FLASHES TWENTY TIMES GREEN TO RED BY 3 TIMES. tHEN LAMP LIGHT LIGHTS UP AND REMAINS ON. tHREE GREEN TO RED PAUSE AND REPEATS. lAMP LIGHT REMAINS ON ALL THE TIME.hELP.
  • bradyob Jul 13, 2010
    Well done,Your engineer was most helpfull and right on target.
    Oliver
  • 10,594 Answers
I need model number and brand info of your tv to understand possible cause of problem.
Thanks.
Posted on Jul 09, 2010
  • 5 more comments
  • bradyob Jul 09, 2010
    Hi.
    Brand Sony. ModelKF-50SX300U.
    Hope this helps.
    Oliver
  • Shahid Electronics
    Shahid Electronics Jul 09, 2010
    Sony KF-50SX300U
    Let me know when did you last time replaced lamp in this tv?
    Symptom shows lamp is dead in tv and need to be replaced.
    Hi ,back again.
    The lamp was never replaced in this telivision.I ordered a lamp two days ago from America but I do expect to receive it within a week or so.
    Thank you for information,I WILL LET YOU KNOW HOW i GET ON WHEN i FIT THE LAMP.
    Best Wishes.
    Oliver,
    OK, great.
    Lamp replacement procedure is easy and written in user manual.
    Your update will be awaited.
    Thanks.
  • bradyob Jul 12, 2010
    Hi,Fitted new lamp this morning.The position as of now is that I have sound on all channels,the lamp lights,the motor runs. lights work as they should ie red/green. Will turn on and off.ok but no vision.
    If connection to lamp were incorrect would lamp still light?. I can see lamp lighting behind door.
    What now?.
    Yours Sincerely,
    Oliver
    Shahid Electronics Jul 12, 2010
    Please reinstall lamp in tv and make sure lamp cover is fixed back in its place securely. Lamp cover is first thing that is removed to take out old lamp. It must be put back properly after lamp replacement.
    Thanks.
    Re fitted lamp as per your instruction.I now have sound and visionand I am back in business..
    Thank you for your help.
    Yours Sincerely
    Oliver.
    P.S The lamp I received was made in China and not a Philips lamp .Is there any difference?.
Lamp wont ignite.lamp light red flashing.
Before changing lamp use a canister of compressed air to remove dust specially inside the projector when lamp is away.
Dec 13, 2013 | BenQ PE7800 Multimedia Projector
My kdf-e42a10 tv won't come on flashes green 7 times then flashes red 3 times.
The 3 blinks is lamp door not closed, what it really means is the door may be warped from the heat of the lamp===the door has a plastic peg on the back that when the door is in place engages a lever just behind the door. If the door is even a little bowed=three blinks.
Engage the lever with something not metal and see if set comes on, if it does replace the door.
Apr 08, 2012 | Sony KDF-E42A10 42 in. LCD Television
IT TURN OFF ITSELF RIGHT AFTER TURN ON GREEN
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
May 11, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
The LCD light (green) flashes for like 6 times and then the pictu
even though the lamp light is not flashing I would think it is the lamp getting weak for some reason the Sony's do that.
Aug 19, 2009 | Televison & Video
Red blinking light three times pause then three
Make sure that lamp door is fixed securely and pressing lamp door switch as 3 times blinks shows lamp door switch is not On.
May 13, 2009 | Sony KDF-50E2000 50" HDTV
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
No sound or pix
3 times flash of standby light shows that Lamp Cover is not mounted properly after replacement of Lamp.
Please fix lamp cover properly because cover has to press protection switch in circuit.
Sep 17, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
TV turns off aftering powering up. red LED flashes 3 times.
3 red blinks means th lamp door in not on. if you have installed the lamp door corectly and it still does this solder all three pins together on the door switch.
Oct 08, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
Top Televison & Video Experts
