Decks was working one nite, the next nite they stopped working! no power to both decks but power to the mixer!!
    Sergeant:
    Champion:
  • 319 Answers
Need more info -- what kind of decks. Check to see if "decks" are plugged into power strip. Check strip or AC mains to see if they are on.
Posted on Apr 19, 2008
My andrew james mixer has just stopped working any ideas was working one day next day nothing
The motor may have failed or the plug you are using has no power.
Oct 20, 2016 | Food Mixers
Its dell latitutde 6400 workrd last nite but cant get the screen
Debby, here is what you do; remove the battery. Next unplug the charger from the laptop. (Please make sure it is turned OFF FIRST)
Next, hold down the POWER BUTTON ON THE DELL LAPTOP for at least 30 seconds NON-STOP!!! After 30 seconds, let go of the button. Now, insert the charger ONLY and NOT the battery. If the Dell Logo comes on, problem SOLVED!!!! If not, repeat again.
Feb 27, 2014 | Dell Latitude E6400/ 6400 ATG Laptops /...
I want to hook my dex and a mixer into my motu 2408 mk2.. the mixer is working coz i can hear the mic,, but theres no sound getting into the computer from the decks.. ive even tried hooking the decks
Have you installed the driver for it? Look for the DVD that came with it and install it. After installing the driver, update it. You can use RadarSync to automate the updating process of your computer.
David
Apr 19, 2013 | Computers & Internet
CDJ-800 Mk1 No sound output!!!
Not true! CD channels don't require a pre-amp and the cartridge for a turntable does. I suspect that when the power went off the mixer was still on, so that when power was restored it came back on. However this resulted in a surge inside the unit. Magnetic cartridge pre-amps are often very sensitive to this kind of thing and will sometimes fail, while everything else works fine. This would result in no sound from the record decks, but sound from CD players etc.
Apr 13, 2013 | Pioneer CDJ-800 Turntable
Midi problem
i think this problem is related with the power of the mixer, see the guide of that mixer and learn how to connect it on right way.
good luck
Feb 17, 2013 | Computers & Internet
NO SOUND... I have the turntables connected correctly to the mixer, but when I power everything up and put the stylus on the record, all I hear is the music directly from the stylus. I checked the...
hello put deck 1 into L1 on the mixer deck 2 to L2 on the mixer .red and white 1 from master on the mixer to red and white on amp /stereo i hope it helps
regards
shaun
Feb 17, 2010 | Numark TT1510 Turntable
Cdj will not play through mixer in stereo, mono only. Cables have been swapped from good deck to bad deck and problem still exists ,and deck has been swapped to the other side of mixer master channel to...
is your mixer switched to line and not phono some mixer have a switch at the back for the phono chanels, I dont mean the ones on to for to select what input you want,
its usualy a small slider switch next to the rca's sockets at the back
Jan 11, 2010 | Pioneer CDJ-1000 CD Player
Need to record from turntables to cassette deck.
Bypass the reciever. Just mixer to tape deck. You will get a better recording anyways!
Apr 13, 2009 | JVC Audio Players & Recorders
I need to reset the system of numark idj2
Latest firmware / Librarian version? I've seen this happening on my ownIDJ2 when using older versions than 1.09(a).
If using old USB devices, transfer rates could have impact. Try an new USB device, defragged if possible.
Could be that you have a problem with the library. Try a rebuild...
Regards,
Jack,
Jan 12, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Humming noise/ feedback
your mixer should be grounded by the power cord, and the decks have a seperate ground wire which connects, usually on a screw terminal, to the mixer, which provides the ground for the decks. I would try the headshells to make sure they are tight and connected correctly also make sure the power socket on the wall is earthed properly.
Feb 19, 2008 | Stanton STR8-150 Turntable
 Grubhead
Grubhead
