner of the plates and there is a black line running through it. Could this be the problem?
The ozone plate will not cause the sanitizer button to not work but it may have caused the button to short out. The sanitizer switch probably needs to be replaced. The plate definitely needs replacing, when there is a crack in the plate it causes an electrical arc which is burning the black line onto the plate. Please remove and throw away that plate.
Jun 07, 2009 | Ecoquest Flair Air Purifier
THE WET DOG SMELL
try soaking the grid plate in ammonia
Jan 11, 2009 | Ecoquest Flair Air Purifier
EcoQuest Flair Air Purifier
get more distance from the two sparking points....with the power disconected, pryde the two metal points apart as mach as possible..to a quarter of an inch!
Nov 14, 2007 | Ecoquest Flair Air Purifier
Ecoquest Flair Air Purifier Logo
299 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
