Question about GE JTP45 Electric Double Oven
GE Double Oven JTP45BA1BB. Oven control panel went out and got the replacement part. The wires do not match up. How do match the wires up? The oven part was WB27T10055 and the one sent is WB27T10283. All say that the replacement part is correct. The problem is that the wires do not match up from the oven to the new control panel. How do I get the new oven part WB27T10283 to wire up to the oven?
Powerman
  • 68 Answers
SOURCE: ge double wall oven repair
You need to tell us the model number. I can then give you specific information.
Posted on Nov 18, 2007
  • 833 Answers
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Posted on Dec 07, 2007
Powerman
  • 68 Answers
SOURCE: Wiring diagram for jtp18
Call GE at 1-800-626-2005 to get a wiring diagram
Regards,
Powerman
Posted on Oct 31, 2008
SOURCE: Dead Whirlpool Double Oven
This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
Posted on Dec 05, 2008
SOURCE: Lighting panel in my electric Thermadore double oven is dim.
I just replaced two of the capacitors and it worked thank God. I couldn't get at the 3rd capacitor with the soldering iron because the display blocks it and I couldn't see how to remove the display unit. We had already begun shopping for a new double oven. This was the last resort. The capacitors were $1.78 apiece at an electronics store. A repairmen quoted us a $780 fix - with him shipping the parts out to be rebuilt because Thermador is out of business and not producing parts anymore. There is a great place in Canada called Appliancetimers.com which will rebuild the timer for you inexpensively ($109) but they also want you to send the Power Relay Board which requires removal of the double oven to get at it. We found that it was much too heavy to consider that solution.
Posted on Mar 27, 2009
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Oven will not heat
GE Oven: If it only gets warm, it is not getting 220 volts. It may only be getting 110 volts. First check your breaker (double pole) and reset it manually. Since it is an older oven, there may be a break in one of the wires or connections. A voltmeter will indicate just how much current you have. Be careful.
Mar 29, 2017 | Ovens
GE Double Oven Controller WB27T10276 Connection Details
I successfully replaced my WB27T10063 with the WB27T10276 (ERC3-GE-M) by following the instructions (Pub. No. 31-10515).
"they tell you for the Broil Relay to connect L1A to the common terminal."
This is simply a misreading of the poorly written instructions.
  1. Bake: yellow goes to yellow NO.
  2. Broil: violet goes to violet NO.
  3. Broil: black L1B goes to violet COM.
  4. AUX 2 goes to AUX2 (black and white wire).
  5. AUX1 goes to AUX1 (daisy-chained black from violet COM/L1B).
  6. OV2 goes to OV2 (white wire).
  7. OV1 goes to OV1 (brown wire).
  8. L1A goes to L1A (daisy-chained black from AUX1).
  9. N goes to N (daisy-chained white from OV2).
  10. GND needs to be "tucked under the (steel) clock bracket" on the control panel.
The hardest part was disconnecting the wires from the old ERC. Took a LOT of force! I also had a hard time figuring out how to release the green tape thing apparently labeled "J1" on the old ERC. Piece of cake after that.
Aug 09, 2012 | GE JKP27 Electric Double Oven
My GE JKP45 double oven needs a new control panel (part # WB27K5047 which is no longer available) There are a few place I've found on-line that refurbish electronic panels, or if it only has a loose...
according to the website i use to look up part#s while the part# you have is indeed not available a replacement for it is WB27T10050
to removeand replace it unscrew the screws that hold it to the cabinet pull it out about 4-6 inches,remove the grill directly under the control panel on the upper oven and look for screws around the panel where ya have pulled it out of the cabinet
to see yourself the replacement part# go to searspartsdirect and enter the model# and you will see the eoc (electronic oven control) as item #16 under the control panel and top tab
Jul 20, 2011 | GE JKP45 Electric Double Oven
My GE double oven JKP26GP broiler burned out (burned a hole right thru). The keypad immediately went blank and the keypad controlled top unit isn't working now (top unit only - bottom is fine). Will...
I'm afraid I don't know how to help you get a new control panel (part #WB36K5065 is no longer available). But we have the same oven and a similar problem. Our control panel works just fine, but the face is melted from a recent mishap (small fire in the upper oven while broiling), so the plastic face of the control panel looks awful and needs replacing. If you decide to replace your oven and would like to sell the front face to your control panel we'd love to purchase from you.
Nov 21, 2009 | GE Ovens
GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
Mar 28, 2009 | GE Profile JT952 Electric Double Oven
Overlay Panel bubbles up!
I had the same oven panel overlay bubbling problem on my GE oven purchased in 2008. It started peeling and bubbling within the 1 yr warranty, and GE sent me a replacement panel. This new part began bubbling again within 4 months. Again, I called but now they say it's out of warranty and they will not replace it. Obviously there's a manufacturing defect in this part. The panel looks terrible. It appears that GE no longer cares about the quality of their products.
Jan 02, 2009 | Ovens
Jrp24bow3bb electric double oven control panel.
Hi rhonm,
You should have found a connection diagram in the top of the oven. If you didn't, call GE at the following number and they will send you one. 1-800-626-2005
It would be very difficult for any one to make a recommendation without seeing the oven or part. Are there one or two gray wires? My first guess is that they sent you the wrong part. See photo for typical double oven ERC.
Regards,
Powerman
Dec 07, 2008 | GE JRP24 Electric Double Oven
GE JTP45 Electric Double Oven Logo
130 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
