Question about Nokia N95 Cellular Phone
Slider problem when i slide the slider up...the screen goes blank
  • nickhohh Jul 10, 2010
    How do I change the strip?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 105 Answers
It might me the strip problem. try to change the strip.
Posted on Jul 10, 2010
  • vinoth kumar
    vinoth kumar Jul 11, 2010
    u just take it to the service centre and let them fix it.
My w580i goes blank when i slide it up didnt drop it or anythin so idno if it needs a new slider or screen please help
Hello Dear.....
I just Suggest you to please go some Mobile Repairing Center and Change Flap OR Bar Cable Which is maintain Connection of Your Slider Screen with Your Device... Its May Faulty.... And Every Problem Occurred From there ...
Thanks
Mar 12, 2011 | Sony Ericsson w580i Cellular Phone
One of my ipod apps goes blank when I touch it... the sound is on, but the screen remains blank
Is your iPod jailbroken? Did you get this app through any other means besides the App Store? If yes, then its very likely that the developers of the app made it that way if you didn't get it from the App Store.
If it isn't, try restarting your iPod (holding the bottom button and the top button, then sliding the slider to off, and then pressing and holding the top button again). It might work after that.
If it still is an issue, and you did get the App through legal means, try contacting Apple through their website.
Feb 03, 2011 | Apple iPod touch
Cannot use the slide button
Try resetting your iPod by:
  1. Holding down the home button (button on the face of the iPod) and lock button (button on the top of the iPod) at the same time for a few seconds. An option to turn off the iPod should appear at the top of the screen.
  2. Slide the slider to turn off, and wait until screen is totally blank.
  3. Press and hold the lock button (button at the top of the iPod) until an Apple icon appears. Let go, and try the slider now.
  4. If that does not work, it is most likely that you damaged the touch sensor on a certain part of your screen - go to Apple to get it repaired. If you bought it within less than a year, it may be covered under warranty - which means you can get a free replacement on the spot.
Feb 01, 2011 | Apple iPod touch
N95 slider problem . LCD goes blank on sliding . it appears that there is problem in Strip. do u get separate strip or it comes alongwith slider....
No the Slider strip doesn't come separately because the strip is merged permanently to a circuit that has your earpiece ,light sensor,and front camera you cannot seperate it in any manner because the only unlockable part over there is the LCD screen .i would recommend you to get your phone serviced from nokia care only because the strip is the most important part in a slider .. even if you get a local strip installed from a local mobile repair center it wont last for a month ..even i had the same problem 4 months back ..because quality of the strip matters .......
Dec 28, 2010 | Nokia N95 Cellular Phone
Desktop display smaller than screen
1) Right click on your desktop.
2) Select Properties at the bottom of the popup menu. This will open the Display Properties window.
3) Click on the Settings tab (it's to the top right)
4) At the bottom left there is a Screen resolution heading with a slider bar beneath it.
5) Slide this bar to the left and right until you find the resolution you like.
Sliding the bar to the left = lower resolution, larger desktop icons and less quality.
Sliding the bar to the right = higher resolution, smaller desktop icons and better quality.
If your screen goes blank after you click Apply then immediately hold down the Enter key.
If this doesn't work then it just maybe the case that you need to set the auto screen fit function on the monitor itself using the buttons provided on the monitor.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
Nov 02, 2010 | HP L1702 17" LCD Monitor
Can't make phone calls with my touch slide always force close. When I try to make a phone call, the screen goes black and I can't view the dialer. Please help!
The problem with the phone is the flexi ribbon thet slides the phone up and down, it is not properly seated that is why it is losing contact with the main board of the phone, hereby resulting in blank screen while dialing or making a call.
The flexi ribbon is known as the flex, so as soon as you replace the flex of your phone, it will work perfectly fine once again.
Have a repairman fix the flex of your phone, and it will be in good condition once again.
Take care
Oct 13, 2010 | HTC Touch Dual Slider Smartphone
Dell laptop screen goes blank when ac adapter plugged in
I believe I have found the problem with the 1525 that I am currently working on which has the same problem that you describe. Ultimately I think it's a problem with the inverter in the LCD. When the laptop is powered by battery the brightness is lower than full. When I plug in the power adapter the brightness goes to "full" and I hear a faint sizzle and the LCD's backlight goes off. Same as if you hold the Fn key and press the up arrow to brighten it, it will do the same thing when you reach near the full brightness. So for now I have fixed this problem by going in the Power Options and clicked on Adjust the display brightness on the left. Slide the slider to the left on the "plugged in" part and now when you plug it in it shouldn't make it go blank. I do want to note that I hear a faint buzz coming from the LCD when I plug it in. That must mean the inverter is faulty. WAY TO GO DELL!!!!!!
May 23, 2009 | Dell Inspiron 1525 Laptop
Slide up, screen goes white but keys are active...
The strip that connects both the upper and lower slider is damaged ... replace it
Dec 11, 2008 | Nokia N80 Cellular Phone
Nokia N95 Cellular Phone Logo
261 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
