Question about Honda Black Max 2600 PSI Pressure Washer
Power washer won't start
I turned it over once and it ran for 2 minutes then cut off. I cannot get it to start again. It has gas and I added some more oil. Could I have added too much oil? Any suggestions...
2 Suggested Answers
  • 251 Answers
SOURCE: New pressure washer runs starts and runs for 30-45
try removing the carb bowl and check for dirt/water etc , also if the machine is over heating it may be getting vapour locked
Posted on Nov 09, 2009
ProForce PWC102350 2,350 PSI 2.3 GPM 163CC MagnaForce Gas Powered Pressure Washer will not start
If you have compression then the first thing you check is for spark. If you have spark then you move on to the fuel system. You will have to pull off hoses at a couple of points to see if gas is at the carb and further along. If it is the carb then a simple carb kit will work.
Apr 13, 2014 | ProForce PWC102350 2,350 PSI 2.3 GPM 163CC...
Won start
Depending on set up there's a chance because you ran it out of gas the bowl is dry? Get some old school lighter fluid pull out the plug squirt some into hole , doesn't take much. Reinstall plug quickly and give it a pull and see what happens
May 08, 2017 | Briggs Stratton 020273 Elite Series...
Ran out of gas and now it won't start after adding 5 gallons
the fuel pump is cooled by gas so if u run it low alot or {OUT} it can burn it up
keep that tank at 1/4 or u will pay!!!
Jul 21, 2012 | 2002 GMC Yukon XL
Engine will turn over freely but will not start. engine was running when it sputtered and died and will not restart on a 2000 Crysler Sebring Coupe, 2.5, 2 door. May have ran out of gas. added 5 gal but...
see if the cam is turning when trying to start the engine (look through the oil filler cap) if its not, you may have a broken timing belt (and engine damage) if it wasn't empty on the fuel gauge I doubt it ran out of gas.
Aug 29, 2011 | 2000 Chrysler Sebring
My 2001 L Series Saturn ran out of gas, then after 1 gallon of gas was added to the tank, the engine would not turn over. Any suggestions for how to get it to start?
the fact that it won`t turn over is just a coincedent it happened when you ran out of gas.i`m assuming that you mean the motor won`t turn over at all and not that you mean it will turn over and not start.if it is the latter then the fuel needs time to fill the lines and pressurize the fuel system while cranking over.
Mar 18, 2011 | 2001 Saturn L-Series
John Deere 3300 PSi pressure washer shutting off while in use.Everything appears fine Oil level,Gal level,Air cleaner ok etc.. May run 2 minutes or 12 minutes then spudders a bit then Bang "Off" as if i...
John Deere will replace the cap for free; they acknowledge the vendor who supplied Briggs & Stratton gas caps provided faulty caps. Call 1-888-228-3068 then 1 (English), 2, 1 and a technician will ask you for model number and Serial Number (which they need to replace the cap). Don't drill a hole in your cap: debris will find a way into the gas tank and end up possibly fouling the engine. Bob from NJ
Nov 03, 2009 | Dewalt 3800 PSI Pressure Washer
ML430 run out of gas and it won't start
you need to bleed the system, turn key to run postion then wait two seconds and turn off again do this a dozen times then hold foot pedal to floor and crank engine, this will clear fault codes and prime system then it should start, if you need more help post here for more information.
Aug 28, 2009 | 1999 Mercedes-Benz M-Class
My Simpson Water Shotgun shuts down about a minute into the wash
Have you checked the oil level? Some engines have a sensor that shuts it down if the oil is too low
Jul 16, 2009 | Simpson PS2600 PowerShot Commercial-Duty...
Honda Black Max 2600 PSI Pressure Washer Logo
125 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
