Question about Polaroid Cameras
I turned the camera on, after i was done with it the lens wont close i put new batteries in it. and it still wont shut off. i bought the camera in january.
  • 10,594 Answers
Model number and brand info is needed to find out possible cause of problem, problem sounds with lens assembly, however, your camera would be under warranty as it was purchased in January so call Store where you bought it and ask them about warranty cover.
Let me know if you have additional question.
Thanks.
Posted on Jul 09, 2010
  • el1962 Jul 10, 2010
    Sorry I forgot the model it is a Polaroid i737 digital camera
  • Shahid Electronics
    Shahid Electronics Jul 10, 2010
    Thanks for model and brand info.
    It is lens mechanism problem in camera and lens loading motor got stuck for some reason. Please call Polaroid for warranty cover, phone number would be written on warranty documents of camera.
    Thanks.
My camera was on, it was low battery but was still using it, then it turned off and the lens was still open, and everything else. I Put it in charge and it still wont turn on and the lens wont close. Its...
ive got a vg 120/d-705 olympus digital camera.reg it to the computer.says leave it plugged in for 3 hours which i have done and no movement in the camera now.is it working or not or do i take it back to the shop where i bought it from.please help me.
Sep 01, 2011 | Olympus Software VG-120 Digital Camera
Dropped camera now lens wont close. It says lens
Remove the batteries and insert new batteries . Sometimes this may work but in your case the lens is stuck inside, or it will have been damaged . Nothing can be done other than taking to service center to get it repaired .
Hope this helps .
Dec 16, 2009 | Canon Cameras
My camera wont stay on even with new batteries
I Have The Same Exact Camera As You And Have lost of Experience With Digital Cameras I'm Guessing you just need digital camera compatible batteries (Rechargeable) Oh and keep in mind taking a picture requires a lot of energy use
Dec 30, 2008 | Polaroid i735 Digital Camera
Not turning on and has strange smell
Powershot A640 Could Not Be Powered On, Burnt Smell
My Powershot A640 died during a picture shot, lens remaining open. I thought it may be due to the dead batteries. But after putting new batteries and pushing the on/off button, the on/off indicator blinked once then shut off by itself. After a while, a strange smell came from camera batteries area, and I could feel warm there too. Immediately I took out all the batteries from camera.
When checking the posts here the other day, I tried one solution and got the lens back to close: first took out the memory card from camera, then put the new batteries in; push the on/off button with no memory card. I found the lens retracted a little before camera shut off by itself. I pushed on/off button three times to get the lens fully close. However, the burnt smell came out again. I immediately took out the batteries.
Did I get a short circuit inside? Is there any ways to fix it?
Oct 31, 2008 | Cameras
KODAK Z1275
I semi resolved the problem with my Kodak Z1275 with this suggestion; Step 1, making SURE the batteries are good. Then, position the camera with the lens pointed up or down (depending on stuck lens position, USE GRAVITY AS YOUR FRIEND) and gently tap on the lens just as you turn on/off the camera. You may have to do this several times before the camera will close the lens. From my research this camera has a faulty mechanism for the lens which causes the software to recognize a lens failure thus shutting down the camera. Poor designed lens mechanism! I now am using my camera again, but regularly have to remember to allow gravity to assist in lens opening (turning on) and lens closing (turning off) as well as occasionally giving it a light tap or in extreme cases lightly assisting the lens opening/closing. Hope that helps! Oh and I don't suggest buying another Kodak camera!
Sep 15, 2008 | Kodak EasyShare Z1275 Digital Camera
Fuji F10 No power
You said that you changed the battery, did you put it in the right way around?.
I had exactly the same trouble, changed the battery (got it on ebay for £2.99) charged it and it worked.
Having said that, I closed the lense from external power. If the camera wont operate from external power then the camera is probably dead.
Sep 13, 2008 | Fuji FinePix F10 Digital Camera
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Dimagez3 Battery Options
Hey bray598,
According to the manufacturer this camera comes with AA alkaline batteries so unless you bought defective batteries the ones you purchased should work fine. I would make sure the batteries are inserted properly, and make sure when you turn it on the battery cover and/or the memory card cover are closed. I hope this helps.
Sincerely,
Allan
Go Ahead. Use Us.
May 16, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
Camera wobn't turn on & lens stuck in out position
My camera stopped working during a wedding. The lens is stuch out, it will power on, but right after turning on, it beeps 3 times, then turns off.
Hope we find a solution!
May 14, 2008 | Samsung Digimax A7 Digital Camera
The lens doesnt close and when i turn the camera on it bips three times and the screan shuts off. the lens wont close.
The batteries need to be changed. The digital batteries sold at the stores die out too fast. I had this same problem. In result, I purchased rechargeable battieries.
Nov 19, 2006 | Samsung Digimax S500 Digital Camera
Cameras Logo
16 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
