Question about Canon PIXMA MP600 all-In-One InkJet Printer
Says it cannot recognize the magenta cartridge. I have cleaned contact points, installed up-to-date drivers, and followed directions to reset. It will not print at all. If I remove magenta and replace and turn printer off and on, it will SOMETIMES print a few pages before stopping again. I am ready to buy a new printer! But I read that Canon is supposed to be the most reliable, so I am not sure what to do.
  • 10,421 Answers
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
Keep Getting Error Message "(Colour) Toner Not Installed"
I think in the menu you have to select replace cartride.. then new or same with new toner...
each toner cartridge has connections and you must make sure all are tight... or you get alot of errors.
Sep 10, 2008 | Konica Minolta magicolor 2300DL Laser...
I have replaced the toner but am still getting the replace toner message.
My message error was sepcific for magenta after I removed it to refill it. After refilling, cleaning metal contact points, resetting the metal tab which prevents message of "low toner", I put the cartridge back in and received the "magenta toner not installed" message. I turned off the printer (safety first!) , I then pushed the button left of the hole where you slide the cartridge in, There is a squarish hole with a circular or cynlinder shaped button in that squarish hole. Use a small screw driver to push and hold it in. While the button is held in I gently rotated the cartridges so that my magenta cartridge was no longer in view, (rotate them counter clockwise). I released the button, shut the door, then turned on the printer.
Sep 09, 2008 | Konica Minolta magicolor 2300DL Laser...
U150 canon pixma MP830 "the following inktank can not be recognized" magenta. Please help, Thanks, Ted
I have had this problem repeatedly lately. To try the Stop/Reset solution already mentioned, I turned on my infrequently used Canon Pixma MP830. Most of the time at a fresh startup it gives an alarm message "the following ink tank cannot be recognized" OR "there are two of the following ink tanks installed" ??! for the single black 8 cartridge !, a Canon original. Of course, tonight it started just fine, but the methods I have used when it does not work because of these alarms are the following:
I open the top, wait for the cartridge carrier to center, unsnap the black 8 cartridge, then snap it back in and close the top. This sometimes works if repeated until the machine recognizes it. Sometimes I unsnap all the cartridges and resnap them. If this doesn't work, I remove the black 8 entirely and use a clean cloth to wipe the electrical contacts of the cartridge in the direction of their length and reinstall. It sometimes takes a repeated combination of these steps and sometimes the two different alarm messages will appear alternately. There does not appear to be any logic to it. Once the machine does recognize it, it works just fine.
However, if the machine is turned off, many times when it is turned back on later I have to go through all this frustrating rigamarole again. I hope it is a glitch with this particular cartridge (fairly new) and not the machine. Next time I get the alarm messages I will definitely first try the Stop/Reset button solution suggestion, but I thought I'd add my two cents solution, which so far has eventually caused the machine to recognize the cartridge.
May 22, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Ink cartridge
clean the contacts of the inkcartridge chip e.g. with spirit
or
Press the reset/stop-button for >10s to quit the error ... but be aware that the ink level will no longer shown correctly
May 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Printing blank pages
Blank Pages Printed
Remove the protective tape from the cartridges:
With the printer power on, open the front cover of the printer. The cartridge carrier should move to the middle.
Remove the cartridge(s) from the printer.
Look on the underside of the cartridge(s). If there is yellow tape and/or transparent blue tape there, remove it.
Clean the cartridge nozzles:
Go to the Lexmark Control Program or Solution Center and run the Clean print nozzle test.
If a black cartridge is installed, you should see black lines only.
If the color cartridge is installed, you should see yellow, magenta (a reddish purple), and cyan (a dark sky blue) lines.
If a photo cartridge is installed, you may see different colors.
Examine the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right, with no gaps.
If there are gaps in the lines, you could run the Clean Print Nozzle page a few more times to try and clear it up or try the "wicking" procedure below to conserve ink.
If the page is faded from left to right and the wicking procedure doesn't clear it up, your cartridge is probably out of ink.
Clean ("wick") the cartridges:
Remove your cartridges following the instructions in your User's Guide.
Take a warm, damp paper towel and fold it so that it has about 4- to 6-ply thickness.
Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are touching the towel, and hold the cartridge in this position for about 15 seconds. The nozzles are where the ink comes out of the cartridge.
Now drag the cartridge lightly across the paper towel in one direction only (left to right) until the bottom of the cartridge looks clean.
Turn the cartridge over so that you can see the bar code sticker on the back. Note: Only perform steps 6 and 7 if the contacts look dirty or corroded.
Using a clean pencil eraser, clean the contact points on the copper strip (only the little squares just below the bar code). Caution! Do not use the eraser on the nozzles that were cleaned, as this will damage the cartridge.
Using a clean part of your dry paper towel, wipe the eraser dust off the contacts; ensure that they are dry, and snap the cartridge back into the printer.
Make sure to install the cartridges following the instructions in your User's Guide, selecting Old Cartridge. Failure to do so could reset your ink levels as explained above.
Repeat the nozzle cleaning procedure one more time. At this point the diagonal lines should be solid.
If they are not and you think the cartridges should have ink in them, contact our technicians by e-mail and let them know the results of this test.
Reset the ink levels:
Lexmark printer cartridges do not have ink sensors. The levels of ink are produced by a mathematical calculation of ink drops and page counts. The printer stores this information and then writes it to the win.ini file on your computer.
Ink levels can be reset by telling the printer you have installed a new ink cartridge or by reinstalling the printer drivers and selecting Cartridges Installed. Once ink levels have been reset, there is no way to change them except by printing.
Accordingly, even if your computer says that your ink is full for a particular cartridge, it may be incorrect and the cartridge may need to be replaced. You may want to try a new cartridge to see if that clears up any print quality problems.
Mar 13, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
HP Business Inkjet 1000 error detecting new cartridge
Disconnect the communication cable (USB?).
Turn off the printer, wait one minute then turn it back on,
Then press the left button on the panel, the transparent one to the left of power button. It will print a status page. Check the dates and information under each color that is failing.
The ink cartridges MAY be outdated. Printing the test and information page without the computer connected fools the machine since it can't get your computer date.
If the cartridges are outdated, then change your computer year back to 2005 or so, reconnect the printer cable and send something to print, once the printer prints it out, reset your computer to today's year.
You will need to do this procedure whenever you turns off the printer. (Disconnect cable, change computer year, print, reset computer date).
Hope this works.
Wagner
Feb 20, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Epson R1800 printer won't recognize new ink cartridge
You can remove magenta & double check that some tape was not left behind on the contacts. Take a clean ragg & dampen it with alcohol. Clean the ink cartridge's (copper contacts & inside the the ink carrige). Re-install the magenta, (tight fit). Power off the printer. Wait a few seconds & power it back up. If it fails a second time with no other errors. Like the above. Than the magenta may be defective. Have a recipt? Return it for a replacment.
Feb 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
New Magenta Ink is not recognized after installed
Hi, it sounds that the issue can be caused by a defective ink cartridge that installed or a printhead that can recognize magenta ink cartridge. To identify which causes this issue please try the following:
1. Reseat ink cartridge
2. Replace ink cartridge with a specified ink cartridge for your printer.
3. If above steps wont resolved that issue, please call your printer manufacture and ask for service referral or process warranty options.
Tirzo
Oct 21, 2007 | Epson Stylus CX6000 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
old marine
old marine
