Question about Maytag 24 in. MDBH950AWS Built-in Dishwasher
Dishwasher starts and gets somewhat filled then starts making a high pitched screaming
  • 484 Answers
The reason the dishwasher gives the high pitch screaming is because there is some sort of system error in it.
Try to troubleshoot it from the procedure in the users manual, to detect the fault and fix it.
Take care
Posted on Jul 09, 2010
  • scottekilmer Aug 08, 2010
    our Maytag dishwasher did that too. there was a small piece of plastic caught in the trap. disasemble the lower arm and clean the traps out.
Gentle annie
The fill switch may have failed or the tube to it broke. Anyway, the machine probably is too full of water for it to start to spin out, so it slips on the belt and that makes noise.
The machine is going to be very heavy if it is overfull, but try to let some water out. Maybe you can just lower the drain hose way down into a bucket and get some water out of it. Once it's low enough, it may be able to pump out the rest. Then you can find out about the fill switch.
If it's not overfull, then some hose came loose or broke.
Nov 25, 2013 | Washing Machines
Squealing noise
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Here is Manual onlineManual online
Nov 04, 2013 | Baumatic Dishwashers
My disher washer is making a high pitched sound when I turn it on.
is this a new unit or old one? the high pitched sound is the pump some models make this sound every time they start up. it will make the sound when you start it up but then goes away. try this before you start it run the hot water in the sink let it get hot turn off the faucet then turn on the dishwasher.
Feb 24, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
High pitch scream after i260 scans a few pages. Scanning stops
the main board in that scanner is going bad which is why its making the high pitch sound. Time to get another scanner or call Kodak and get a replacement scanner or go back to the store where you got it from and get a new one.
Jan 23, 2010 | Kodak Office Equipment & Supplies
91 S-10 it has a high pitch scream
It sounds like a worn or loose fan belt. It's slipping on the pulleys causing the screeching noise.
Nov 22, 2009 | 1991 Chevrolet S-10
It makes a high pitched whine at about 62 mph
Vacume line off of transmission won't alow high gear and at that speed the tranny starts screaming for relief. Find the vucume line and make sure its good and connected at both ends
Nov 16, 2009 | 1991 Volvo 240
Screaming acer!
sometimes if the inverter board (the part that drives the backlight) has a cold solder joint on it, it can actually generate a high pitched resonating sound (aka a screaming squeal sound)
if it's under warranty, have the manufacturer correct the problem.
if not under warranty, retouch the solder points on the inverter board, or have a repair tech fix it for you.
Jun 03, 2008 | Acer AL1916W 19" LCD Monitor
Steam Button
Your iron pump is faulty the high pitched sound is normal.
Rdgs
Alan
Nov 27, 2007 | Rowenta Perfect Iron
Maytag 24 in. MDBH950AWS Built-in Dishwasher Logo
114 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
