Question about Ryobi Garden
I purchase a ryobi universal pro cut ii string head and i'm haveing difficulty installing the new head. can you help me?
4 Suggested Answers
  • 115 Answers
SOURCE: Replacing the cutting head on Ryobi string trimmer.
There is a nut above the head, place a wrench on the nut then unscrew the head from the shaft, unless yours is different from mine this is how it works. I hope this helps.
Posted on Jul 06, 2009
SOURCE: ryobi weed trimmer
I have one of this trimmers. It is simple to replace the line.
-First line up the arrows on the bottom of the spindle.
-Then feed the line back in one of the holes in the side of the spindle (this is the same hole that the cutting string comes out of).
-You will see the line come out of the bottom of the spindle.
-Take that line a place it in the hole on the bottom of the spindle.
-Leave about 9 feet of string hanging out of the weed eater (do the same with the other side).
-Then turn the inside wheel (I can't remember if it is clock wise or counter clock-wise but it will only turn one way) most of the string is rolled into the spindle.
-Cut the string of about 5 inches out of the weed eater. You're ready to cut!
Posted on May 31, 2008
joeguest2
  • 2080 Answers
SOURCE: The cutting blade on our Black and Decker GrassHog
Here is a link to the Black and Decker Support page for your machine where you can see an exploded view parts diagram and parts list (see item #27 on diagram and list):
http://servicenet.blackanddecker.com/Products/Detail?isId=true&productNumber=GH1000&selectedType=14365
And here is a direct link to the online ordering page with an image of the blade screw that you need (part number 681914-00):
http://servicenet.blackanddecker.com/Parts/Detail/31899
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
If you are not in a hurry for the item, you can order it online from Black and Decker, or pick it up from a local B&D or Dewalt service center. However if you want to just grab one from your local hardware store, the screw shown in the image above certainly appears to have SHEET METAL SCREW threads rather than machine screw threads. If you just print off an image of the screw from the webpage and take it in with you then the staff will probably be able to match it up with one in stock.
http://www.ereplacementparts.com/screw-p-103566.html
Good luck.
Joe.
Posted on Sep 03, 2011
Remove ryobi S430 trimmer head
it has a left hand thread which means that to unscrew it you have to turn it in a clockwise direction like putting a nut on a bolt
Jul 02, 2016 | Ryobi Garden
Need new bump head or full bump and feed unit
You can find some string heads and string head parts for your machine at Home Depot. They have a universal type head and heads made especially for Ryobis and Homelites (I think). Otherwise, several online vendors sell parts for your machine (but you have to pay shipping).
Jul 23, 2011 | Homelite Mighty Lite Lawn Trimmer
Cutting string is stuck inside head
The head will have to be pulled off by taking the nut off of the bottom and then take the spool off and resting the spool. If the string is new it may be the wrong size string.
Jun 04, 2011 | Ryobi 15" Electric Factory Reconditioned...
I need to kno what the item number (so I can order) the line tensioner on my Poulan Pro Link line trimmer---PPB 335. It is a small plastic trimmer head cover. Do I have to order the whole trimmer head?
Your string head is part number 26 in the diagram. Home Depot's Garden department has a wide variety of parts including universal string heads and heads for Homelite, Ryobi, etc. and possibly one that will fit your machine. A lot of these trimmers have Poulan engine and trimmer head parts. See if you can get the complete assembly off the trimmer (if you haven't already) and take it with you to the HD and match it with a new one. The price of parts from an online supplier plus shipping will be almost as much as a complete replacement head. If you shop Ebay, there are literally hundreds and hundreds of weed trimmer parts on there and some good deals to boot.
http://www.mowerpartsweb.com/MANUALS/POULAN/PPB335.PDF
May 02, 2011 | Garden
HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for Ryobi RLT30CD trimmer
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM Head) Use 2.4mm monofilament string. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Cut one piece of string approximately 7.6m in length. n Rotate knob on string head until line on knob aligns with arrows on top of string head. n Insert one end of string into eyelet located on the side of the string head and push until string comes out through eyelet on the other side. Continue to push string through the string head until the middle section of the string is inside the string head and string outside the string head is evenly divided on each side. n Rotate the knob counterclockwise on the string head to wind the string. Wind the string until approximately 20cm remains protruding from the string head. INSTALLING STRING IN PRO CUT II STRING HEAD Use monofilament string between 2.4 mm and 2.7 mm diameter. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Gather two of the pre-cut lengths of trimmer line provided or cut two pieces of trimmer line, in 28 cm lengths. n Insert the strings into the slots located on the sides of the string head. String should be pushed in until approximately 2 cm protrudes from the holes on the top of the string head. n Remove old string by pulling it from the holes located on the top of the string head. http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Oct 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Jul 05, 2009 | Garden
RYOBI 767r.. HOW DO I REMOVE PART #15 (OUTER SPOOL & EYELET ASSE
push down and turn, I think it is reverse threads
May 15, 2009 | Hand Tools
Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
Feb 22, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
601 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
