Question about Lexmark C782dn Laser Printer
STREAK ON ITU OF LEXMARK C782
One line about a half inch in diameter running the length of the itu. shows up in the same spot. removed the toner cartridges and ran a belt tracking test to clean the line off the itu but after a cleaning the line becomes more vivid and the display reads "belt tracking test failed, error code: 04" the colour of the line depends on the colour of the job being printed but when i did the belt tracking test the line looks the same colour as waste toner. PLEASE HELP
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Lexmark Expert
  • 217 Answers
The only thing that helps is replacing the ITU.
Posted on Jul 27, 2010
Does compaq nx6310 have in built modem?
Hi!
Yes, it actually has a built-in modem, here is the specifications:
Max Transfer Rate 56 Kbps
Modem Fax / modem - MDC
Protocols & Specifications ITU V.21, Bell 212A, ITU V.22, ITU V.22bis, ITU V.29, ITU V.32, ITU V.32bis, ITU V.34, ITU V.17, ITU V.23, ITU V.27ter, ITU V.8bis, Bell 103J, ITU V.92, ITU T.30, ITU T.4, ITU V.250, ITU V.251, ITU V.80
Fax Compatibility G3
You can also check all hardware details about that laptop at: http://www.laptopdrivers.net/specs/hp_compaq_nx6310_laptop.htm
Hope this helps.
Apr 17, 2011 | HP Compaq nx6310 Notebook
100.01 Services ITU Error, Lexmark C782
From the Lemark Service manual
A 100.01 ITU error indicates that the printer did not detect the ITU belt home sensor. Before proceeding with this
service check, make sure that the Second Transfer Roll is correctly installed. After you reinstall the Second
Transfer Roll, check to see if a 100.01 ITU error is still displayed. If a 100.01 ITU error is still being displayed,
continue with this check.
The ITU has an optical sensor that watches for a piece of reflective tape on the inside of the image belt. This
tape is read every revolution of the belt. If a signal is not received from the belt sensor within a certain time
period, the printer posts an error due to the loss of signal. There are several causes for the loss of signal. First,
the belt has tracked too far to the front or rear of the printer. In this case, the belt is still turning, but the reflective
tape is no longer passing within view of the belt sensor. This is considered a belt tracking error and is initially
posted as a 100.02 ITU Error. The other causes of a signal loss could be a belt stall, meaning the belt is not
turning, or a true signal loss, which would be due to a bad sensor, broken cable, loose connection, or bad
system board. These other causes post as a 100.01 ITU Error.
To assist the printer in determining the cause of a signal loss, there is a buffer that records the belt position for
the last 50 revolutions. If the printer loses the belt signal, it refers to the buffer. If the buffer shows significant
mistracking before signal loss, it will post a 100.02 ITU Error. If the buffer shows that the belt has been tracking
in the center before signal loss, it posts a 100.01 ITU Error. Due to memory restrictions, the buffer is not saved
during POR. This means if a printer posts a 100.02 ITU Error, so the belt is tracked off, and the customer or
servicer turns off the printer to clear the error, when the printer starts up, it will still not see the belt signal and will
now post a 100.01 ITU Error because the buffer is empty. When servicing a printer for a 100.01 ITU Error, it is
important to view the error log. See "Display Log" on page 3-29. The error log can only be displayed at this
point. Do not try to print the log. Look for past occurrences of 100.01 ITU Errors preceded by a 100.02 ITU Error.
Apr 13, 2011 | Lexmark C772dn Laser Printer
30 ITU MISSING
ITU is missing or defective. Try reinstalling the ITU. If this doesn't work you'll have to replace it. The ITU is the black "belt" at the bottom of the printer.
Oct 18, 2010 | Lexmark C752 Printer
My lexmark c782 keeps coming up 100.01 ITU error. Please help.
That usually means that the intermediate transfer unit(ITU) is defective but try these troubleshooting steps found in the Lexmark website. Just go to this link: http://bit.ly/dzs6o1. Follow the instructions but if all else fails, I suggest you contact Lexmark Technical Support.
May 04, 2010 | Lexmark C782N Laser Printer
Error Code 23.05 ITU Missing
ITU is missing or defective. Replace the ITU and the problem should be solved.
Gerrit Jan
Nov 04, 2009 | Lexmark C780dn Printer
100 ITU error
Have you recently replaced the ITU? If it is saying ITU Maintenance, then the kit needs to be replaced. If you have already purchased and installed a kit, the reason this error is coming up is because the second transfer roll (small roller under the ITU) is not installed properly. Otherwise, you should purchase and install a new ITU maintenance kit.
Mar 12, 2009 | IBM Infoprint Color 1464 Laser Printer
BLACK VERTICAL STREAKS
toner recently replaced?
have you cleaned nozels?
try running a cleaning cycle.
also clean the paper rollers to make sure you got no ink on them.
Feb 25, 2009 | Lexmark C760 Laser Printer
83 itu maintanece
You replace the ITU it has reached its end of life cycle.
Jan 22, 2009 | Lexmark C762 Laser Printer
Lexmark C782dn Laser Printer Logo
435 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
