Question about Nikon Coolpix S210 Digital Camera
The zoom lens gets stucked and cannot come out when I turn on cam
I tried to turn on my camera and usually the zoom lens will come out, but recently it seems to have gotten stucked! The lens looks like its trying to come out but something its stoppin it and the back screen just says "Lens Error"...
would you please advise what I can do to fix this?
Thanks so much!
Heidy
  • 502 Answers
Lens probably does not extend or retract because of debris or a misaligned gear box. Thelens can in about 50% of the cases be repaired without having to replace it. Try toreturn to manufacturer first. If you're out of warranty, there arethird party place that fix them such as camera lens repairs. If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Posted on Jul 10, 2010
My Coolpix L320 was working fine, then all of a sudden got stuck with the lens zoomed all the way out and a message on the screen that says, "Turn the camera off, remove the lens cap, and turn the cam
after changing the battery and gently push back on the lens it should automatically close if not then check around it it must be something stuck in between it
Jan 18, 2015 | Nikon Coolpix L320 Black Digital Camera...
When I turn it on, the lens gets stuck. I get a msg on my screen that says "Lens error, restart camera". I've turned it on several times, and it keeps getting stuck. Is there something else I...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jan 09, 2011 | Canon Powershot A1000IS 10MP Digital...
My fujifilm s1000 keeps showing "zoom error." I don't know what happend. It's like one day it's working, the next not. I have a family member graduating Friday and can't afford a new camera. I've taken out...
Hi.
If you try turning on the camera with the lens cap on, you may get zoom error. Ensure that you are removing the lens cap before turning on the camera.
If the autofocus ring is held while taking the picture, or operating the lens this will also cause the Zoom error message coming up.
If that is not the problem, then the lens has troubles extending. This may happen because of dust stuck in lens mechanism, or because of a mechanical fault concerning the lens.
Any cause preventing lens from full extention or retraction will trigger zoom error.
Here a basic manual in PDF format.
Here Owners manual.
May 20, 2010 | Fuji FinePix S1000FD Digital Camera
The zoom does not respond
Hello. The stuck lens assembly is triggering an error condition--and you get the "press reset" to make you reset the internal computer in the cam. Was the unit dropped or did it have some sort of impact--this would cause the internal lens mechanism to become mis-aligned. Also, leaving the cam in a hot car can cause grease(or other lubricants) to flow to movement surfaces, thereby causing a "glue" effect. Look into the lens(cam off) under a bright light and try to determine if the internal lens assembly is crooked. Also, try to see if there is any "wet" area appearing anywhere(especially if the cam was exposed to heat--classic symptom) If the lens assembly is indeed mis-aligned, the cam must be sent to a repair facility. (Also, make sure the battery is fully charged as a weak charge will cause lens jamming(and a whole host of weird phenomenons)---Rick
Oct 11, 2009 | Panasonic SDR-H60 HDD Camcorder
Hi, my zoom is stuck out and won't retract.
Your lens motor is most likely burnt out. The only way to continue taking pictures is push the lens in manually, You may have problems with the focus after doing this, so just turn the lens manually until you are zoomed in properly. If you have a warranty now is the time to use it.
Jun 26, 2009 | Fuji FinePix A600 Digital Camera
Lens keeps getting stuck/needs a good tug to zoom past 25 HELP!
Hi Rachael_amor, If the lens will not zoom on the camera will it off the camera? If not then it has some grit, dirt, and the like in the lens. You could attempt to vacuum around the zoom however, I suspect it will need to go in to Nikon. That lens is not well weather sealed, it is a inexpensive consumer lens.
Jun 02, 2009 | Nikon D80 Digital Camera with 18-55mm Lens
Zoom wont adjust
Hi there. I can help you with that.
The number one problem with cameras with lenses that won't retract or or move out into position is dirt, grit or sand in the lens mechanism. The best way to fix this is to get an air compressor and put the tip up the lens and blow air into the space around the lens. Run the tip of the compressor nozzle around the lens and turn the camera back on. See if that helps. If it doesn't do it one more time.
If it helps, great. Stop there. If it doesn't help, let me know in a comment and I will tell you a couple more things to do. I want to wait, because they are things that you should only try if you are ready to trash the camera, but they usually work. Hope the air compressor works.
Rob
Feb 21, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Same problem
your batteries are dead.
Oct 27, 2007 | Samsung Digimax S500 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
237 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
