Question about Fisher and Paykel Fisher&Paykel E522 Bottom Freezer Shallow Depth Refrigerator
Something about Vaccum Condensing....and not going below 50 degrees
My samsung refrigerator model RF266AEPN refrigerator compartment won t go above 50 degrees
I think if you check fridges are made to run fifty or below. Ours runs at forty five degrees.
Jun 09, 2017 | Samsung Refrigerators
What is a 410A 3 1/2 ton air-conditioner low pressure at 80 degrees
??? 80 degrees ??? Anything below 100 psi is going to start freezing up. 410a refrigerant is approximately 32 degrees at 100psi. Typically a 410a low pressure switch will open at 50 psi.
May 08, 2017 | Heating & Cooling
How frequently should the compressor run on a fridge?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
The model number provided does not register. Your model number is located on the inside wall of your fresh food section.
Your freezer is your only source of cooling. It will meet its setting before meeting the refrigerator temperature.
The normal setting are -2 to +2 degrees F. for the freezer and 35 -40 degrees F. for your fresh food section.
Your freezer will go about 10 degrees F. above the set temperature. Then when it reaches 10 degrees F. below the set temperature the compressor will kick in.
You have condensing coils either under your unit or a canister in the back which gets ride of the heat. When the condensing coil is plugged up with dust, this could affect your cooling by as much as 40 degrees.
I do not think this is your total problem.
Feel the face of your separator wall between your freezer and fresh food section. Is it hot?
Your problem is your condenser fan in the lower right back of you unit is burned out.
So, you can not dissipate the heat.
Remove the lower back cover. Take a common household fan to blow air under your unit.
Your compressor is running to make up for the heat that the condenser fan can not dissipate.
Feb 27, 2015 | Electrolux Refrigerators
Hayward heater steaming
if water temp is below 70 it is condensing and the water is falling on the burners if over 70 degrees see if heat exchange is leaking
Feb 02, 2014 | Hayward Pool & Spa
Hayward h100id leaking
if water 70 or below it is condensing and the water is dripping on the flame bar and sizzling if over 70 degrees check for leak in heat exchange if that is leaking you need a new one and check chemistry
Sep 09, 2012 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Fridge side working but only cooling to 50 degrees
My 14 years old GE profile refrigerator keep cooling above 50 degrees and not going down to below 40 degrees. I did clean condenser coil and fans are running fine. I adjusted temperature control to maximum cold .Do you think it my be short of refrigerant?
Jun 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
UNIT RUNS BUT WANT COOL BELOW 50 DEGREES... COMPRESSOR IS RUNNING AND COLD LINE COLD ,HIGH PRESSURE LINE HOT BUT WILL NOT COOL BELOW 50 DEGREES.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 15, 2010 | Haier HSB03 Compact Refrigerator
There has got to be a way to change the factory preset freezer temperature on a Delfield 6000 series MCII to operate at refrigerator tempatures. Does anyone know how I can change the factory preset...
Do you mean to go up to +36 degrees? If so, it just won't work correctly. The refrigerant is the wrong one to run at 36 degrees. The pressure on the "low" side of the compressor is so low that the compressor will starve for freon if you tried to change the thermostat to "warm" it up to +36. Also the defrost cycle would have to be disabled or it would jump to 50 or 60 degrees 4 times a day. It also has the wrong cap tube for that temperature. It could be done with a very expensive condensing unit changeout. Over the years I have seen a lot of people try it and nobody that I know have been succesful at it. It may be easier to find someone who wants to trade. After all a freezer is worth more dollars than a cooler. Good luck.
Oct 07, 2010 | Delfield 113.28 cu. ft. Commercial Freezer...
When out temp is below 50, heater does not produce enough heat
Sounds to me like the thermostat or thermostat wires are wrong.
If you open the t-stat make sure no bare wires are touching one another.
Typical wire codes/colors are red to R,green to G,yellow to Y,w to white or w1,orange to O,blue to common(C),brow to E.
These should be the same in the air handler as well as the outside condensing unit.
Some installer may use different colors for some other reason.
Verify these colors throughout and report back.
Has the problem existed for the 2.5 years or is it recent?
Feb 18, 2010 | Ruud Central System Air Conditioner
I just get a dehumidifier it was on all night and the bucket its dry u think theres something wrong with it and whats the % that i have to set it up
% is the % humidity you want.
This is a DEhumidifier for to take water out of air for moist areas.
Usually a setting of 50% or 60% is dry enough. If it is freezing outside, inside of home is probably alreadt below 50%.
If you place in basement below 60 degree, will freeze up. Place over floor drain or in tub and leave off overnight.
Dec 05, 2009 | Goldstar DH504EL Dehumidifier
Fisher and Paykel Fisher&Paykel E522 Bottom Freezer Shallow Depth Refrigerator Logo
18 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
