Question about Online Double Conversion 1500VA 1050 Watt UPS (GX1500) UPS System
UPS is on but the devices are not getting the power out of it
  • ginbot86 Jul 09, 2010
    What make and model is this UPS? If you know what it is, see if you can find yourself an online manual for your backup. It should tell you what to do.
    Sergeant:
  • 238 Answers
Check the internal connections
Posted on Aug 06, 2010
I already replce the new battery that also is showing in overload pls solve that problem
UPS in overload. Try removing some of the attached devices one at a time to determine which on is causing the overload... it may also be a combination of devices causing the overload.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Nov 07, 2013 | APC Back-UPS RS 1000VA UPS System
Tip
Benefits of a UPS (Uninterrupted power supply
We all use many devices and equipments that run on electricity. For all these to function properly they need uniform power supply (constant flow of electricity). As the electric supply in many countries is not uniform there is a need for a device to correct it. There are many such devices available in the market today. For example UPS (Uninterrupted power supply), Voltage Stabilizer, Constant Voltage Transformer are such devices available today.<br /> <br /> <b><u>Why buy a UPS?</u></b><br />We can never guarantee that we will get constant power. The power supply always has fluctuations. Surges, Spikes, Brownouts, Blackouts and Noise can damage your electrical appliances especially your computer. To prevent this from happening you need a device that does power conditioning. Electricity has to be uninterrupted. If the voltage is higher than the specified level then it is 'Over Voltage'. If the voltage is lower than the specified level then it is 'Under Voltage'. Both Spike and Surge come under 'Over Voltage' category. But there is a small difference between spike and surge. If there is very high voltage for an instant but comes back to normal immediately then it is called 'Spike'. If there is very high voltage for a slightly longer period then it is called 'Surge'. If the voltage is dangerously reduced to very low within a short period of time then it is called 'Brownout'. When this happens, the computer can be seriously damaged. If the power supply is totally cut then it is called 'Blackout'. Noise can mix with electromagnetic or radio waves or any signals. This is called 'Line Noise'. This may also reduce the voltage level to very low within a short period of time.<br /> <br /> <b><u>How can the UPS provide power when the main electrical supply is cut?<br /></u></b>A UPS has an internal battery. With this battery charger, an Inverter is also present. The inverter converts the 'Direct current' supplied by the battery to 'Alternatinc current' as required by the computer. When there is electrical supply the charger in the UPS charges the internal battery. When there is a power cut, the battery kicks in to supply the DC which is converted to AC by the inverter and power is supplied to computer.<br /> <b></b> <br /> <b><u>What if the battery loses its power?</u></b><br />When there is power cut, the required power is taken from the battery. Therefore the battery keeps losing its capacity. If the power supply comes back before the battery is depleted then the battery charger will start recharging, but if the power supply doesn't come back then the battery keeps supplying until it totally drains out. When the battery drains below a certain level the UPS sounds an alarm for your to shut down your computer and turn off the UPS. Some UPS' even have a built in system that shuts your computer down for you after a certain amount of UPS uptime.<br /> <b></b> <br /> <b><u>How long can the UPS provide power when there is a blackout?</u></b><br />This all depends on the specifications of the UPS and the requirement of the computer. A 600vA UPS for example can supply power to a computer with a 550W power supply for about 10 minutes or more.<br /> <b></b> <br /> <b><u>Tips for buying an UPS</u></b><br />The backup time of your UPS is the most important you need to consider. Other than that, you should know how many KVA (Kilo Volt Ampere) your UPS has. A computer needs atleast 0.5 KVA (500VA) to function. If you are planning to connect more than one computer to a single UPS then you need to get one with a higher KVA.<br /> <b></b> <br /> <b><u>What type of battery does a UPS use?</u></b><br />UPS uses <b>SMF</b> batteries (Sealed Maintenance Free). These type of batteries can be used for 5 to 7 years continuously.
on Mar 05, 2011 | Computers & Internet
Red light
Jul 23, 2013 | APC Smart-UPS 1000VA UPS System
We have a new 60 inch LED Sharp TV. Will an APC #BN600R battery backup, 600 VA 360 watts, handle a power outage or surge for this TV and a Dish network DVR??
Yes this UPS will protect the TV and the DVR.
The TV is pretty energy efficient, and uses just under 100watts powered on. The DVR uses under 30 watts, so under heavy load you won't go over 150 watts if just these two devices are plugged into the battery backup side of the UPS. I'm not sure how long this UPS battery last's in a power outage, but since you are not using it to the full 360 watts, you should get double time out of it, though of course, its best to power off your devices as soon as you can. Regards, Chris
Jul 12, 2011 | APC BN600R Battery Back-up 600VA UPS...
Dear experts; We have a HP R3000xr UPS, inetend to install the power management software on a server runs windows server 2008 R2 OS. Installed the power manager server software, the following messages...
Is the cable USB or SERIAL?
make sure serial port IRQ is enabled in BIOS
ALso make sure you are using x64 and not x32 drivers for UPS
ALso try getting a USB cable to connect to your UPS device
Feb 17, 2011 | HP R3000 UPS System
I hit the button to turn it on it will stay on for awhile and then it will start beeping really loudly an shut off
With your UPS turned off, unplug your PC and all other devices from the unit. Then turn the UPS on. If it still beeps and shuts off your UPS internal battery may need to be replaced or you have an internal UPS failure. Look for a red "battery alarm" light on the front of your UPS.
If the UPS does not shut down with all devices disconnected from it, Power off your monitor and look on the back of the monitor for a label which will tell you the amount of power it requires (probably 100 watts or less). Plug the monitor's AC power cord into your UPS and turn on your PC and monitor. With the UPS plugged into the AC line you are not using the internal battery and the UPS should remain on and your monitor should be working. If it shuts down you have an internal problem with the UPS.
Now unplug your UPS from the AC line (simulating a power failure) Your UPS is rated at 350 watts. Accordingly it should easily support the 100 watt load of your monitor. If the UPS continues to provide power to the monitor for 1 or 2 minutes down it's an indication that it's working properly and the COMBINED LOAD of your monitor. PC etc. when plugged into the UPS is exceeding the 350 watt capacity of the UPS. You will have to disconnect 1 or more devices from the UPS.
NOTE: Never plug a laser printer into an UPS.
If the UPS immeadiately shuts down after disconnecting it from the AC line with only the monitor plugged into it you have a bad battery.
If you found this information to be helpful to you please return to the FixYa website and rate me.
Regards,
Yavacotech
Dec 07, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
My UPS does not start
I'm guessing that during the power outage, the ups battery completely discharged. Now it will take about 14-15hrs to recharge it.It will not support any devices until it is fully charged. Remove all load devices and let the battery restore to full charge before re-connecting the devices. If the battery does not recover, it needs to be replaced.
Apr 16, 2010 | APC MasterSwitch Power Receptacle - Power...
Damage to equipment from power surge
yes a spike may destroyed the mov (metal oxide variastor) inside projector replace it problem will be solved spike comes in the case of storm and lightning strike apc ups are well protected from spike and surge
Mar 04, 2010 | APC Back-UPS XS900 (BX900) UPS System
My ups battery backup time is too short even i replace the battery
sounds like you have too many devices plugged in, it's not the ups that's failing it's the amount of power it takes to keep all you devices running. you may want to buy a larger ups or you can unplug some of the devices you don't need in the event of power outage. if it's just your pc your power supply might be sucking up alot of juice, i'd check and see what the power consumption rate is on that particular power supply.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Nov 15, 2009 | Dell Uninterruptable Power Supply, 1500VA,...
UPS does not supply power to equipment after power trip
Some of the less expensive UPS devices have two sets of plugs.  One set provides backup power and the other set only provides surge protection.  You need to ensure that the devices for which you want backup power are plugged into the correct outlets on the UPS.
Apr 20, 2009 | Computers & Internet
Computers & Internet Logo
Top Online Computers & Internet Experts
PhillipDodge
PhillipDodge
Level 1 Expert
Alex
Alex
Are you an Online Computer and Internet Expert? Answer questions, earn points and help others
