Question about Cobra 18 WX ST II 40-Channels Base CB Radio
Intall a cigarette lighter adapter to a CB radio
    Champion:
  • 219 Answers
Are you asking can you. If so yes it's just two wires
Posted on Jul 14, 2010
Where is the cigarette lighter fuse located in a 97 buick century?
GOOGLE is your friend! Open up Google then search for this exact phrase (without the quotes)
"97 buick century cigarette lighter fuse location"
Aug 05, 2014 | TRUCKSPEC TSP-311 12-Volt 2 Outlet Fused...
How to install a cb radio in a 1997 chevy truck
get a dc plug for your cigarette lighter and connect it to the radio wires(black on black red to red) its the best and fastest way for install and cheap.
May 25, 2012 | Cobra 29 LTD CB Radio
Purchased CB radio kit from Maplin with TTI brand CB and mag mount aerial in kit. Installed new CB's using a cigarette lighter adapter which plugs into lighter. CB comes on fine and this appears to be...
Sounds like you have a bad antenna.Altough it might be new doesn't mean anything I have customer come thur my shop with new antennas that they bought mostly from truck stops that have the same problem most of the time they have no ground,although its a magnet mount it can still read bad,take it to an honest shop and let them help you.
May 17, 2011 | Radio Communications
I just got my first cb and am trying to install it. I have connected the red wire in the fuse box( to the radio) and grounded the black wire. turned the car on and I cannot get any power to the CB, but the...
Take a deep breath and start over! The best way to power this little radio is probably through the cigarette lighter or 12vdc accessory jack. It is simple and straight forward and no fuse box or negative ground wires to worry about. Go the Radio Shack, purchase an adaptor (cig lighter type) and hook it up to your radio wiring being careful to watch polarity. You may have to have your ignition on to run the radio, but that is much safer that maybe blowing up the unit.
Unless you are running a larger more powerful unit or an amp, there is no added benefit to hooking the radio into the fuse box.
Dec 16, 2010 | Cobra 19 DX IV CB Radio
Can cigarette lighter plug be used for 93t galaxy radio?
Yes, but be very careful of polarity. If you hook it up backwards the radio will stop working because it will blow the polarity protection diode.
Sep 15, 2010 | Galaxy Radios DX-93T Base CB Radio
Can I wire the TR-121 directly to a cigarette lighter???
yes, just buy a good plug and make sure that you polarize it right.and that your vehicle has the right system voltage also make sure that you have a fuse inline for the radios pwr cable
May 19, 2010 | Ranger TR-121CP CB Radio
I purchased a used Cobra 19 DXIV cb radio that has a black & red wire with a fuse. I was told that the wires can be wired into the fuse box under my dash. How do I do this?
You may need a test light to do this.
1. Decide if you want the power to the radio to be full time or only when the key is on.
2. If you want part time the easiest power source to access is the cigarette lighter. You can either splice into the power wire going to the cigarette lighter (center lead) or you can get a cigarette lighter plug and install it on the end of your two power wires. Center is the positive. The plug costs about $4 and takes about 10 minutes to install.
3. If you want full time you will need to find a circuit that is hot at all times and splice into it.
Use a noise filter on the power as just about all circuits in the vehicle are liable to be noisy power circuits and this will show up in form of excessive static noise during radio operation.
The red with the fuse is your positive lead. Do not hook these up backwards as this will certainly ruin the radio.
Jan 17, 2010 | Radio Communications
Have cobra 29 nw ltd keeps blowing fuses inline and in cigarette lighter adapter adapter is 10 amps and inline is no more than 5 amps
This is an easy fix if you are comfortable soldering.
You must have hooked it up backwards. Big problem when using a cigarette lighter adapter. You have to be careful, if you hook a radio up backwards you blow the polarity protection diode.
  • Go to radio shack and buy an N1004 diode.
  • Open the radio
  • Look towards the back right of the radio for a black diode D23. it will probably look burnt, but not always.
  • Use a soldering wick to remove the solder holding the diode in.
  • Remove it, and replace the diode making sure its going in the same direction as the old on. Strip on the side the triangle is pointing.
  • Solder it in.
  • Test the radio
That should do it.
Make sure you are careful to hook the radio up to power corrctly.
Nov 14, 2009 | Cobra 29 LTD CB Radio
Cobra 18 WX ST II 40-Channels Base CB Radio Logo
506 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
