I am unable to play a dvd recorded on one player in another machine, even tho I have finalised the disc. What am I doing wrong??!!
    Genius:
  • 1,550 Answers
They are a function named formate that you gonna make at the disc you record when you finished.Then he can be played in all devices.Good luck.
Posted on Apr 19, 2008
How can I show my DVD-R(Memorex) on my televison?
I assume you mean that your current DVD player won't play this DVD?
There are 3 reasons that it won't play. One that the disc is faulty and therefore won't play on any machine. Two that the disc has a scratch or has marks on it. You can look at ways to clean the disc on-line!
3 That it was not finalised on the machine that it was recorded on. If you current player is a + machine it won't play the disc if it is unfinalised. You will need to use the old machine to finalise the disc or another "-" disc recorder to do it - if it will accept the disc! Otherwise if the old DVD recorder is no longer with you, then your only hope to save the disc is to find another model of your old recorder to do it on. If it was a common model someone might let you finalise the disc!
Feb 21, 2013 | Panasonic Original Pansonic Tv Vcr Dvd...
Whenever I burn a DVD in my recorder I can't get it to play in anything other than the recorder it was made with. When inserted into my DVD drive on my computer it says it is a CD with nothing on it...
You need to FINALISE the recorded disc for compatible playback in any DVD player or PC. This should be a menu option on your DVD recorder. (similar to DVD management on Panasonic recorders).
It always helps to do a test recording on some discs first, then finalise them to see how they play elsewhere before going ahead and doing serious recording in this unit.
Apr 20, 2011 | Dual Presidian DVD Recorder
Trying to write to blank disk first time (Memorex CD-RW). Get message: Record failed: wrong format for re-write Spectroniq SDR-205 DVD Recorder
Some DVD recorders cannot write CD-RW - only DVD-RW (+ and -) as well as DVD-R (+ and -) (this depends on the brand/model). This unit probably does not support CD recording. Try using DVD-RW instead for this machine - see if it records that (do not finalise even if unit prompts you to with an on-screen message prior to ejecting disc).
There are DVD players and recorders which can play CD-RW (mp3, jpegs etc.) but I don't know of any which record this format (a PC CD/DVD-ROM drive can do this though).
Mar 09, 2011 | Televison & Video
When trying to play a computer generated DVD +R DL, I get a message that says this type of disc cannont be played. please insert a different disc
The disc is probably an incompatible format for this model player. Even if the disc is finalised in your PC, or in a DVD recorder, this player may still be unable to read it. Some DVD recorder/players do not recognise DVD+R (or +R DL) media, while others won't recognise +/-RW discs (except CD-RW); this is a model limitation - not a fault with either your player, the PC burning software or the discs themselves.
Nothing can be done to fix this except purchasing a model which accepts multimedia (+R/DVD-RAM etc). The question is, does your player play ANY normal DVDs? I am guessing your player will accept DVD-R DL discs just fine since this is standard as well as proper shop-bought movies.
Feb 19, 2011 | Panasonic DVD-S35 DVD Player
HI, i try to copy a Hi8-Tape to DVD, t works but i can't play it on another DVD-Player. Whats the problem. Thank's.
Depending on the format of the DVDs you record, some may not be compatible for playback on other DVD players, even if you FINALISE the disc in this recorder before playing it anywhere else. Assuming you are using the correct DVD format (for example, DVD-R), did you finalise the disc in this recorder after transferring your tape? if not, that would be the reason why the DVD won't play in another machine (I am also assuming you have everything set up correctly to enable smooth transferring - picture, sound, etc.).
Most modern DVD players recognise various disc formats (+R/-R/-R DL etc) but all of these must be finalised in the appropriate drive prior to make playback anywhere else possible. There should be a menu option or similar on this model recorder which would allow you to finalise the recording - you should only do this if you are completely happy with what you recorded, and it turned out OK. Until you finalise the recorded disc it will not work anywhere else but the deck it was written in.
I hope there is no major issue with the deck in this unit which would prevent you from finalising your discs - and achieving some success with playback in other units. The last thing anyone would want is a batch of drink coasters.
Feb 11, 2011 | JVC DR-MX1 DVD Recorder/VCR
Re-recording on re-usable discs (automatically finalised)
Check the setup. You have "automatically finalize disk" selected.
Mar 15, 2010 | Televison & Video
Why can't l play DVD's recorded on this recorder on other player
DVDs come in different versions.
Try using the -R DVDs. Once your DVD recorder finalizes the DVDs they should on any DVD palyer.
Check your manual to find out the finalizing method for your DVD recorder.
I hope this solution is helpful. Let me know.
Feb 11, 2009 | Samsung DVD-HR735 DVD Recorder/HDD...
Unable to finalise disc after recording
check the net download CD Roller very good program that finalises DVD cd etc wth recover options very cool! program
Dec 05, 2008 | Toshiba RD-XS25 DVD Recorder/HDD Recorder
Emerson EWR20V5 DVD Recorder/ VCR Combo
didn't realize had to finalise the disc after recording.
May 26, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Playing disc
any disc recorded on the liteon must be "FINALISED" before it will play on other machines.use "disctools" in the liteon menu to tdo this.
Sep 04, 2007 | Sanyo DVW-5000 DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
