Question about Husqvarna Garden
How do i repair a choke lever in a weedeater te475y gas trimmer? Does the lever pull straight out of the carburetor.
    President:
  • Husqvarna Master
  • 1,545 Answers
Upon inspection of this model machine, it appears that the choke lever shaft is pressed into place when the carb is manufactured. Removal may be possible, but probably more damage will occur. I have this same model machine with a Zama carb having flooding issues after soaking in a bath-type solvent overnight. This is NOT recommmended.
Here is a parts breakdown for your machine:
http://www.ereplacementparts.com/weed-eater-te475y-gas-trimmer-parts-c-17589_17626_18141.html
Unfortunately, there is no avaiilable release date for the part you need in question....On the page I made available it is part # A800 or A801...depending whether you have the Walbro or Zama carb. Mine has the Zama.
Posted on Jul 10, 2010
What can I use to adjust the carburetor on a weedeater with out a special tool?
before adjusting check have right mixture --airfilter is clean-spark plug good -and exhaust screen [on quite a few ] is clean and not carboned up and fuel filter is clear--if still going to adjust only need a small screwdriver
Aug 31, 2016 | Garden
My weedeater max te475y starts on full choke but wont run on half or run please help
problem--- main jet blocked or diaphragm has failed
check prices of parts as a new carby is around the same price on e-bay
Jul 16, 2016 | Garden
How come weedwacker tries to crank while on choke but when you move lever to 2nd position it tries to crank? but wont
When mine does that I go back and reprime repeating the process. It seems the gas does not feed up fully with the initial priming effort. Once it starts I move the choke lever quickly on way or the other to see if I can keep it running until it gets warmed up. Sometimes I have to adjust the choke setting even after it has run for a while.
Sep 21, 2014 | Craftsman WeedWacker Gas Trimmer 25cc...
How do i remove/replace the choke lever on my model 128cd trimmer? I have the carburater cover off but i cannot get the lever to slide off the rod.
I do not believe this lever comes loose from the carburetor. When a kit is ordered, the lever comes with the carburetor kit.
Jun 08, 2014 | Husqvarna 28cc Gas Line Trimmer
My wife put a small bottle of 2 cycle oil directly in the gas tank of my Weedeater edger and then added gasoline. Bless her heart she tried to help me out. Emptied the tank and refilled it correctly but...
Take the air filter off and make sure it is not soaked with oil. Leave if off. Get some carburetor/choke cleaner and have someone spray it into the carburetor throat while you are pulling the starter. You may have to open the choke to do this. You may also need to pull the spark plug and clean it if it is oil fouled. Hopefully, no real damage has been down and the machine will eventually start.
Nov 28, 2010 | Poulan Garden
Troybuilt 15cs Can not adjust cab. Only runs with choke pulled full on. touch gas to kick down choke engine stops???? Help
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me,
Thanks
Good Luck,
I hope this helped
Aug 04, 2010 | Troy Bilt Tb70ss Gas Trimmer
PROPER WAY TO START TRIMMER.
Pump the primer bulb on the carburetor at least 7 times....set choke lever ( the yellow lever on the air cleaner) to the down start position....pull start handle till it fires....let machine run for about 30 to 45 seconds before you open the throttle to give it a chance to warm up....that's it !!! ;-D
Jul 05, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Only runs on choke
fit a diaphragm kit in the carby
the pump diaphragm is the first to fail and then the float diaphragm distorts and will not let in enough fuel to keep it running
Jan 10, 2018 | Craftsman 25cc Gas Line Trimmer
Echo trimmer won't start, gasoline flows out of exhaust
look at choke and air filter. ensure choke is operating and clean air filter.
May 24, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Garden Logo
524 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
