Question about NetGear RangeMax NEXT WNR834B Wireless Router
Wireless router has no power---no lights
Wireless router has no power----working fine yesterday ----power strip works, as other items still have power----tried plugging adapter for router into another socket & still no lights on it at all? any ideas?
  • 173 Answers
SOURCE: Netgear 108 Mbps Router WGT624 v3
As you say that, you are able to go online with the modem, connect your modem- router and laptop witha cable and check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be checked..open your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
Posted on Nov 28, 2007
SOURCE: Wireless router working fine, randomly stopped working.
Best solution is no solution.
I've been having the same problem for a while now. Even replaced the router with a newer WBR-2310. Same issues after 4 months.
I have done all that I could and even reported it to D-Link without results.
Seems to be a common occurrence.
I have two machines hard wired and one on wireless. I use VPN for work.
It's a real pain to get disconnected in the middle of doing remote application support.
JM
Posted on May 24, 2008
TBlessed 1
  • 61 Answers
SOURCE: Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Posted on Dec 01, 2008
kakee
  • 1269 Answers
SOURCE: router cannot connect to belkin g usb adapter it worked fine yesterday and today nothing!
Make sure to install the USB adapter's driver and utility. If it's installed, you need to use the Belkin WLAN Utility to connect to the wireless network. You should be able to find the signla coming the router and you can connect to it
Posted on May 07, 2009
leecom72
  • 4806 Answers
SOURCE: Netgear WGR614 internet light not coming on
Hi there.
Reset the wireless router by removing the power cord from the back of it for 30-60 seconds, then plug the power back in wait for 2 mins then try to reconnect again.
If you get no joy please post back for aditional advice.
Good luck and thanks for using FixYa!!
Posted on May 11, 2009
I have a D-link DSL-2750U router worked fine till yesterday, but now its power led keeps on giving a red light it should give green a second or two later but it keeps givings
Reset router. There are two resets. A simple push reboots and holding it in clears all custom settings. Try the first.
This is a quick fix and usually does it. Test with network cable and work your way backwards to modem if you still have problems.
Nov 11, 2012 | Computers & Internet
Worked fine up till yesterday now wireless wont work
The wireless cards in the computers need to be configured with the router's wireless settings so the computers can connect to the wireless router.
Resetting the wireless router back to the factory defaults will not let the computers connect to the wireless router without configuring the network card in the computers with the router's wireless settings.
I suggest you configure your wireless router with encryption settings to prevent unauthorized persons accessing your wireless network and Internet connection and your computers.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 01, 2012 | Computers & Internet
There was a lighting storm the other day and when the house next door was struck my wireless router stoped connecting to the internet. It had been working fine the past 6 months is there anything I can do?
1. the lighting could have rendered your router functionless. or the cable/dsl line has been fried at the drop.
2. call you ISP and have the line checked.
3. If the router has a "red" light at the power light you have a bad power adapter or the power supply circuit in the router has been fried by the lighting. The only remedy here is to get a new router and a surge protection strip that is above 10,000 joules and guaranteed.
Jul 01, 2010 | D-Link DIR-615 Wireless Router
My wireless router was working fine for a year until this last weekend when a storm was coming in. We unplugged everything, the power was out for a couple days. When we regained power, we plugged...
depends on whether or not it was plugged in a power strip or not and even in the power strip it could be fried anyway because it depends on wherther or not your house is hooked up to a ground which would be the third prong on the plug send me questions if you need something else
Jun 20, 2010 | NetGear RangeMax WPN824 Router
Hi there.
May 11, 2009 | NetGear WGR614 Wireless Router
Router installed yesterday, but not working today. Wireless light indicator is not on
If the wireless light is not lit up on the router , better reset the router, This is the way how you reset it Press and hold the reset button of the router for 25 seconds and then after that power off the router and check the wireless light if its ON then if its ON just reconfigure the router by running the setup CD, but iof the wireless is still OFF have the router replace since its still new....
Apr 30, 2009 | Computers & Internet
Can't connect to the internet
Had same problem just now but somehow power had been inadvertently disconnected at the source when cleaning the wire mess yesterday works fine now after plugging in. Hope yours is simple also, good luck. Chaslannen
Nov 21, 2008 | NetGear WGR614 Wireless Router
No wireless signal
The router probably went, u may need to buy a new one. Call linksys for support.
Apr 22, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
109 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
