Question about E-Machines M6810 Notebook
How do I replace the CMOS battery on an emachines m6810 laptop? Where does the battery go?
4 Suggested Answers
  • 140 Answers
SOURCE: Replace CMOS battery
First you need to take the cover off your laptop and locate the cmos battery which looks like an oversize battery watch. With everything unplugged it just pulls out, note which side of the battery goes however. Place the new one in put everything back together and power the computer up. When it powers up it will finally get to the screen that says press "F1" for setup or "F2" to continue. Press F1 and you will get to your set up screen. You can go through each screen and select F5 which is the default factory settings or scoll across the top to the last screen which will give you the option of resetting all the settings to factory default with just pressing one of the F keys once only. Once you do that, just shutdown your computer and restart and it will start as normal. It may go through the F1 and F2 screen one more time but just press F2 and continue. After you log off the next time all your changes should be good. Let me know if I can help you in any other way.
Posted on Feb 09, 2009
sandrew
  • 2961 Answers
SOURCE: CMOS replacement for ASUS d1
It's difficult to say but you will need to remove the underside screws and also maybe even the keyboard as it's often attached to the base. The cmos battery could also be behind the screen. Comment by sandrew, posted on Nov 12, 2006 I'm sorry but I dont have any personal experiences with your particular laptop, but the lcd's are generally held in with 1 screw in each corner normally covered by a rubber bung hiding the screws, I would be very carefull not to disconnect any wires behind the screen, if yor not sure take it to a qualified repairer. You will probably have to remove the top panel just below the hinges as they may be held in underneath
Posted on Nov 13, 2006
gripfitter
  • 557 Answers
SOURCE: emachine m6810 how do I open the case need to
Pretty much the entire laptop needs to be disassembled. All screws removed from the bottom. The keyboard removed. The hard drive and the cd drive. You will have to separate the besel from the screen to remove the hindges. Unplug the lcd and wireless if you have it. That plug is attached to the motherboard which is a double sided board and the connections are on the bottom. The motherboard needs to be removed to repair the connection.
Posted on Nov 29, 2009
Inside I smell something burning and my power port is loose.
Your Notebook PC needs a new power supply or at least a new power port, or it may self-destruct really soon (like tonight). Unplug your PC and quickly backup your important data to a flash drive.
I wouldn't plug anything into the power port until it gets service, and unplug it overnight (or there could be a fire).
The owners' manual doesn't describe power supply replacement:
http://support.gateway.com/emachines/Mobile/eMachines/M2350/M2xxx_030804.pdf
Here's a picture of the bottom of the system:
http://support.gateway.com/emachines/Mobile/eMachines/M6810/M6810bv.shtml
Jan 17, 2011 | E-Machines M2352 Notebook
I have an emachines m6810, powers off when the fan turns on.
check that your fan is not defective and drawing to much current, check the fan driver transistors base is not shorted to ground
Jan 20, 2010 | Computers & Internet
Emachine m6810 how do I open the case need to replace or soldier the dc input connector. Unit will not charge although charger is operational. check w voltmeter
Nov 29, 2009 | E-Machines M6810 Notebook
How do i install memory in my emachine m2105
the maximum memory allotted that machine is 1.2 gigs and to do so you open the bottom memory door ans slide out the slot card and reinsert the new one
Aug 29, 2009 | E-Machines 1024MB Memory Upgrade for...
How do you remove the cd/dvd rom in a emachine m6810
This is not an easy task, but first unsnap the the swivel cover just beneath the lcd screen. unscrew the keyboard securing screws and carefully lift out the keyboard ans separate the tape cable, now look and locate the securing screw for your dvd rom and just slide it out. Installation is in reverse. Please use caution as not to damage the internal parts and connections. Good Luck
Fehdi
Aug 19, 2009 | E-Machines M6810 Notebook
Screen
This model has a 15.4" screen. The maximum setting is 1280 X 800 according to the specs. Suggest to try this one.
Aug 11, 2008 | E-Machines eMachines M5305DP Notebook
E-Machines M6810 Notebook Logo
4,252 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
