Question about Ultra LCD30-500 Television
My ultra tv will black out after having it on for a few minutes, but the sound is still okay. I can then turn it off and wait for a few minutes and turn it back on okay and then the same thing happens again.
  • 1 more comment
  • trainsrok Jul 09, 2010
    I don't kow if this is a solution or not but it sounds like it might br right
    do you know who made the ULTA tv's
    I'm in Blaine Washington zip code 98230
  • 10,594 Answers
It seems tv lose its back light and screen turns black because back light inverter board fails for some reason.
Back light inverter and power supply board can be cause of that problem and need to be checked by tv repairman.
Local tv repair shop will help you to get it fixed.
Thanks.
Posted on Jul 09, 2010
  • 4 more comments
    Is it a heat thing or just happens? Why will it come back on for a while?
    Will a local tv repaiman know anything about the ULTRA LCD30-500 TV?
  • Shahid Electronics
    Shahid Electronics Jul 09, 2010
    I think problem would be of leaky capacitors in power supply board and arc of high voltage in back light inverter board that can activate protection circuit to shut it down.
    I hope local tv repair shop would know about ULTRA LCD30-500 tv because they fix tv daily.
    What is your location and zi code to find out tv repair shop in your area.
    Following are few tv repair shops in your area that can fix your tv.
    1- Electronics Service Professionals.
    2- Alex Audio Video
    3- MS Audio
    4- Tech One Electronics
    Click above links for adrress and call numbers.
Why does my LG tv seems like it need to warm up before it will accept HDMI signal?
Sounds like a capacitor fault. They can be intermittent when cold, but will work okay when warm. Eventually though they will fail.
This is your advance notice to get the set either repaired by the manufacturer or a local TV shop.
Sep 06, 2014 | LG 42LG50 42 in. LCD HDTV
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
Polaroid tv screen goes black after 30 40 minutes, sound is good. No picture. Turn set off and wait a few minutes and the picture returns for a few minutes then goes black again.
Ur tv now power on only have picture few mins,than dead,have sound only?Yes,than the 1 or 2 the long board call the LCD inverter boards are dead.The LCD inverter long boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy 1 or 2 long LCD inverter boards for the replacement.
Jul 05, 2010 | Polaroid FLM-3232 Television
TV works fine for about 3 minutes then the picture goes black and the red light on the front of the TV starts blinking. The sound works the entire time. If I shutdown the TV and wait a few minutes and...
The light is blinking a code. The code will be a series of blinks, a pause and the blinks again. Phone Sony service and give them this code. They will be able to advise you as to the problem.
Apr 03, 2010 | Sony KP-53HS30 53" Rear Projection...
47in Phillips-tv picture goes black still has
Could be the signal board has a bad cap, in this case it sounds like you are getting intermitten power to the inverters....when the tv goes down and of course you have audio....Shine a flashlight on to screen and see if you have a picture...look carefully. If this is the case..you have the above problem!
Nov 23, 2009 | Televison & Video
No Picture, but I have sound!
Your color tube has probably went out that is why you have sound but no picture, you will have to call a tv repair place or where you bought it from to get an estimate on having it repaired
Jul 22, 2009 | Televison & Video
After few minutes LCD picture went black but sound works ok
most likely the power inverter, also suspect the p/s. best to have a trained tech check it. Julio at milleniumtvsvc@gmail.com
Jul 21, 2009 | Memorex MLT3221 32 in. LCD TV
The image leaves and the screen goes black.
Either the picture tubes are going, or they are dusty. Take apart the front grill and take off the black cut away behind the grill. Inspect the tubes and the circuit boards. If they are dusty blow them off with an air can duster. It might work and its free and takes 5 minutes.
Ben
Mar 23, 2009 | Sony KP-61HS10 61" Rear Projection...
Rear Projection TV Cuts out Need to wait and then turn back on?
SOUNDS LIKE A FLYBACK PROBLEM AROUND $70.00 FOR PART
Dec 06, 2008 | Panasonic TX-42PT10 42" TV
TV screen went black, sound OK
check cold solder vertical circuit
Nov 21, 2006 | JVC AV-27530 27" TV
Televison & Video Logo
57 people viewed this question
Top Ultra Televison & Video Experts
Jaime Hernandez
Vernon Taylor
Are you an Ultra Televison and Video Expert? Answer questions, earn points and help others
