I have a Leem KA-1210N amplifier and when i insert the microphone the xlr input no sound comes out when singing in the microphone!can you tell me why?volume is on high,everything set ok but no sound!
  • therock1519 Apr 19, 2008
    there is only one xlr input for the mic and another jack input for it!but i only have an xlr cable maybe i'll get a xlr jack cable and try the jack input for the mic
  • Jack Garner Sep 21, 2013
    It was working, but would stop if my voice got loud. Now just quit.
    Sergeant:
    Champion:
  • 319 Answers
Mic maybe plugged into wrong or inactive input. Check to see if input is switched to another input rather than mic.
Posted on Apr 19, 2008
The XLR-input distorts very fast
XLR inputs often have a pad (attenuator) that is switchable for signal level.
May 23, 2017 | Boss Rc 50
I just bought the GXL2200 CAD microphone without the cabels,(thought they would've came with), what kind of cable do i need?
As with most microphones, these mics use XLR cables. You can get them online or in a music store in many different lengths. What you need is XLR male to XLR female, though most of the consumer-level stores will probably just call them "mic cables." Note that the thing you're plugging into will need to have an XLR input, and will need to provide phantom power in order for that mic to work.
Nov 09, 2013 | CAD Microphones GXL2200 Professional...
No sound
1st thing to try is a different XLR microphone cable. Sounds too simple, but sometimes it's the cable. If the mic has ever been dropped/damaged, OR has seen alot of saliva/spit from singing into it...it's possible the diaphragm has crapped out. At which point, get a new mic, because the SM-48 is not an expensive mic to replace with same.
Jan 06, 2013 | Shure SM48 Professional Microphone
Does the Behringer xm8500 work on it's own, or do I have to hook it up to something? My daughter wants a microphone she can sing into.
All microphones have to be hooked to an amplifier to work. The socket at the bottom with the 3 pins in it is called an XLR jack. You need to plug an XLR cord into that and then plug it into an amp that has an XLR or 1/4 inch microphone input (using an adapter).
If she just wants it for looks, then no, you don't need to plug it in.
Jul 03, 2011 | Behringer XM8500 Professional Microphone
Brand new ag30 when I plug my mic sm58 into it all I get is static no sound as in singing comes through it I'm using a XLR to quarter brand new lead.. Have tried everything when I hit the tip of mic sound...
You should be using XLR to XLR cable, NOT a 1/4 inch cable. There is a problem of the 1/4 inch being the unbalanced version and is not compatible with this unit's input.
Use the XLR to XLR mic cable and it will work fine.
The cable you have would work for one of those cheap Karaoke machines...
Mar 25, 2011 | AMP Acoustic Ag30 30w 1x8 Acoustic Guitar...
I get a quiet signal when using the mic.
You should use the mic input of your computer.
If it's not there, use a microphone pre-amplifier.
Regards,
Gerard
Feb 17, 2010 | Shure SM57-LC Professional Microphone
What kind of outlet do i plug my cm-p35 microphone into?
The cm-p35 is a low-impedance (low-Z) dynamic microphone. It can plug into a mixer or microphone preamp that has XLR input connectors, typically found on professional audio equipment.
If you want to attach it to a computer, you'll need to buy an audio interface for it, either a pro-grade sound card with XLR inputs, or a USB-to-XLR adaptor, like this one at ZZounds.com
Jan 10, 2010 | Coby CM-P35 Consumer Microphone
I buy a microphone, and I don't now where I have to plug it in, I's called i Carly Microphone, do I need something extra to use it, im trying to plug it in an guitar amplifier...
does it have a cable for it? it should. if it does then just plug it into the amp input jack. there is probably an on/off switch on the mic. i dont know if this is a fixed mic cable or if it is XLR type input on the mic. If there is a place for a cable to plug into the mic at the base of the handle, see if there are 3 pins in the jack of the mic. if so it is XLR, and the amp is 1/4inch so you would need a cable with XLR to 1/4"male. I would go with no shorter than 12 feet, but try to go with 20 to have enough room to move around. Hope that helps.
Nov 04, 2009 | Nickelodeon 684-1220B Microphone
Microphone
It really depends on where you will be using the microphone and and whether it is just going to be used for fun at home or in a club oor for recording?
Some golden rules for microphone selection.
1) Make sure the microphone is Uni-Directional. This means it will only pick up sound from the direction it points in. You are less likely to get feedback or background intereference.
2) For a vocalist, make sure the mic is a reasonable size. If it is too small and you need to hold it, after a while it becomes fiddly and uncomfortable.
3) When singing always use a foam hood or pop filter with the microphone. This will reduce explosive sounds on the letter "P" etc.
4) Choose a microphone with a wide frequency response but not too much bass which can make vocals sound boomy.
5) Finally, the microphone must have a reasonable dynamic range so that if you suddenly shout it does not distort excessively, but it will also work when you speak or sing softly.
Feb 29, 2008 | Audio Technica Audio-Technica ATW-T341...
310 people viewed this question
 Grubhead
Grubhead
