Question about Honeywell HY-030 Tower Fan
What do the "symbols" mean on the tower fan and remote?
Which symbol on remote is cooling? I dont have a manual but is on the wall, symbols are a fan on the bottom LH, an a sun on top LH I think? Are you able to help me with modes to select please?
Symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
L-means fan speed low
M-means fan speed of med H-means fan speed of high.
To get proper cool, mode "cool" and less 3 degree minimum than your room temp.
To get proper Heat mode "Heat" and 3 degree more than room temp. Hope, helpful
Jan 30, 2011 | Sanyo Heating & Cooling
Omega Europa 20-1 oven. What do the symbols mean?
Fan symbol - defrost (fan only - does not use thermostat)
Fan symbol within a circle - fan forced oven
3 little triangles - static grill (keep oven door open)
3 triangles above the fan symbol - fan grill (keep door closed)
Oct 03, 2009 | Ovens
Are all symbols on a/c the same
Ok the snowflake means that the unit is cooling. The sun means that the unit is heating, the raindrop means that the unit is dehumidifying, the fan means that the unit is using the fan only as ventilation without cooling or heating and the funny triangle looking thing is auto mode where the unit sets the mode automatically. The little bar in the middle displays fan speed and the two little arrow things next to it means that the fan is in auto mode where it sets the speed automatically. There I hope that that helps.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 25, 2009 | Heating & Cooling
Need a replacement remote for tower fan
CALL 1-800-295-4448 THE WILL SEND YOU A REPLACEMENT
GOOD LUCK
Jul 03, 2009 | Tower Aloha Breeze Fan
I need the directions on how to use the remote for the fan.
plug in fan and use the remote the same way you would press the buttons on the tower fan. Just press ON on the remote and select MODE and SPEED as desired. If unit does not turn on, check the the batteries are fresh and installed correctly.
Apr 30, 2009 | Aloha Housewares Breeze 29" Tower Fan
Computer not loading up strange symbol indicating some problem
That is the hard drive symbol. The noise is most likely the hard drive, and I would say that your hard drive has failed/crashed and needs to be replaced.
Aug 21, 2008 | Packard Bell (ATXMH28AP) Full Tower Case
Aloha breeze tower fan
I am listing one on EBAY today.
search for Aloha Breeze Ceiling Fan/ FAN REMOTE CONTROL
It should be listed in an hour or so. Kindiskandi42 is our ID on EBAY
Jun 04, 2008 | Tower Aloha Breeze Fan
Aloha Breeze Tower fan remote control no longer functions consistently. A replacement remote control is needed, or this one needs to be fixed. Is a purchase of a just a remote possible? Suggestions?
I'm serious even though it sounds like a joke.
Call 1-800-REMOTES
or here is their site
http://www.remotes.com/store/aloha_breeze/84001.html
Aloha Breeze 84001 Remote for $28.95
Shipping in US and Canada is $7.95
Hope this helps!
May 03, 2008 | Tower Aloha Breeze Fan
Honeywell HY-030 Tower Fan Logo
83 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Tom Chichester
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
