Question about Canon imageRUNNER 5000 Copier
How can I change the time that it takes the ir5000 to come out of energy saving mode. Right now when I send a printer job I have to wait 5min before I can get my print out.
    Problem Solver:
  • 11 Answers
You can turn of sleep mode.the machine will stay on all the time. you enter sevice mode 1) Press the user mode key (star ) on the control panel. 2) Press the 2 and 8 keys at the same time. 3) Press the user mode key (star ).
then option ......user.......sleep and you put on 1.
goodluck.
Posted on Jul 12, 2010
My canon imagerunner 6000 hangs on starting the machine. It just says wait.....
Most copiers and printers have a mode called power save mode. If the Machine is not in use it saves energy and powers down to a lower level. Once it receives a print job it takes a bit for it to warm up. It can take up to a couple minutes on some machines to do their self test while powering up. As long as it gets to the ready mode to unit is good. On some unit you can disable the power save mode or make the between going into power save mode longer.
Printer Repair Service in Miami and Fort Lauderdale FL
Jan 15, 2016 | Canon Office Equipment & Supplies
What can i do when my copier says wait warming up but it never gets ready?
Have you checked the manual under Troubleshooting?
The only thought I have is this one;
Is the equipment in the energy saving mode (Automatic energy
saving mode)?
Press the [ENERGY SAVER] or [START] button on the control
panel to clear the mode. (It takes a while for the equipment
to become ready.)
P.43 "3.Energy Saving Mode
Apr 01, 2015 | Toshiba E-studio 281c Copier
CHANGE THE SLEEP MODE OM A SHARP MX-M700U
If I remember correctly you puch the System Settings button on the right side of the LCD and then select Energy Save and in there I think is were you can turn off the Auto Shut Off and the Energy Save Modes.
Oct 20, 2011 | Sharp MX-2300N Color Copier
How to change turn-off time from 20 minutes?
Power Save mode allows your machine to reduce power consumption
when it is not in actual use. You can turn this mode on and select a length
of time for which the machine waits after a job is printed before it
switches to a reduced power state.
1 Press Menu until System Setup appears on the bottom line of the
display and press Enter.
2 Press Enter when Machine Setup appears.
3 Press the Scroll buttons until Power Save appears and press
Enter.
4 Press the Scroll buttons until the time setting you want appears
and press Enter.
5 Press Stop/Clear to return to Standby mode.
Jun 28, 2009 | Xerox Phaser 6110 Laser Printer
CLEANS ITSELF TOO FREQUENTLY- 2-3 TIMES EACH DAY
Try maxing out your power save timers. Here are the instructions. I suspect the machine is going into power save mode to quickly. Here is how you do that.
NOTE: To save energy, the printer enters a power saver, low-energy consumption mode after a predefined period of time since its last activity. In this mode, most printer electrical systems are shut down. When a print job is sent to the printer, the printer enters the Warm-up Mode. You can also warm up the printer by pressing the [OK] button on the Control Panel.
If the printer is going into Power Saver mode too often and you do not want to wait while the printer warms up, increase the length of time before the printer goes into the Power Saver mode.
Modify the timeout value:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Printer Controls], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Power Saver Timeout], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select the required timeout value (30 - 240 minutes), and then press the [OK] button.
    NOTE: Select a larger timeout value to extend the length of time before the printer goes into the Power Saver mode.
  5. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
Feb 02, 2009 | Xerox Phaser 8500/DN Printer
How to turn off the cleaning page feature in Xerox Phaser 8500
Actually what is happening is your machine is going into the power save mode and staying there for a long time.
What happens then is you get a full warmup. When the machine warms up, it will turn on the compressor and drain the resivour because Xerox wants a "fresh": supply of ink in the print head.
Its excruciatingly expensive and wasteful.
Here is something that can help. I am not sure you can completely disable the energy save mode. Thanks Al Gore...
Dec 17, 2008 | Xerox Phaser 8500/DN Printer
Disabling Power Save mode
If you enter the config menu, you can turn off energy conserve. You enter the config menu by turning off the printer, holding the center and right arrow, and powering the printer on. Continue to hold the buttons until you see Performing self test. Then you will see config menu. If you scroll down to energy conserve and select it. You can change the option to off. This will disable power saver.
Jul 01, 2008 | IBM Infoprint 1532 Laser Printer
Receiving faxed
when the machine goes into energy save mode it will still receive faxes. (energy save is a low power mode the copier is still on and can accept faxes, print jobs and copy jobs)
however if the machine goes to auto shut off it will not.
(auto shut off will after a set amount of time turn the power switch on the copier to the off position and the copier can not be used until it is turned back on.)
you need to turn the copier off, hold down 0 & 8 and turn on then type in 206 press start, key in 20 press set then turn the copier off and back on. this will make sure that auto power off is not enabled.
i hope this helps you.
Jun 01, 2008 | Toshiba e-Studio 350 Copier
Sleep Mode
Yes there is.But let me give you an explaination of somethign in the scanner.Once you turn the power save mode off, If the copier has sat for a while and saws WARMING UP, It is not the power save setting. The scan lamp also has to reach operating temperature for the machine to run. So even after Power Save is off, you may get an occcasional Please wait Warming up before a copy. There is no settings or changes for the scanner lamp warming. I throw that in so you don't suspect you did something wrong in changing settings.
Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  1. Press the [Enter] button. 'Machine Setup Tray 1 Size' will be displayed.
  2. Press the [Left] or [Right] arrow button until 'Power Save' is displayed, and then press the [Enter] button.
  3. Press the [Left] or [Right] arrow button to select 'On' or 'Off' to enable or disable the Power Save mode.
  4. Press the [Enter] button to save the setting.
  5. If Off is selected, skip to step 9.
  6. If On is selected, press the [Left] or [Right] arrow button to select the required time interval.
  7. Press [Enter] to save the setting.
  8. Press the [Stop] button to return to the Standby mode.
Jan 11, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Energy saver mode
Yes you can change the power save mode. I don’t remember from where you can change it. but its easy for you if you get the all operation manual list form the printer, get the setting page from printer by pressing the menu from your printer then you will get all commands so then you can change all settings of your printer.
Nov 30, 2007 | Konica Minolta PP9100 N Economical...
Canon imageRUNNER 5000 Copier Logo
183 people viewed this question
old marine
old marine
