Toshiba NB205 N310 BN-G ERROR 0X0000007B 0XF7A56524,0XC0000034,0X00000000 while I was trying to install win xp pro on the laptop. how to fix the issue and install xp. Thanks for help
  • Mohammed Arif Jul 10, 2010
    I did try both, did not resolve the issue.
  • Mohammed Arif Jul 18, 2010
    thanks
  • 977 Answers
Hi!
How are you?
From my experience, when receiving this error while performing a clean installation of Windows, it means - in 95% of the cases - a faulty hard disk drive... In other cases it indicates other problems, such as problematic motherboard or a bad installation CD.
(Also, If you're using a diskette to install a SATA adaper device driver, make sure it's in good condition).
I'd advise you using HDD Regenerator to try repairing your HDD.
Unfortunatelly, the free version doesn't allow repairing, but it'll sure tell you if the HDD is faulty or not...
For other possible reasons and solutions, kindy read this.
Good luck,
Pelu.
Posted on Jul 10, 2010
  • Ran Kedar
    Ran Kedar Jul 11, 2010
    Did HDD Regenerator find any problem on the HDD?
    Is there any other Windows version currently installed (Vista/7/etc.)?
    If so, use a 3rd party software to erase or re-create the partitions on the HD.
    Acronis Disk Director, which is included in Hiren's Boot CD will do the job just fine!
    Also, resetting the BIOS settings will be a smart thing to do...
    Best regards,
    Pelu.
    President:
  • 1,561 Answers
The could be cause by either of the two following, is either the operating system cd you are trying to install is corrupt or the memory stick on your system is bad, so i suggest, you get a another copy of the operating cd and try to load it on your system, if the problem still persist, then you will need to replace the memory stick on your system to enable you load your xp.
Take care.
Posted on Jul 09, 2010
Nb205-n310/bn maxes at 800x600 screen resolution
Make sure you have the correct driver installed for the graphics. Right hand click on the desktop, select resolution and pick a size that fits.
Feb 12, 2014 | Toshiba NB205-N310/BN Netbook
Connect to TV
Most likely your laptop. Check the TV manufacturer's website for drivers that will work with your particular TV.
Jun 01, 2012 | Toshiba NB205-N310/BN Netbook
Laptop Toshiba NB205. when i press the power button there is no display, i've tried removing the ram and display cable still no display when i fix it back, but other parts like the usb seems to be...
Check if it works with an external monitor. If it does your laptop screen may have a problem. However, if it does not work with the external monitor attached, your laptop may have a motherboard issue.
Feb 14, 2018 | Toshiba NB205-N310/BN Netbook
Hello My nb205-n310 works perfectly until you put it into hibernation or turn it off. Then it won't boot up for a while, then, boots back up randomly to full usage. It is not battery or charger. short...
I'm assuming you have all the drivers installed and properly configured.
Yes, it appears that a part doesn't start up as it should. Run this program
http://www.cpuid.com/softwares/pc-wizard.html
and check the voltages, if one is low then the board is failing.
Jul 12, 2010 | Toshiba NB205-N310/BN Netbook
How to remove the motherboard on a Toshiba NB205-N310/BN netbook
The manual on the support page should tell you, but unless you have done this kind of thing before I would not try.
I have built a few pc's and repaired many pc's and laptops. and i would not want to try that.
Jul 10, 2010 | Toshiba NB205-N310/BN Netbook
Hooked up toshiba nb205 to toshiba lcd tv have audio no picture
you probably need intel graphic media software go to Cnet this will help with the video/picture
  • http://download.cnet.com/Intel-Graphics-Media-Accelerator-Driver/3000-2108_4-10300119.html
feel free to rate the help
Apr 03, 2010 | Toshiba NB205-N310/BN Netbook
Tosheiba Netbook NB205-N210 2 GIG, upgrade to Windows 7
I personally have not but if you are concerned how it will run, you should be fine, windows 7 is very efficent on resources.
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
    These are system specs so if you exceed these then your laptop will run great.
    Hope this helps
Mar 20, 2010 | Toshiba NB205-N310/BN Netbook
Toshiba nb205 display problems
Search for the display drivers for your computer
Jan 04, 2010 | Toshiba NB205-N310/BN Netbook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
