Question about Whirlpool 24 in. ADP5966 Free-standing Dishwasher
Cda dishwasher ive got a cda cw492 dishwasher and there is no water coming out and there is a green flashing light
  • 4 more comments
  • Stuart147 Jun 14, 2008
    We have the same problem.
    Dishwasher worked fine, now nothing and a green flashing light, which flashes twice in quick succession.
  • needfullthin Sep 24, 2008
    my cda cw492 flashes 6 times can you help
  • len2nic Feb 02, 2009
    the light flashes and no water comes out
  • changefor200 Feb 19, 2009
    no water coming in dishwasher
  • Anonymous Mar 01, 2009
    machine going on and then you can hear it filling but there is no water in the machine and then the green light starts flashing.
  • needfullthin May 11, 2010
    cda cw 492 still no joy still flashing 6 times ,and dont know how to reset
Green light on right flashing and beeping noise..Problem solved by thowing a few pints of water in the bottom of the dishwasher...must have 'primed' the pump..which must have been the problem; working fine now. David- Crosby
Posted on May 22, 2010
I have just developed the same problem on my CDA CW492 - did you find a fix for this problem?
Posted on Jul 24, 2008
I have had the same problem the solenoid valve is stuck on the water inlet.I stripped the panels off and tapped it with a screwdriver press the start button and it will reset.
I have done it twice now but will eventually replace it.
You could try and hit it where the water hose is connected to save dismantalling the whole thing it might work.
Always press start button and till pump stops and then turn dial to the off position and then turn through programmes, green lights should appear for each programme as you pass through, this indicates the valve is free.
Posted on Mar 06, 2009
Can anyone help please
Posted on Feb 02, 2009
Cda wc140in
Hello, hope you can help? I brought a second hand (but brand new, but not used CDA wc140. Its plumbed in fine, switch on, the end light comes on, the programme button just beeps when pressed. There's no info in the manual. I hope I haven't brought a second hand dud, any ideas to start would be greatly appreciated. Steve...
Apr 24, 2012 | Dishwashers
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after...
Anyone got an answer to this, as I have exactly the same fault.
Dishwasher appears to switch on OK, then after a short time (20 secs?) the pump noise stops and the green light flashes - it seems to e a sequence of 7 flashes, then stop... 7 flashed then stop.
The sequence could indicate a fault detected?
Anyone know anything about these units from IKEA, made by Whirlpool?
Thanks!
S
Feb 12, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Cda cw 494 - dishwasher makes beeping noises and stops halfway through cycle . will restart if turned off but will not complete . doesnt seem to be filling properly .now and then does complete cycle and...
Greetings,
usually, open and close door..then start counting the flashes. these will give you your fault code. The code then tells us where to go from there. off hand, i would say you have a heater problem.. Either, the water is not getting hot enough because of a faulty heater, or faulty thermostat. The button above the green light that flashes try and hold that down for a minute to reset....let me know about the flashes
Nov 16, 2010 | Whirlpool Dishwashers
Indesit dishwasher IDL505 green light flashing water not entering the machine
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Aug 27, 2010 | Indesit 24 in. IDL500 Built-In Dishwasher
Cda cw494 dishwasher it runs for about 20 mins
is the light indicator flashing because you need to add salt or rinse aid.i have a bosch and my lights only flash to give me information on addig salt and,or rinse aid. so i can stop this by setting my dishwasher to take all in one detergent ,then the lights will not flash.
Nov 10, 2009 | Dishwashers
Green light flashes 7 times - why?
Ok, the reason for the shutdown is because of a serious control fault within the control panel. it could be because of a simple lose wire or, it could be as serious as a damaged control circuit board.
The best way to find out is to use a multimeter and test all pins on the back of the control panel for their respective operational values. Make sure the wires are not worn and damaged as well. check the entire wiring harness for lose fit on all correlating parts in the unit.
If you are not an experienced electrician, i would recommend calling in a tech for a look. Your tech will run a smilier inspection to make sure its the control and not a motor malfunction.
In most cases, this will most defiantly be a control board failure and replacing the board will usually fix this type of issue.
PLease rate and god bless:)
May 09, 2009 | Dishwashers
I have a cda mx194 dishwasher 1st three lights are flashing and it is beeping it wont start the cycle
MX194 Dishwasher.
Switch off and unplug before doing anything. .
First three lights are flashing on top and it will not stop making stupid noises.
Remove plastic panels at front of machine under door, see if there is water inside.
If there is ... something is leaking. If it is a slow leak - solution is to dry up excess water in tray with paper towels or whatever comes to hand. You will need to find the leak somehow - salt container is usual suspect.
There is a microswitch attached to a float on the left hand side inside a white plastic cover. Water at the base of this activates the switch and disables machine. Mine has not leaked since trying this fix and machine is running well 2 months down the line. Better 10 minutes with paper towels than 2 hours of expensive plumbers.
Jun 15, 2008 | Dishwashers
CDA CW 446 dishwasher problem
Emma:
Is there a reset button on it? If so, press that. There are also sequences of buttons which one has to push to reset it. These are kept secret. Try pressing Hi Temp and Heated Dry, turn loose and press again within Five seconds. Or turn off the electricity and see if that resets it
May 11, 2008 | Dishwashers
Whirlpool 24 in. ADP5966 Free-standing Dishwasher Logo
2,489 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
