Question about Weiser Lock POWERBOLT ELEC DEADBOLT
Weiser combination lock beeps
Our Weiser combination lock still beeps after changing batteries.
The lock itself is only two years old.
    Problem Solver:
  • 15 Answers
You should check if the keyboard ribbon cable is properly connected and not pinched or cut ... Also it is possible that water has entered into the keyboard. In case you should remove and dry with a hair dryer.
Posted on May 15, 2011
Lost combination
The Weiser brand and Kwikset brand Powerbolt are identical, so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Change the batteries with fresh brand-name batteries before you reprogram!
Sep 21, 2012 | Weiser Lock Powerbolt 1000 Lock
My Weiser powerbolt lock is beeping-changed batteries-won't stop
Why is my Powerbolt 1000 unit beeping?
To determine why your lock is beeping abnormally, please follow these steps:
  1. Take out batteries and unplug powerstrip.
  2. Let it sit for 1 minute, then put the batteries back in and wait another minute.
  3. If it does not beep, the keypad needs to be replaced (17733-1).
  4. If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
Contact Customer service from here:
http://www.weiserlock.com/CustomerService/ProductSupport/SupportContact.aspx
Jan 09, 2012 | Weiser Lock Powerbolt 1000 Lock
Began to beep in intervals. Changed batteries and it worked a couple of times then beeped twice then touchpad will not work, Five minutes later it beeped steadily for 10 seconds than stopped. Will not...
This is the relevant excerpt from the Powerbolt programming and troubleshooting instructions:
"To determine why your lock is beeping abnormally, please follow these steps:
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish)."
Since you've already gone through the battery change, try the battery remove-reinstall recommended above. If that doesn't work for you it suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page, where you will find the appropriate number of your location:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem. You will want confirm that you need the part before you go through the expense, and that it's worth it. You will need to know the "finish" of your lock. Try to talk them into warrantying the part, in spite of the age (one year warranty on electronics), as a matter of good customer relations. They will help you get the correct part on order.
Good luck--and please provide feedback if this helps!
Sep 22, 2011 | Weiser Lock Powerbolt 1000 Lock
Our Powerbolt 1000 started beeping this morning. I've tried replacing the batteries and disconnecting the power strip. The beeping continues. I am unable to reset the code. Are there any other...
Powerbolt is Beeping?
Take out batteries and unplug power strip.
The complete page that I cut this from can be found by cutting and pasting this link into your browser search bar:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Since you've already gone through the battery change, etc.,this suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page:
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense.
Also, they will be able to get the correct part on order for you.
Jul 16, 2011 | Weiser Lock Powerbolt 1000 Lock
The lock started beeping every couple of minutes so we changed the batteries and the problem continued. The lock was working ok just wouldn't stop beeping. It is probably close to 10 years old and I...
Since you've already gone through the battery change, this suggests that you need to replace the appropriate Powerboard for your lock.Since you stated that your lock is ten years old, this is likely the case.
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense. And to confirm that you indeed are concerned with the correct model of lock! Secondly, they will be able to get the correct part on order for you.
This link should take you to the complete installation and programming instructions:(cut & paste into browser)
https://s3.amazonaws.com/Kwikset/Powerbolt%201000%20-%20Installation%20Instructions.pdf
Jul 03, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
We purchased our keyless weiser dead bolt 11 years ago,has worked perfectly till today,red lite off,changed batteries,still nothing,no beeping ,no movement of any kind..Ellie
This is the link to the troubleshooting procedure for the Powerbolt:
Here is the contact information for ordering parts:
http://www.weiserlock.com/Support/Faq/50160000000HhY3AAK.aspx
Customer Service:
Your lock is well out of warranty and may be simply dead of old age. However, I'd still contact their Customer Service for further troubleshooting, and you may be able to get them to stand behind their product and help you with the replacement if necessary. Good luck!
Apr 27, 2011 | Weiser Lock Powerbolt 1000 Lock
Dear Sirs: I have a Weiser keyless locke
  • Take out batteries and unplug powerstrip.
  • Let it sit for 1 minute, then put the batteries back in and wait another minute.
I contacted customer support... they tell me the FAQ information on their own website is incorrect. The opposite is true, therefore the following is correct:
  • If it does not beep, the powerboard needs to be replaced
  • If the unit continues to beep, the keypad needs to be replaced
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
-=dån=-
Jul 15, 2009 | Weiser Lock Powerbolt 1000 Lock
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
307 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
