Question about ASUS A8N-E Socket 939/nForce4 Ultra/PCI-Express/Gigabit LAN Motherboard (MOTAS70)
I transfered my motherboard and other parts into a new box and now it wont turn on??
  • 484 Answers
First ensure that all your connections are correct, then you check for the power cord to see if it is properly connected and if on the inside it is connected to the mother board.
Ensure that all ribbons are properly connected and not damaged in any way, also see to it that the power cord is plugged to a power supply that can carry the system.
Take care
Posted on Jul 09, 2010
4 wheel drive wont lock in on my 99 jeep cherokee.is there vacuum
are you on pavement, or offroad.?
99 Cherokee what transfer case?
if Part time system. then,.
are your tires on ice or dirt?
if not its cockpit error.
read the operators guide, on this.
if on ICE,say so, we can not know what transfer case you have
nor what tires are sitting on.
do tell, and we can tell you what good or bad.
here is the build list for these years XJ
what do you have. ?
The full time box, must not be in 4Lo , on pavement
unless it too is on ice .
All the transfer cases used on the Cherokee were chain driven with aluminium housings. Command-Trac was standard on XJ models built with 4WD.
  • 1984-1987: New Process NP207 Command-Trac, part-time only, 2.61:1 ratio with low range
  • 1984-1986: New Process NP228/229 Selec-Trac, full- or part-time, 2.61:1 ratio with low range
NP228/229 has a vacuum switch for 2WD-4WD selection on the fly and a separate manual lever for low range
  • 1987-2001: New Process NP231 Command-Trac, part-time only, 2.72:1 ratio with low range
NP231 has the following settings: 2HI, 4HI, N, 4LO
  • 1987-2001: New Process NP242 Selec-Trac, full-time or part-time, 2.72:1 ratio with low range
NP242 has the following settings: 2HI, 4 full-time, 4 part-time, N, 4LO
never post questions on 4wd unless you know what is there.
the transfer case, also has tag , telling what it is.
Jan 07, 2017 | Jeep Cars & Trucks
4805 fan not working, the one on the inside. Everything else works.
the new fan that you installed is a good one,but it wont turn on, because there is no electric current into the fan
something is wrong with the motherboard, the motherboard control the electric current (to the fan)
the motherboard is needed to be checked and repaired
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 09, 2014 | InFocus ScreenPlay 4805 Multimedia...
Just bought a new msi main board today transfered all my stuff over onto it and all it does is NOthing wont load anything up.. can some1 help
You can't just transfer it - an old Windows is always incompatible with another new motherboard. The entire Windows will have to be at least Repaired, or much better, reinstalled.
Mar 07, 2011 | MSI G41M4L (890552669976) Motherboard
My computer will not power on, only a flashing green light on the back is on. I just bought a new computer and would like to transfer my files to my new computer. Why my old computer will not power on?...
Hi and welcome cj4man1 !
Extract the Hdd out of your old computer . Place it in a external usb box and connect the box to your new pc . You will be able to access and transfer your data .
The issue about your old computer is another matter an could have several reasons , such as power supply , damaged Hdd , defective memory , damaged motherboard ...etc ...
best regards ,
fanaudi .
Feb 20, 2011 | HP Pavilion a450n PC Desktop
My t2460 emachine won't power up the power box works it just won't turn on .
Emachines don't last long. Even though the power supply turns on it still could be bad.
It is probably the motherboard. Best to buy a new computer. Pull the hard drive from the old one and set it up as slave on the new PC so you can transfer all your old files.
Feb 24, 2010 | Computers & Internet
Eurovox Max 2008 wont turn off standby
Have you unplugged it from the wall?....if you have than I suggest that you install new software on it.
go to www.bigmaq.co.uk and download the tool bar, than go to files and fixex select your eurovox from the list and download software and install it onto your box.
Regards
Dec 08, 2008 | Computers & Internet
Comp not firing up
Something may be shorting out the board. Try taking the motherboard out and turning it on without the case. Just put the motherboard and power supply on a non-static surface. A box works well. Then use a flathead screw driver to temporary "jump" the 2 power switch pins for the front panel connection (as you wont be turning it on while inside the case).
If that doesnt work, then replace power supply. You could also take one out of another working computer just to test.
Jun 18, 2008 | EliteGroup K7VMM Motherboard
ASUS A8N-E Socket 939/nForce4 Ultra/PCI-Express/Gigabit LAN Motherboard (MOTAS70) Logo
29 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
