Question about Car Audio & Video
I have a 6 cd changer is my Sebring. It was playing disc #2 and I decided to change to disc #5. An error appeared on screen and now I'm unable to get the Cd player out. I think the two disc got stuck as one was going and the other coming out. I need to know how to get the changer out so I can get the cds out of the changer.
Get two wires and hook one of them up to the radio on the power wire and ground it and press eject and rub yout stomache and pat your head and hop on one foot and try to bite your ear and it should be fixed
Posted on Jul 09, 2010
Error-99 shows on screen then turn system off
Error 99 is CD not up to speed. Either the CD is slipping, Defective CD, pickup is unable to read sectors and is either dirty pickup or pickup going bad.
Is it always the same CD you are playing? Is the CD smudged with finger prints or dirty? If not suspect the CD itself. This will require Repair or Replace, as E-99 is a classic malfunction & unit will need to be taken apart, "unless" there is a CD stuck in the Unit.
If you have loaded a Blank Cartridge & clicked Eject & found no extra CD, then you will need to have a Reputable Shop Repair Typically this is the Logic I.C. & / or the Servo Motor. Sometimes you can find the same Unit on E-Bay, Craigs List, etc for less than Repair
Changer Error Codes:
E-00: Poor Cable connection.
E-01: Magazine not properly set in changer.
E-02: No Disc in magazine.
E-03: CD does not have selected track number.
E-04: Disc is dirty, upside down or unreadable.
E-10: No data is recorded on the MD. The player plays the next disc automatically.
E-99: Changer malfunction, disc may be caught in machine or changer requires service.
Hope this helps. Your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Oct 26, 2011 | Sony CDX-454RF 10-Disc CD Changer
SL PD887 5 disc CD changer was working one day but not the next day - does not read the CD - goes from one CD to the next but unable to read each CD in the changer. Have changed the CD's and cleaned the...
I have a model sl-pd847 and experience similar problems to many other submitters. I checked the main pcb and found discolouration around what appear to be 2 (power?) transistors and probably a voltage regulator. After about 4-5 minutes after switch on these get really hot. I suspect that may be the reason why it doesn't work anymore. Worth fixing? I don't think so. This one didn't even play CD-R let alone CD-RW! Get something a bit more up to date I say.
Jan 16, 2011 | Technics SL-PD887 5-Disc CD Changer
Six cd changer with 6 cds stuck inside, none will play and message appears no cd, or cd error,or eject error in a 2004 ford escape
Ok this may seem barbaric but it worked on mine.......Hit the top of the stereo a couple of times and see if it corrects the problem.
May 30, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Jensen hd5112 error 2
CD Changer Error Codes: If problems arise during CD changer operation, the following error codes may appear in the display:
ER-1: No magazine loaded.
ER-2: Problem in the disc loading function.
ER-3: Error in the disc loading function.
ER-4: Error in the disc unloading function.
ER-5: Error in the magazine position.
ER-6: Error in the laser pickup position.
ER-7: Error in the laser focus on the disc.
Dec 21, 2008 | Car Audio & Video
About every 2 months our 6-disc CD changer breaks down and we have to have the whole radio replaced they said it comes from playing burned cds in it but it has even broken down with store bought ones. So...
I had the same problem i just decided to pull the whole thing out and get a new radio and single disc cd changer put in and so far it works fine.
Jul 26, 2008 | 2006 Chevrolet Equinox
Pioneer cdx P1280 error11
pnoman: Your code means an electrical/mechanical failure. Follow this: 1. If the cartridge is stucked try to force it out slowly with a fine screwdriver. 2. Once is out or if already out without forcing it, remove all remaining CD's. 3. Insert a laser lens CD cleaner. 4. Clean it at least 3 times. 5. The unit must be disconnected from the 12V signal to be reset it at least 5 minutes, then reconnect. 6. If problem re-appears repeat procedure once more. If problems still, your laser lens is damaged and need replacement. Probably from $40.00 to $55.00. SithPitt
Jul 04, 2007 | Pioneer CDX-P1280 12-Disc CD Changer
Kenwood 10 disc changer
i have a sony mini Hi-Fi Component System MHC-GX470. I comes on, the Radio and Tape deck plays well. the CD Player says "mecha Error" and hangs. CAN YOU PLEASE HELP ME???
Jun 23, 2007 | Kenwood KDC-CMP59FM 10-Disc CD Changer
Harman Kardon FL8350 CD Changer
try lifting the left side of the player, I tried that last night, and it behaves different, in horizontal mode it tries to load each disc before it finds that there is no disc, but when tilted it just scans the slot (with som optical sensor) and finds the slot empty without loading the disc
Feb 25, 2007 | Harman Kardon FL8350 5-Disc CD Changer
Cd will not play and keeps ejecting
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. Sounds like the mech is gummed up, jammed, or a cd is stuck inside. Get a nerd to open it up and check it over. Luck
Jan 14, 2007 | Kenwood KDC-3027A CD Player
Car Audio & Video Logo
127 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
