Question about Microsoft Windows XP Professional SP2
I have a XP desktop computer with SP3 upgrade. I want to replace the small IDE hard drive with an SATA 1GB drive. I can connect both drives to the motherboard. What is the easiest way to transfer the operating system and files from the IDE drive to the SATA drive before removing the IDE drive? Thanks, budhennessy@wildblue.net
  • 428 Answers
Well you can backup the system simply with the system state. However some files will be ignored. So what you have to do is to "Clone" the disk. That is the easiest way. Most of the Disk Cloning Software are commercial and not for free. But there are a few. You can use this product. This runs on Windows (win32). XX CLONE.
Download and install it. It has a Graphical User Interface with the necessary options. The image is bootable by default. It is fairly easy to get used with. Just plugin the HDD and back it up. Make sure you properly set the SATA as a slave. These settings can be accessed via boot options in BIOS. Use del,esc,F2 or F11 to jump in to BIOS settings before the system boots Windows. Hope you know the procedure. (Otherwise the System will be boot using the SATA drive instead of the IDE drive). Online manual for XXCLONE.
If you have any commercial product such as Norton Ghost or Acronis True Image you can use with a hassle. They are ideal for disk imaging. You have to purchase a key how ever. If you use a torrent downloader such as Utorrent, you can download with a key. But you cannot Register the key since they are used keys. So if you like to do that (we do not enforce piracy) download and use one of them. They are user friendly software and easy to coop with.
If you have any questions please feel free to ask. Please rate the answer if it helps you to solve the issue.
Thanks for contacting Fixya!
Posted on Jul 10, 2010
How do I find my folders with multiple file types (stored on a second Drive E:) using XP SP3, now that I boot from a different C: drive?
Have you checked to see if these hardrives have a jumper on master or slave? It's a small white or black piece that connects two pins in the hard drive. Sata drives won't have pins or jumpers
also consider plugging the drive into an IDE to USB cable and plug into a system with a different operating system. Or look up a program called r studio. it's one of the better file recovery software out there. It also recovers in "original file/older structure" which you are trying to do.
is your machine using sata drives or older IDE drives?
Jul 01, 2014 | Computers & Internet
Sata drivers xp
For any Panasonic Toughbook built after the year 2005,
if the Toughbook uses a SATA hard drive instead of an
IDE hard drive, then you will need to use Windows XP SP3
(Service Pack 3) instead of XP SP2 (Service Pack 2).
The XP installation CD for SP3 automatically includes
SATA drivers and you do not need any extra drivers.
That is it. Good Luck and Best Regards from:
Richard, Montreal Based Panasonic Canada Authorized
Toughbook Dealer since 1989.
Jan 22, 2014 | Panasonic Toughbook CF-30 Notebook
When i installing windows xp sp3 show no hard disk found
If your laptop is installed with a SATA hard disk then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 25, 2012 | Computers & Internet
What type or brand of hard drive do I have to get to install in Acer AM5641 Desktop ? I want to upgrade to a 1 tb hd.
You currently have a 320GB 7200-rpm SATA II hard drive, with 8MB cache install on a base package of your make and model of computer. I would recommend a hard drive like Samsung Spinpoint F4EG 2 TB Internal hard drive. You can find it roughly for $70.00 - $90.00 at online stores like amazon, new egg, etc.
I hope this helps.
Jun 30, 2011 | Acer AM5641-B5660A Desktop PC & Monitor...
Can I install a hard drive in an HP Pavilion 6736 which has a capacity greater than 20GB ? If so, is there an upper limit to the capacity..can I install a 120 GB drive?
The size is not an issue with the hardware normally. Usually it has to do with the operating system. If you are running an OS like windows xp you should have no problem.
Just make sure you are using the SAME type interface hard drive. Example PATA Parallel ATA, or Serial ATA (SATA).
May 04, 2010 | HP Pavilion 6736 PC Desktop
How can I upgrade my e-tower 366is hard drive ?
Of course you can up grade it. Just be sure to get the drive with the correct connections to it. It can be SATA connections which are 2 small plugs in the back of the hard drive that are about 1" to 1 1/2" wide. The other connection would be IDE, it will be about 3 /1/2" wide with another connection that will a 4 pin Molex power plug.
Jan 25, 2010 | E-Machines etower 366is PC Desktop
WD Caviar SE16 WD3200AAKS 320GB 7200 not recognized at install
Windows XP does not have built in SATA drivers. You will need to download the XP drivers from Western Digital's website and install before the computer will allow you to format and use your new drive. Hope this helps.
Jul 18, 2009 | Western Digital (WD3200JS) 320 GB Hard...
I would like to change my hard drive
If you are looking to save just a "small" bit of $ .. 2 - 1GB sticks should be cheaper .. but what is the current configuration . is it 1 - 1GB or 2 - 512MB or 4 - 256MB?
You have the option of IDE or SATA drive so either is an option .. You may want to get a drive copy utility and just "clone/ghost" your current to the new drive and then swap it to master and GO
Dec 26, 2008 | Dell Dimension 4600 PC Desktop
Connecting new hard drive
If the old one is still conected you can connect it the same way if not here is how to::
Well firstly they are 2 types IDE (large connector) and SATA (small connector)
IDE
of an ide cable has 3 jacks 1 for the main board and 2 for IDE drives
2 drive must be set to master and the other to slave
Set the drives by using the jumper on the back the instructions are written on the drives
Connect the Ide Cable and then the power and turn you system on
IF ITS SATA
connect the sata cable to both hard drive and main board
connect the power cable and your done!!
NB:: sata ports are labeled SATA 1 SATA 2 etc
IDE are LABELED IDE 1 IDE 2
Ide is a large grey cable black connector SATA is usually orange or red and small
Oct 26, 2008 | Gateway (M520HD80G) Hard Drive
Install sata drives on abit av8 motherboard (vista home)
Right click on my computer, click on manage. Then on Disk Management. See if the drive shows up . If it does you can format it by right clicking and select format.
Sep 28, 2008 | HP xw4600 Workstation Linux Installer...
Microsoft Windows XP Professional SP2 Logo
64 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
