Question about Kenmore 28,000 BTU Large Capacity Room Air Conditioner
How do i take the front cover off to clean it?
  • 456 Answers
Take the filter out, Look for a couple of screws on each side at the bottom of the unit, if they have them. Then the pull down on the top of the unit gently until it pops loose
Posted on Jul 09, 2010
Error code - 001-302
check if the front cover is closed properly. If this doesn't work try rebooting the printer with the front cover open. Close it when it started up. Clean sensors. All not working. Engineer.
Nov 27, 2013 | Xerox WorkCentre 7328 Colour Multifunction...
I have a 2005 3.7l jeep grand cherokee. I just wanna know what bolts I need to remove to clean out the front differential. How many there are. I already did the rear. That was easy. Does the front need to...
  • It's just some bolts holding the cover plate to the front pumpkin (differential). 10 maybe. You will need a cover plate gasket if you pull the cover plate. You can drain and fill it if you want and it will be fine. Being a mechanic I always like to pull the cover plate and spray the spider gears with some brake clean first then put the cover plate on and fill it up. Get's them gears squeaky clean. But a simple drain and fill is sufficient.
Regards, Tony
May 25, 2011 | 2005 Jeep Grand Cherokee
Error 1203 on lexmark p6250 printer
Erro 1203 solution
1. open the front cover of the printer
2. wait for the cartridge carrier to be in the center..
3. remove the mono and color cartridge or printhead
4. clean the gold connectors or circuit on the printhead
next: power off the printer while the front cover is open .
5. then clean the printer cartridges carrier circuit ..especially those gold connectors....and reinstall the printhead or cartidges..
6. close the front cover and power up the printer..
Good Luck!
Feb 26, 2011 | Lexmark P6250 All-In-One InkJet Photo...
Message 'Clean Sensor' has appeared. Followed advise to open Cover D and close it again but to no avail. Has anyone got any other suggestions, please?
Follow the steps below to clear the "Clean Sensor" error message.
  2. Slowly close the cover again. c2600_close_cover_d.jpg This action will move the lever shown below and clean the sensor.
  3. Open and close the cover several times. Once the front cover is left closed the printer will start to calibrate.
Once complete, the error should no longer appear and the printer should resume normal operation.
Note: If the error message is still apparent after following the steps above, contact Epson for further advice.
Nov 16, 2010 | Epson AcuLaser C2600N Printer
FLASH WILL NOT OPEN - ERROR CODE SHOWS, ASKS TO SWITCH CAMERA OFF THEN ON - BATTERY REMOVED AND PUT BACK CODE ERR 05
Top cover giving err05
you can open manualy and clean throughly and front cover edge just push it out side make little space beetween top cover flash and front cover.
try out if work then good other wise you have open camera and clean top cover part which is poping up flash.
Jul 31, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Can the front cover be removed for cleaning?
yes normally its just small clips that are resealable used to hold it on as for maintenance it requires exposing the light bulbs
hope this helps
Robb
Apr 23, 2010 | Panasonic PT-51HX41 51" Rear Projection...
I need to clean the drain pump but before I do I want to make sure what I think is the pump really is. I have the front panel off so is the drain pump white and in the front? I'm assuming it is because the...
The drain pump is easy to clean. It is white and has around cover facing the fron on the bottom. Take 3 screws out and remove the bottom cover, unscrew the round cover off of the drain pump, pull it out, and clean out all the coins, toys, hairpins, whatever else has been left in pockets and gone into the washer. When you screw the cover back on make sure the gasket is seated properly. Also, expect some water when you remove the cover.
Apr 17, 2010 | Kenmore Elite 45986 Front Load Washer
Can't send faxes , keeps saying document jamed
Open the front cover by pulling it towards you (that is the cover where are the digits and other function keys), see if any paper has inside and than close the front cover and press the " Stop " button.
Remember if you do not close the front cover good the message will still appear on the screen because the machine thinks that the cover is not closed. That happen because of the sensor on the front cover which detects do the front cover is closed so check dose the door is good closed. If your machine do not pull the documents in the " document feeder " than open the front cover and you will see pair of rubbers inside, clean them with alcohol or glass cleaner and clean peace of cloth.
Jul 03, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Cleaning the screen cover on my sony big screen
To clean its front screen, you should not open front cover as its complicated procedure. just take off its back cover as its shown in picture and use air-blower to clean dust. Then use soft cotton cloth to clean its screen from internal and 3 bulbs / lenses (CRTs) and job is done.
Need further help, let me know.
Bye.
Sep 13, 2008 | Sony KP-57WV600 57" Rear Projection...
Heating & Cooling Logo
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
