Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Keep getting a message "The following ink cartridges appear to be missing or damaged" after replacing the cartridge several times
  • jpallen Jul 09, 2010
    Keep getting a message "The following ink cartridges appear to be missing or damaged" after replacing the cartridge several times. The printer is frozen and does not print
  • 10,515 Answers
Did you installed cartridges those are hp branded or not...?
Please checkout once again installation is correct or not...?
If so... You just follow the below instructions.
Performing a power reset.
1.Press the On button to turn off the HP All-in-One.
2.Unplug the power cord from the back of the HP All-in-One.
3.Unplug the power adapter from the wall outlet and wait for 30 seconds.
4.Plug the power adapter back into the wall outlet.
5.Plug the power cord to the back of the HP All-in-One.
6.Press the On button to turn on the HP All-in-One.
Try cleaning the cartridge contacts as one last attempt.
1. Make sure the HP All-in-One is turned on.
2. Lift the ink cartridge door.
3. Squeeze the bottom of the latch below the ink cartridge you want to clean, and then lift the latch.
NOTE: Do not remove multiple ink cartridges at the same time. Remove and clean each ink cartridge one at a time. Do not leave an ink cartridge outside the HP All-in-One for more than 30 minutes.
4. Remove the ink cartridge.
5. Inspect the ink cartridge contacts for ink and debris buildup.
6. Dip a clean foam rubber swab or lint-free cloth into distilled water, and squeeze any excess water from it.
NOTE: Hold the ink cartridge by its handle. Do not touch the copper-colored contacts with your hands or anything other than a foam rubber swab or lint-free cloth.
7. Clean only the copper-colored contacts.
8. Place the ink cartridge back into the empty slot and press down on the gray latch until it clicks into place.
9. Repeat if necessary for the other ink cartridges.
10. Gently close the ink cartridge door.
NOTE: The printer may take up to 15 seconds to clear the error and recognize the cartridge after closing the cover.
If problem persists, you need to send the unit for repair.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 09, 2010
  • HP Master
  • 3,247 Answers
I am not sure if you have checked on the HP support website about this problem. I noticed that for some other HP printers, the recommedation from HP is to ignore the message if the printing is OK. But I cannot find your model listed specifcally when I checked the problem list
So if the printing is ok then you may have to ignore it, unless you might be using an incorrect cartridge. If printing is not ok then there may be a need to service the printer. Hope this helps.
    It does not print at all. Doesn't copy or accept faxes
2 Suggested Answers
professor_sc
  • 180 Answers
SOURCE: ink cartridge problem! The following ink cartridges appear to be missing or damaged.
Solution :
1. clean the ink cartridge contacts both in the printer and the cartridge with a lint free cloth or a cotton swab. and try inserting the ink cartridges again. if it wont work proceed to step 2.
2. unplug the power cord at the back of the printer
3. press and hold # and 3 keys at the same time and plug the power cord back in. Do not release the two keys. wait until the printer would say "partial nvram reset" or anything that says "reset". if this still would not resolve the problem
4. do the same process as 2 & 3 but instead of # and 3 try # and 6. instead of saying "partial nvram reset" it should say "semi-full nvram reset". and if it would not work better go to an onsite technician. but if your printer if brand new return it to the retailer and exchange it. but before you do that try calling HP technician they would instruct you to the things i have given you. Just tell them what you have had done and asked them to replace the ink cartridges. This are the informations the agent would ask you about the ink cartridge
part number and also the expiration date.
try to ask for a replacement first if it would not resolve it. then go to a technician. I could not assure you that a technician could fix it because i have troubleshoot this kind of problems and there are alot of printer parts that needs to be fixed. Usually i suggest my clients to buy a new printer instead
Posted on Mar 07, 2009
I have an HP Photosmart C5180.ink appears to be missing or damage
Hi there
Most times it just need a good clean ,take out and clean the brass conextions.
All the best Pineworks
Apr 27, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ink cartridge problem( s) appear to be missing or damaged
hi there,
Ink cartridge Problem
Cause : The indicated ink cartridge(s) are missing or are damaged.
Solution : Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-one, the ink cartridge contacts might need to be cleaned.
IF there is no ink cartridge missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge. Replace the ink cartridge.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Nov 26, 2009 | HP Photosmart C6280 Printer
Ink cartridge cannot be used after initialization
The following are common issues.
The following ink cartridges cannot be used after device initialization and must be replaced
Cause The wrong ink cartridge(s) are installed.
Solution The indicated ink cartridge(s) cannot be used after the device has undergone first time setup. Replace the ink cartridge(s) with the appropriate ink cartridges for the HP All-in-One. To find out the reorder number for all the ink cartridges that the HP All-in-One supports, see the printed documentation that came with the HP All-in-One.
If you are using compatible cartridges make sure they are reset for use.
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might need to be cleaned. If there are no ink cartridges missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge.
Sep 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Says cartridge cannot be used after initialization but brand new HP 363 cartridge sent directly by HP to me. This happens ever time I put a new cartridge in when prompted by printer to do so. Do I put new...
Sep 21, 2009 | HP Photosmart 3310 Printer
HP Photosmart 3110 All in One says ink cartdriges missing
Follow the instructions in this link.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00409514&prodTypeId=18972&prodSeriesId=3380537
May 18, 2009 | HP OfficeJet J4580 All-In-One Laser...
MFC-210C I changed the ink and keep getting a no cartridge message. I have reinstalled several times but I still get the same message.
Replace with old cartridge and if the problem still persists there has most likely been damage to the socket caused by replacing the cartridge. If the message does not exist with the old cartridge then there is something defective with the new cartridge.
Nov 17, 2008 | Brother Office Equipment & Supplies
Ink cartridge problem! The following ink cartridges appear to be missing or damaged.
hi!!!!
try to clean the nozzle of your cartridge with the alcohol
or solvent used cotton
or replace the cartridge
try to email me ronaldsuboc@gmail.com
Sep 18, 2008 | HP Photosmart C7280 Printer
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
