Question about Maxtor Hard Drive
Pin settings to change Maxtor hard drive from slave to master
Maxtor Model 51023H2
  • 518 Answers
With no pins in it should be on master setting
Posted on Jul 09, 2010
I have a maxtor quantum fireball plus as 20.5 hard drive. i want to set it to slave. how do i set the jumpers?
on maxtor drives, you will find the jumper within a cluster of 9 pins. if you look on the bottom of the drive, on the circuit board, the pins should be labeled "ms" "cs" and such. the "ms" and "cs" stand for "master" and "cable select". you rarely use the true "slave" setting anymore, more often than not' "slave" drives are set to "cable select" and are attached to the middle, slave position on the ide cable. in "cable select" mode, the cable decides what device is master and what is slave, depending upon the devices' position on the ide cable.
to set the drive to "slave", set the jumper so that it only has 1 pin under it, and doesnt actually jump any pins, or just take the jumper out. only use the "slave" setting if the "master" device on the same ide cable is actually set to "master".
if the master device is actually set to "cable select" then you will have to set the slave device also to "cable select" and the middle position on the ide cable will set it automatically to be a slave. , instead of using the jumper to make it the "slave".
to set the drive as "cable select", which is what i would recommend, use the jumper to connect the 2 pins which are labeled "cs", the 2nd position from the bottom position on most older maxtor drives, and attach this hard drive to the middle connector of the ide cable.
Nov 25, 2010 | Quantum Fireball Plus AS (QMP20000AS-A)...
I need the jumper settings for Maxtor N256 hard drive.
Hard drives have three jumper settings on them.
1.MASTER---MA
2.SLAVE---SL
3 CABLE SELECT----CS
If you have a hard drive on the end (last) on the ribbon cable connectors, then it is the master drive, and should be jumpered as such-- the jumper should be on the MA pins, any drive in the middle of the cable is jumpered as slave and should be on the SL pins.
CS usually causes problems, and I do not use it.
There are no jumpers on the motherboard that need to be changed for the hard drive. The only other settings for the hard drive are in the BIOS.
Please vote 4 thumbs up!!,
James.
Apr 23, 2010 | Maxtor Hard Drive
Take Three: I have an older Maxtor Hard DriveTake Two: I have an older Maxtor Hard Drive (Model 90645D3). I need to transfer some files from it (Win98SE) to new hard drive (WinXP Pro). I asked earlier and...
Jumper off will set the drive to slave. If you can connect both drives to the same ribbon cable with the master on the end & the slave to the second connector. Look at your bios as win is booting up to see if shows the drive as slave, you will not be able to copy windows as a operating system off of the drive, but should be able to copy files.
Good luck on your endevors.
Lee
Nov 12, 2009 | Maxtor Hard Drive
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
How do i switch the maxtor n256 model# 51023h2 from master to slave?
if u look on the back of the harddrive you will see a jumper for doing this switch, the case is marked..
Sep 28, 2009 | Computers & Internet
Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Jumper setting
The first jumper goes up and down on the two pins just beside the IDE cable slot and the other jumper goes across the top two pins next to it
Jan 23, 2009 | Maxtor Hard Drive
Maxtor 90845D5 EIDE HDD jumper settings
Connected the 2 pins furthest away from the power connector.
Pin 1
J1 IDE Connector | J2 Power
| .................... || @ * * * || X X X X |
| .......... ......... || @ * * * * || X X X X |
J50 Master/Slave -----+ | | | | | | | +-+12V
J48 Cable Select -------+ | | | | | +---+12V Return
J46 4092 Cyl Limitation---+ | | | +----- +5V Return
J44 Factory Reserved -------+ | +------- +5V
J42 Factory Reserved ---------+
Hope this helps.
Andy
Jun 28, 2008 | Maxtor Hard Drive
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Apr 12, 2008 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
Maxtor Hard Drive Logo
158 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
