Question about Intuit QuickBooks: Pro 2005 for PC
I am trying to load 2005 Pro onto windows 7. I got past the flash player 7 issue by bypassing it. [I went into the actual CD and clicked on the icon and the software loaded.] Toward the end of the down load an error message appeared. "Error 9104 module C Program Files x861\common files\intuit\quickbooks\Zrush3_QB.ocx"
  • jfchi1 Jul 14, 2010
    The above blog offered no solution that I can use. If there are any other suggestions I would be open to them.
    Thank you
    President:
  • 4,070 Answers
Hi! I provided a link to help you out on the error 9104. HOpe this helps and have a good one! Please click here http://www.cleanerrors.com/fix/error-9104/
Posted on Jul 14, 2010
  • 3,083 Answers
I'm going to refer you to a blog, and it has some answers to this problem, and things to try. Go down to TrekDozer's blog, and try his suggestion. It fits your scenario, and may be of help to you:
http://social.answers.microsoft.com/Forums/en-US/w7programs/thread/7d52962f-6cbf-4cd3-95a1-dc16cfb3fe67
Hope this helps.
Posted on Jul 09, 2010
Flash player 7
If you are getting the message about flash player 7, explore the cd and look for the Qbooks folder. Inside the folder run setup. This bypasses the prerequisites.
Jul 16, 2012 | Intuit QuickBooks: Pro 2005 for PC
2005 Jeep Liberty CD player
Possible security issue. Check owners manual. If aftermarket player, some had a small hole on front panel with a reset button. Check player manual. Possible digital lockup, pull fuse so unit is dead for a minute, reinstall fuse and try unit. Did you try loading a cd?
Dec 21, 2011 | Audio Players & Recorders
I can't reinstall my Pro 2005 because it asks for Flash 7 then the cd tells me it can't install it.
You're several versions behind with your QB Pro, and also several versions behind with the Flash Player you're trying to install.
If you're reinstalling because you upgraded your operating system version, this is likely the root cause. QB 2005 is not compatible with Windows 7; neither is Flash 7.
While you may be able to install the program using XP Mode, that isn't the most reliable way of running it. I recommend avoiding uninstalling the .net framework files and "back versioning" as a way of getting around it, because it is likely to cause problems with other functions.
You may be best off to upgrade your Quickbooks version.
Hope that's helpful.
Jan 16, 2011 | Intuit QuickBooks: Pro 2005 for PC
Problem installing quickbooks pro 2005 software
right click on the install cd and click on QBooks, then setup and it will install withou tthat happening
Jan 31, 2009 | Intuit QuickBooks: Pro 2005 for PC
Can't install quickbooks 2005 - need flash player 7
open the disk file where qb is and look at 3rd party files
then click flash 7 and ignore when it says error
then the darn thing will install no other solution listed works !
but this just did
Dec 20, 2008 | Intuit QuickBooks: Pro 2005 for PC
When i insert quickbooks cd and click install it says error need to install flash 7 macromedia.
Depending on the version of QuickBooks you are installing, it may require the flash player for some of it's help functions. Typically, the flash player the program requires is included on the cd.
There can be instances where you already have a later version, but the program is not reognizing it. This may indicate that the Flash registry entries are not in the Windows registry properly, and the Macromedia Flash needs to be reinstalled.
If you have already installed the program once, and the Flash installed, you may get an error message about needing to install, or that it cannot install the files named ************. In this case, you may try ignoring through the message.
If worst comes to worst, explore the cd, copy the Qbooks folder to your desktop. Inside the folder, you will find the Install file and the installation should go through.
Sep 21, 2008 | Intuit QuickBooks: Pro 2005 for PC
Cannot install quickbooks pro 2005
Download the latest flash player from www.adobe.com
Thank you for using FixYa!
Az.
Sep 17, 2008 | Intuit QuickBooks: Pro 2005 for PC
Problem in installing quickbook 2005 pro
you were suppose swicth off your pc after dowloading your flash player 7.
Jun 10, 2008 | Intuit QuickBooks: Pro 2005 for PC
Quickbooks 2005 Error 1603
Explore the QuickBooks 2005 CD, go into the QuickBooks folder and double click quickbooks.msi - this will install QuickBooks without checking for the old/outdated Flash Player 7.
Sep 30, 2007 | Intuit QuickBooks: Pro 2005 for PC
Intuit QuickBooks: Pro 2005 for PC Logo
64 people viewed this question
Top Intuit Computers & Internet Experts
Scott Fair
Scott Fair
Dan Shibata
Dan Shibata
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
