Question about Fujitsu 18C1 Air Conditioner
I bought and installed an ASU9RLQ that had been
I bought and installed a Fujitsu ASU9RLQ mini-split that had been installed and used for approximately 6 months. It is at capacity on refrigerant and the electrical is installed correctly. However, I get no response when trying to activate the unit with the remote. I am beginning to suspect that the remote is the wrong one. It is an AR-JW5. Can you tell me if this is the correct remote for this unit or should the unit operate with it? Thank you.
  • 456 Answers
Install new batteries, aim it at the unit and press the power button. You should hear a beep or see a green signal. If not, try to command the fan to come on.
Posted on Jul 09, 2010
I have a fujitsu aou24rml that i am installing in my house and the tag on the unit says 230/208 volts but the terminal block only has L and N witch i think is for 110 volt
Based on the specs that I could find, that unit requires 208/230 volts. Are you sure you are looking at the correct terminal block. It should be more like L1/L2. Do you have the install manual and does it tell where to hook up the supply voltage?
Oct 11, 2014 | Fujitsu ASU24RLF HFI Wall Mounted Mini...
How do I silence clicking sound from a a Fujitsu Mini-Split Wall Mount?
Try taking it off the swing function. Only clicking I can think of, louvers getting jammed???
Sep 20, 2017 | Heating & Cooling
What is the hourly labor rate 2 install this unit
Trades will be very reluctant to give you an hourly rate on split system install as this would deplete the profitability. It depends on the installation, a simple back to back install would take around 3 hours with electrical connection to switchboard. It also depends on brick or fibro walls. Most installations are around 500 Aus dollars total price with the longest time frame of around 4 hours
Jun 10, 2014 | Fujitsu "AOU30CLX1 30,700 BTU Halcyon...
I am trying to replace the fan on a Fujitsu ASU9RLQ Mini-split (I have the replacement unit). I have the front cover over the Mini-split; how do I get access to the existing fan to replace it?
This is from Friedrich support and I believe yours is similar. The whole bottom of the unit should come down after you remove the outside shroud.
To take the blower motor out:The technician would do the following:1. disconnect the power2. remove all front cover3. disconnect all wires at the terminal block at the unit4. DISCONNECT ALL WIRES AT THE BOARD. take out the control board5. remove the drain hose at the back6. REMOVE 2 SCREWS ON THE LEFT SIDE OF UNIT7. REMOVE 1 SCREW ON THE RIGHT FRONT AT BOTTOM8. PULL DOWN FIRMLY down
BUT NOT TOO HARD. BE CAREFULL NOT TO DAMAGE THE STYROFORM AROUND. WORK IT SO THAT THE BLOWER AND FAN MOTOR COMES OUT TOGETHER. 9. IT IS NOT NECESSARY TO DISCONNECT THE REFRIGERANT LINES
Aug 06, 2011 | Heating & Cooling
How to use thermostat for heat on Fujitsu IAQ halcyon
This unit comes with a remote control (optional wall mounted wired thermostat available) as a standard feature. This unit is precharged with the environment friendly R-410a refrigerant. No additional refrigerant is needed if the line set is 49 feet in lenght or shorter. In addition to its very high 20 SEER efficiency rating, the 15RLQ is only 31 in. long which makes it the smallest Mini-Split System in its category through out the industry.
This category of equipment is ideal for smaller spaces where spot cooling is required. Several models in this category are ENERGY STAR Certified, meaning they save you money on your utility bill. Residential applications including sunrooms and additions are made easier with these air conditioners and heat pumps. Do you have a warm spot in your home? Fujitsu mini-splits can provide extra cooling capacity for those hard to cool areas. Commercially, their small size makes them ideal for small offices, providing individual temperature control.
Fujitsu's I.A.Q. Systems provide residential and commercial property owners an innovative solution for clean, temperature-controlled indoor air. The Halcyon IAQ systems deliver powerful heating and cooling, are designed for ease of use and maintenance, and feature an unobtrusive design which can be integrated easily into any decor. The Halcyon IAQ systems filter dust, pollen and odor making them the perfect addition to any home!
  • Wireless Remote Control
  • Plasma Filter
  • Sleep Timer
  • 24 Hour Timer
  • Dry Mode
  • Auto Louver: Up/Down
  • Auto Mode
  • Quiet Mode
  • Auto Restart/Rest
  • Auto Changeover
  • Low Ambient
  • Cold Prevention
Warranty All Fujitsu ductless mini-split air conditioners and heat pumps come with a 2 year parts and 6 year compressor warranty.
Important: All installations must be performed or supervised by a certified HVAC technician in order for the warranty to be valid.
Dec 08, 2009 | Heating & Cooling
Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Jun 01, 2009 | Fujitsu Heating & Cooling
Aou18c1 not shutting off
Fujitsu, Mitsubishi, Sanyo mini-split indoor fan motors operate continuoulsy. The room-temperature sensor is inside the unit, so the fan motor needs to circulate air continuouly to sense room-air temperature. This is normal operation.
Sep 12, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu ASU9RLQ
check indoor unit sirkit board
Mar 10, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu 18C1 Air Conditioner Logo
233 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
