Question about Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop
When I light 3 of the 4 burners, the clicking sound (like it's trying to ignite) keeps going for at least a minute or so...but there's no problem lighting the burners. Is there an easy fix (maybe a new part to stop this from happening?
  • Jenn-Air Master
  • 43,501 Answers
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 18, 2010
My gas cooktop is contiuing a clicking sound to start the gas burner. it is not the color of the flame or that stuff. Just the starter keeps trying to start. the gas burner that is all. Blair
Hello Blair
Does the clicking or spark stop with all knobs in off position? If so it's probably the one burner valve for the one you're trying to light ,stuck in light mode,sending signal to module.Have that burner valve replaced.($50). (2) If clicking continues even though everything is off, it could be any one of the burner valves or your ignition module is messed up .You would have to pull wire off each burner valve one by one to find the offending valve . If not valves then suspect ignition module.
Easily fixed either way.
Feedback appreciated !
Aug 03, 2011 | GE Cooktops
Gas stove tops: After 3-4 minutes of the gas being on for one or more burners, all of the ignitors keep on attempting to spark. They keep going even after the gas has been turned off and stop after 5 or...
Hi abbilou_78,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 30, 2011 | Whirlpool Cooktops
On our 6 burner gas coocktop, the right two burners don't light
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
How do you replace the ignition module on stove.
heatman101
Apr 14, 2010 | Viking Professional VGRT362-4G 36 in. Gas...
Jen-Air Gas range Igniter keeps clicking but not starting fire
01/26/09 My wife decided to give our Jenn-Air a good cleaning. With lot's of soapy warm water she pulled the knobs off and washed under each of them not realizing excess water was now running down the inside of each control knob shaft. The igniter immediately began clicking away as it was being shorted by the conductance of the water now inside of the switch. I had to remove the cover (2-screws) to access the control switches but that is all I needed to do do in order to have clear access. Using her hair dryer it took about 5 minutes of warm air blowing down each of the shafts until the water evaporated and the clicking stopped. Wahla. The old Jenn-Air is back to working order again.
Sep 22, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Igniter issue - some do not turn on other do not turn off
I would try cleaning the burners. You can purchase cleaning brushes made specifically for this purpose and they work like a charm.
Sep 25, 2007 | Thermador PC366BS Stainless Steel Gas...
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
Dacor gas range igniter clicking
I did have the same problem after the house keeping people done with cleaning. They used window/surface cleaner. First I asked them not to clean the ignitor with any cleaner. Here is what I did to solve the problem
I took scotch scour pad (one that you use for washing dishes), In dry state I polished ignitor switch. It is abrading the residuals and deposits on the top and polishing it. Don't use any thing more abrasive than that. MAGIC - I don't have any more problem.
Aug 14, 2007 | Dacor Preference SGM365SS Gas Cooktop
Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop Logo
172 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
