Question about HP Televison & Video
HP lc326on 32'' hd tv. Can't get the sound up. Have to keep it at 50, both TV and Direct TV Box. Are my speakers just bad?
SOURCE: remote code
I have a Polaroid 32" LCD flatscreen.
11250 worked for me.
--Wayne
Posted on Jan 25, 2008
SOURCE: Emerson LC320EM81 32
i cut the tv on and then it cuts its self off.
Posted on Oct 14, 2008
SOURCE: i have hd picture but no sound, tv says hdmi audio unavailable
I called Verizon and exchanged my STB from a QIP 6416 to a QIP 7216 and it solved the HDMI audio problem. This looks like the fix.
Posted on May 13, 2009
  • 8457 Answers
SOURCE: Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Posted on Apr 07, 2010
SOURCE: samsung 50" plasma tv with no picture but has sound.
I just had a similar issue with my 46" Samsung LCD and fixed it myself for $5.11! I realize we have different tvs, but I bet it is the same issue ... crapped out capacitors.
I researched the problem online and most places, like samsung's site, referred me to call a repairman and called for the whole control panel or power supply to be replaced for anywhere between $400-$1000. I was like ... "screw that" ... I refuse to put in a fautly part in the place of a faulty part. So I continued to research.
That's when I stumbled on youtube. There are many how to videos on how to tackle this daunting task. I read that the issue was more than likely faulty capacitors and there is a very easy way to tell if it is in fact the capacitors that are blown. instead of having a flat top, faulty capacitors are crowned or even ruptured! When I opened up my TV I saw 3 blown capacitors!
So I bought 3 new capacitors all with the same uf and higher volts ... I think all three of my capacitors were 1000 uf and 25 volts. I kept the uf the same (recommended) and raised the voltage to 35 volts. It doesn't mean more volts, it just means it COULD handle more volts if it had to (which was the problem those cheap Samsung bastards screwed up on). This is a very common problem with Samsung TVs.
Anyway, I have never soldered before, but I did it. I warmed up the solder on the bad capacitors and removed them them slid thenew ones in and soldered them in and popped everything back together ... and PRESTO .... the damn thing works better than ever!
3 capacitors= $5.11
1 solder gun and solder= about $18
fixing an incredibly intimidating TV by yourself= PRICELESS!
Seriously ... don't be afraid to F up ... check it out on youtube and other place and save yourself a bundle. Source(s): I just fixed my TV!!!!!!!!
Posted on Mar 17, 2011
Purchased iLive Bluetooth HD soundbar 32", hooked up to TV and makes noise when on a HD channel, Samsung tv
iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat ...
www.amazon.com/iLive...Bluetooth-Sound-Bar/.../B0...
Amazon.com, Inc.
Rating: 3.7 - ‎6 reviews
iLive HD Bluetooth Wireless Soundbar Speaker TV Stand For 20-55" Flat Panel HDTV's Up ... when you purchase $5.00 or more of Qualifying Items offered by D.R. Worth and Sons. ... The iLive Bluetooth HD Sound Bar for 22 - 50 Inch Flat Panel TVs is cleverly designed to ... Click here to make a request to customer service.
Amazon.com, Inc.iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat Panel Televisions ...Bought another for a relative. ... **2 things to NOTE: 1-make sure there is nothing aside from your tv on top of the speaker to avoid rattling, which i mistook for distortion/blown speaker at .... It sounds much better than the Samsung internal speakers.
How to Connect Soundbar to TV ' Audiogurus Store
www.audiogurus.com > Learn: Home > Displays
Dec 29, 2015 | Samsung Televison & Video
How do i hook up craig surround sound mode cht904
Are you using your TV for both Audio and video? Sounds like you are only wanting HD video and SS audio. If, so only send HD video signal to TV and keep SS Audio direct to speakers from SS receiver/ amp.
Jan 01, 2015 | LG Audio Players & Recorders
On my Zenith z50p3 plasma tv, I have picture , but the sound is scratchy, I have to raise the volume to 40 before I hear something,and then it is very irratic. Some say it's the sound amplifier. D
First check all your wiring with it turned on wiggle the connections and you mite find you have a dodgey plug somewhere or a break in the wiring
Dec 14, 2017 | Zenith Z50P3 50 in. Plasma TV
I have a luxor 32" lcd tv and i cant get my surrond sound speakers to work. how do i do this?
Hi well surround sound speakers require an "Interconnection" box, that is a box with Jacks that the Red & White stereo audio plug into, on one side, and the 3 SS speakers plug into the "Other side" as it were. Usually with SS we have a Rear, Front and Sub Woofer, as this means 3 sets of speakers must mate with the 2 outputs from the TV etc. So the "Line Out" stereo output from the TV, which are usually the Red & White, is the output to the interconnection box, from there it feeds into the SS decoder, some plug directly into the decoder itself, and don't use an interconnect box, but it's all the same in the end. The stereo output is fed into the SS decoder, and then SS signal is extracted from the sign in, and routed out to the appropriate speakers.
Oct 21, 2011 | Samsung LE32R73BD 32 in. HD-Ready LCD...
I have picture but no sound. We just had our surround sound system go out and are trying to run our tv on it's own internal speaker system. How do you hook it to our direct tv hd box
Hi.
You need to use audio cables. Connect two red and white audio cables from the output on the HD box to the relative input at the back of TV (nr.4 in picture below). The best way to connect the HD box is by using component cables, that are the red-green and blue trio of cables, plus a white and red audio cables.
Here what you need:
Three plus two:
Component Video Cable
Audio Red / White Cable
or single set of five:
Cables Unlimited - Video / audio cable
Once you have the five cables, connect them to the output at the back of the Direct TV box, and then connect the other end of the cable to either group of connectors 6, or to one of the columns in connector 7. Do connection with box and TV power off. After re-applying power use the source-input selector on remote to select the source from Direct TV box.
May 24, 2011 | Samsung HCM4215W 42" Rear Projection...
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
Hdmi plugged in to tv and hp G70 laptop. Picture showing up on both as expected, plus cable works just fine. however, sound is not played thru the tv. It has before.
right click the speaker icon on the botton right hand side, click playback devices and then in the box that appears click the hdmi sound output and then click set to defult
Oct 05, 2010 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Popping noise through speaker when changing channel on sky hd
What make is your HD Box and TV? Assume you are connecting direct to your TV using HDMI, and not though an amp? If you do have an amp, you'll need an optical from HD box to amp to get DD 5.1, and connect your HD box to TV with the HDMI. Have you disconnected any scart connections from the HD box to TV - no longer required unless you really want to watch SD over the scart? Check that the Audio Output in the Sound settings for you HD box is set to Stereo.
Does your TV have individual audio and picture settings for the input source - perhaps you need to tweak these for the HDMI input being used. Do you have another HDMI cable you can use to eliminate a possible dud?
Mar 18, 2010 | Sony HT-DDWG700 Theater System
Speakers not working
I have a wharfedale 32 HD Ready didital LCD TV and the headphone socket does not seem to work...have used four working headphones that work on Ipods and Hi Fi but they do not work on TV is this a tv fault or do I need a mono small jack on headphone ?
Dec 01, 2009 | Televison & Video
No sound
No sound on any input from TV, DVD, DIRECT TV?
Try using the powered PC speakers attach to the Auido line out RCA jacks to see if you get any sound to narrow it down to find out if the problema are in the preamp or power amp sections.
Oct 31, 2009 | Digital Lifestyle s LT32323 LCD TV
Televison & Video Logo
73 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
vbalag
Level 1 Expert
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
