Westinghouse Electric Westinghouse Lighting 3speed Ceiling Fan Switch 7707500 Logo
Posted on Jul 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The replacement switch has 4 wire ports marked L,1,2,3. The fan has a black wire (power) and 3 other wires from a plastic capacitor box, 1 green and 2 brown. How do the wired connect to the switch?
AJMAL KHAN
Level 2:
  • Expert 388 Answers
  • Posted on Jul 09, 2010
AJMAL KHAN
Expert
Level 2:
Answers
388
Questions
0
Helped
110049
Points
869
Dear sir
try to find out first all wire wich type of you shold use ampere meter for testing thise wire .
ampere meter turn into continuty mode and conecect its one lead (wire cable) to your motors black wire and watch the display what is rating there .and write it next wire check and date write like this way check your all 4 wire and now who is high number data its conect to number 1 after that some low conecet number to switch number 2 after that who is lowest conect to number 3 and that black colour wire conect to the L mark then try to start your motor
hope answer the question
thank you
1helpful
Ceiling fan and light kit installation 4 wires 3/1 (red, black, white) from electrical box to 3 wire (black, white. green) from fan. How do the wires connect?
I'm assuming from your question the 4th wire in your electrical box is a bare copper wire which is the ground. The green wire gets wire-nutted to that. The white wires get wire-nutted together. I'm guessing you have two switches installed in the wall for the fan because there is a black and red wire coming from your electrical box (one for the light and one for the fan) connect the two black wires together. The red wire is then connected to the blue wire in the fan which is the light.
Dec 22, 2016 • Dryers
Replacing 4 wire 3 speed fan switch with 3 wire 3 speed fan switch. Is it possible??
No it is not going to. If it does then why did they use the four wires in the first place? Duh!
If you cap the ground wire nada will work - if you cap one of the wires going to a motor winding, that speed will not work.
1helpful
2answers
I got my craftmade ceiling fan about 10 years ago, the fan has now stopped working but the light works, I changed out the switch on the wall that was not the problem sometimes I will turn on the wall...
pretty sure its the 3 speed pull chain switch.$4.50 to $6.00 at home depot or lowes or hardware/elecrtical store.
how 2 replace switch.
1.turn off breaker to fan/fan lights,probably that whole room.
may need extension cord & floor lamp from closest room with electric, so u can see.
2.need 6ft step ladder to get up to fan.look see how to get to fan speed switch. speed switch unscrews from outside but body of switch is inside fan cover.
3. need to take fan off ceiling to replace switch.
4.switch has 4 wires, power feed into switch and 3 selector
wires that go to high speed winding,medium speed winding and low speed winding.
speed selector switch has 4 settings, off, low,medium,high.
about ac circuits , black wire is 120 volts, hot.
white wires are neutral return wire. an ac voltmeter will read 120volts ac with its red and black probes between black,hot and
white,neutral.
white= neutal=ground which is green. If wired properly and polarity was observed, white and green ground wires both connect to the neutral ground buss bar in the circuit breaker panel box and are the same electrical point.
black wires,and the selector handle getting the hot juice into the fan and white returns the used juice to the circuit breaker panel box.
If polarity was observed, you can touch white and ground without getting a shock.
black will jolt or even fry you dead, so make sure the breaker to the fan is off, so that the circuit is de-energized before you touch it.
PLEASE NOTE--- make drawing on paper of what color wires from the fan motor go to what color wires on the selector switch.
If the switch has 4 black wires, you need to put different color electrical tape as a marker, on each wire. or ,to be cheap, you can use white paper,scissors to cut paper,and pencil and write 1,2,3,4 on the paper and tape to the 4 switch wires.
that is: wire # 1 from the switch goes to the black wire from the wall--ac hot
wire #2 from switch goes to yellow fan motor winding,
wire # 3 from switch goes to orange wire from fan motor
wires are specific and NOT interchangeable.
go to www.ehow.com & type into search engine box
how to replace fan motor speed selector switch.
I needed to replace the pull switch, but in doing so the capacitor was disconnected and I do not know where the wires go. It's a five wire, 2 gray,1 green, 1 red, one brown. It's marked 10mfd/5mfd/250vac....
1 - gray
2 - brown
3 - green
L - should be black
The other gray should be connected by wire nut to the other grey to reversing switch.
Also, you should have two wires, white & black w/ white stripe, at bottom of fan to hook up light if needed.
I want to replance a standard wall switch (2 wires: white & black) with a PIR Occupancy Sensor switch
Copy following link for simple walk-thru how to wire occupancy switch
http://waterheatertimer.org/How-to-wire-occupancy-switch.html
This device is made to replace single-pole switch.
Power to fan: note the horsepower range for device: for example if occupancy switch is rated 1/4 Hp, then it will work for ordinary bath fan. If device is rated for 1/3-1/2 Hp then it is rated for whole-house fan.
Each fan motor will have rating plate showing Hp. Check rating labels for each device.
http://waterheatertimer.org/Color-codewire.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
2answers
Hunter cieling fan replacement zing ear switch ze-268s5
I never could find the 5 wire 4 speed replacement. I did however find a solution.
4-speed (five-wire) pull-chain ceiling fan speed switch--Use 3-speed ZE-208S6-A09.
How to use the 3-speed ZE-208S-A09 to replace a 4-speed switch:
old ZE-208S5-1T or ZE-268S5: . . . . . for ZE-208S6-A09 use:
L=Black . . . . . . . . . . . . . . . . . . . . . . . . L=Black
1=Gray . . . . . . . . . . . . . . . . . . . . . . . . 1=Gray
2=Brown . . . . . . . . . . . . . . . . . . . . . . . . (Don't use Brown)
3=Purple . . . . . . . . . . . . . . . . . . . . . . . 2=Purple
4=Green . . . . . . . . . . . . . . . . . . . . . . . . 3=Green
old ZE-208S5-1T or ZE-268S5: . . . . . For ZE-208S6-A09 use:
2=Green . . . . . . . . . . . . . . . . . . . . . . . . (don't use Green)
3=Brown . . . . . . . . . . . . . . . . . . . . . . . . 2=Brown
4=Purple . . . . . . . . . . . . . . . . . . . . . . . 3=Purple
1helpful
The Casablanca 88U33M Scandia Ceiling Fan only has three wires, a black, a white, and a green wire (ground). How do you wire the fan and light on seperate switches?
If you want to control both the light and the fan using 3-ways, then just wire 2 sets of the 3-way circuits. For this you need two sets of 3-wire between the switches, and one 3-wire cable from the switch location to the fan/light box.
At box #1 (a 2 gang box), you will run a power cable (marked cable #1) into it. From there you run 2 sets of 3-wire cables (identified as cable #2 & cable #3) to the other switch location, which will also be a 2-gang box (box #2).
Also from box #1, you will run a 3-wire cable (cable #4) to the fan/light box (box #3).
Hook up is as follows:
Box #3: connect black of cable #4 to black (fan), connect red of cable #4 to blue (light), connect white of cable #4 to white (fan/light), and connect the bare to the green.
Box #2: Connect white of cable #2 to identified terminal on 1st 3-way switch (#3). Connect red & black of cable #2 to the remaining screws of 3-way switch #3. Next connect white of cable #3 to identified terminal of 2nd 3-way switch (#4), and connect black and red to remaining screws. Tie all grounds together and terminate to both switches.
At box #1, connect black from cable #1 to whites in cables #2 & #3, using a wirenut. Connect white in cable #1 to white in cable #4. Connect black and red in cable #2 to 3rd 3-way switch (#1) and connect black and red in cable #3 to 4th 3-way switch (#2). Connect black in cable #4 to identified terminal of 3-way switch #1, and connect red in cable #4 to identified terminal on 3-way switch #2. Tie all grounds together and to the switches
7helpful
2answers
Wiring diagram for a 3 way ceiling pull switch.
These fans are manufactured by a number of overseas companies and sold exclusively by Home Depot. They do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire fro the ceiling, take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Questions?
Please Vote !
2answers
Would this work or burn out fans? Amps on one fan is 1.5 and the other is 5 amps I want to run a 12/2 wire from the panel and to the duplex switch and tie it into a 12/3 wire that goes to switch to...
Tell me what you are wanting to accomplish. Are you wanting to run each fan off a separate switch in the same duplex box? The reason I ask is because you are using 12/3 wire to the fans. If you are just going to have 2 switches then you are only going to have power to each fan from each switch. Therefore there is no need to run 12/3 wire. 12/2 is all that is needed and you would simply tie the fan and light wires to that one power source at the light/fan. Now if you are wanting to have a switch for the light and another switch for the fan at each location then that will take 4 switches. You can buy double stack switches and have 4 switches in a double gang box. Is this new construction or old? Please explain what you are wanting and I will be more than happy to explain how to wire it.
10helpful
2answers
Need wiring diagram for 4 wire switch
I have similar problem, although I have 1 high speed and 2 lows, no medium. before I replaced the switch (which was no help) I marked the wires.
L= Black
1= Grey
2- Brown
3= Green
Top Westinghouse Electric Electrical Supplies Experts
john h
CJ Rock
CJ Rock
Are you a Westinghouse Electric Electrical Supply Expert? Answer questions, earn points and help others
